Page 2 of 3 1 2 3
Re: Power Cut Off switch Question. [Re: rickraw] #1599675
03/28/14 10:37 PM
03/28/14 10:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does anyone have a fuse on their alt wire to the battery?
Yes.. I have a 100 amp on it
Re: Power Cut Off switch Question. [Re: MR_P_BODY] #1599676
03/28/14 10:47 PM
03/28/14 10:47 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
How many amp alt?
Re: Power Cut Off switch Question. [Re: rickraw] #1599677
03/29/14 01:11 AM
03/29/14 01:11 AM
Mo.
racerx Offline
racerx  Offline
Mo.
for this.
Re: Power Cut Off switch Question. [Re: rickraw] #1599678
03/29/14 01:14 AM
03/29/14 01:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How many amp alt?
Its a 85A Denso
Re: Power Cut Off switch Question. [Re: plycuda] #1599679
03/29/14 01:34 AM
03/29/14 01:34 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I have 150 and 300 amp
Where do uall purchase these fuses from?
Re: Power Cut Off switch Question. [Re: racerx] #1599680
03/29/14 01:43 AM
03/29/14 01:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I get them from a local electrical ware house near me..
its a larger fuse like the mini flat bladed ones in
the cars about 8 years ago... its just bigger with
its own holder
Re: Power Cut Off switch Question. [Re: racerx] #1599681
03/29/14 02:11 AM
03/29/14 02:11 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Good car audio shops have them.
"Just a Bracket car dressed up like a streetcar"
Re: Power Cut Off switch Question. [Re: Just-a-dart] #1599682
03/29/14 09:13 AM
03/29/14 09:13 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thax.
Re: Power Cut Off switch Question. [Re: Bigcube] #1599683
03/29/14 11:44 AM
03/29/14 11:44 AM
mi
rbj Offline
rbj  Offline
mi
I don't like running the alternator wire to the battery because that wire will be hot all the time. I set mine up with a relay. I use a continuous duty relay, similar to a Ford starter relay. See attachment.
X2 ran mine same way , they run the constant duty on golf carts a lot got mine of eBay cheap and easy. Dvw recommend this idea and works well.
Re: Power Cut Off switch Question. [Re: rbj] #1599684
03/29/14 02:00 PM
03/29/14 02:00 PM
S.E. Michigan
TruPerformance Offline
S.E. Michigan
Rather than running the alt power wire all the way back to the kill switch, I found it easier to run the field wire through a relay. I just ran a small 12 ga wire back to the switch for power, when the switch is off, car dies. I thought that was better than running the higher voltage the length of the car.
1963 Belvedere (mine)
1969 Roadrunner (wife's)
Re: Power Cut Off switch Question. [Re: TruPerformance] #1599685
03/29/14 02:57 PM
03/29/14 02:57 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
You can fuse all you like, BUT, that line is still live until the fuse blows. Plenty can go wrong until that happens.
I do the CD relay and kill the line. Rather not have any live wires to the front when the master switch is thrown.
Re: Power Cut Off switch Question. [Re: plycuda] #1599686
03/29/14 03:46 PM
03/29/14 03:46 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Sorry to be an electrical idiot.... but that's what I am, and I want to be certain of what I think I'm seeing: We're talking about a 300 amp fuse on the pos. cable, and a 150 amp fuse on the neg, correct? Then, following Mike & Jim's outlines, a 100 amp fuse on the alternator wire, along with running that wire through the continuous duty relay....
Am I straight on this?
Re: Power Cut Off switch Question. [Re: StealthWedge67] #1599687
03/29/14 04:10 PM
03/29/14 04:10 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Yes, you wire per the diagram AND use the fuse. I should put a fuse in mine.
My alternator is very close to the frame. I would forget to take the battery cables off and saw sparks when I was pulling the motor. I wired it in before I put it back together a few years ago. The Solenoid is the silver thing under the tail light behind the battery.I have it wired into the cut off switch.
Re: Power Cut Off switch Question. [Re: Bigcube] #1599688
03/29/14 04:32 PM
03/29/14 04:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On mine I use a Ford type starter solenoid in the trunk since I ran my starter cable under my carpet I did not want it hot all the time so its only hot when cranking as I have it going thru the solenoid. The smaller red wire is my 12 volt feed which is the wire my cutout switch controls as it goes to the starter relay on the firewall where the car picks up it hot 12 volt feed to the fuse box , ign switch , headlite switch and so on. I have a 70 am fuse with eyelets on it on the red wire as its bolted to the battery cable end and then hooked to the wire. The black wire is my alt output. I like the idea of putting the field circuit on a relay that would kill the field when you turn the kill switch off and stop the charging system from working. That would work as long as the relay control turns the relay off when the cutout switch is turned off. Ron
Re: Power Cut Off switch Question. [Re: Bigcube] #1599689
03/29/14 04:32 PM
03/29/14 04:32 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Did mine the same way. That way the power at the alt is off when the kill switch is off.
Re: Power Cut Off switch Question. [Re: Todd] #1599690
03/29/14 04:45 PM
03/29/14 04:45 PM
RobX4406 Offline
RobX4406  Offline
On a race car the way that s605 is wired is fine if you turn the master off.
Street car, if you leave the master on, the S605 will be a constant draw and drain the battery. It needs to be switched with something from a keyed source in the on position.
There's a minimum standard, then there are improvements.
Re: Power Cut Off switch Question. [Re: RobX4406] #1599691
03/29/14 05:20 PM
03/29/14 05:20 PM
Puyallup, WA
Puyallup, WA
Uhggg...... Why must there always be problems?! Are there relays available that would work like this, but not need to be switched? I generally break the master cutoff whenever I leave the car. But if I were to add this, I would want to do it correctly and not expose myself to potential dead battery issues. Wiring it all the way from the key switch seems like a hassle and lots of added wiring, which I don't want.
PS: sorry to hi-jack, but this is good info. and I think its relevent to the OP.
Re: Power Cut Off switch Question. [Re: StealthWedge67] #1599692
03/29/14 05:56 PM
03/29/14 05:56 PM
RobX4406 Offline
RobX4406  Offline
Find a wire that is hot when key is in run position and wire it to trigger the CD relay, pretty simple.
What's a 16ga wire weigh... not much and have it mirror route of the taillight wiring.
Re: Power Cut Off switch Question. [Re: RobX4406] #1599693
03/29/14 07:04 PM
03/29/14 07:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Rob is right as it is simple just make sure you use key on powered wire as I would not use a hot all the time wire for much of anything so you dont have a draw. I leave my switch on most of the time on the street and have no drain at all. But I run my alt output back to the battery side of the master switch and only use a solenoid for my starter cable. I do turn it off if I park the car where I cant see it all the time. Ron
Re: Power Cut Off switch Question. [Re: StealthWedge67] #1599694
03/29/14 09:15 PM
03/29/14 09:15 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
300 amp on the starter cable and 150 on the alternator cable. not the neg cable
Page 2 of 3 1 2 3
