Re: ? For those that run Drag Radials (rear) on the street
[Re: bigdad]
#1599347
03/28/14 11:23 AM
03/28/14 11:23 AM
Posts: 12,814 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Tire Rack has a 195/70-15 Continental Vanco on clearance right now. They are about 26" tall but just a little wider than you spec'd. They are a D rated capacity tire rated to 65lbs air pressure. I run them and they hold the front of the car real well. A very good choice for $108, I think.
Master, again and still
[Re: DaveRS23]
#1599348
03/28/14 11:27 AM
03/28/14 11:27 AM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
195/65/15 Falkens. I was forced to buy them on drag week last year when I had a front tire failure. I like them better than the 165s I had on there. It looks a little better and drives slightly better.
68 Barracuda Formula S 340
[Re: 1967dartgt]
#1599350
03/28/14 12:12 PM
03/28/14 12:12 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
How do you guys feel about running these radials past there speed rating? All these tires are s speed rated so that's only good to 112mph.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 68LAR]
#1599351
03/28/14 12:15 PM
03/28/14 12:15 PM
BradH
I run a P215/75r15...
Same here, on 5" rims. IIRC, they're about 27" tall, but I can't recall the tread width. I have 275/60R15s on the back which are closer to 28" tall.
[Re: 1967dartgt]
#1599352
03/28/14 12:20 PM
03/28/14 12:20 PM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
I ran on the 165R15 tires for a long time and never had a problem. Lots of FAST cars around here are on them too. The speed rating thing is for sustained speeds, not for short bursts like in drag racing.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#1599356
03/28/14 05:13 PM
03/28/14 05:13 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
My buddy would get on me for running the street tire rated at 112mph also and I told him the same thing thats its only for 10 seconds at a time not a long drive. Ron
[Re: 383man]
#1599357
03/28/14 06:07 PM
03/28/14 06:07 PM
Posts: 3,433 Toronto
mshred
Toronto
Running those non speed rated tires is an accident waiting to happen....just because it has happened to you or someone you know yet, doesn't mean it won't happen. Those tires were designed for lighter cars, sustained speeds or not. I am an idiot for ever running them for one season, which is why they came off very soon after so obviously you know my opinion
[Re: mshred]
#1599358
03/28/14 06:10 PM
03/28/14 06:10 PM
383man
Balt. Md
Running those non speed rated tires is an accident waiting to happen....just because it has not happened to you or someone you know yet, doesn't mean it won't happen.
Fixed it.
[Re: 383man]
#1599359
03/28/14 06:12 PM
03/28/14 06:12 PM
mshred
Toronto
Fixed it.
LOL thanks
Also, M&H makes a nice speed rated radial front runner that is imo better looking then the flame tread of the sportsman S/R radial...not sure what sizes in terms of height they have
[Re: SpareParts]
#1599362
03/28/14 06:18 PM
03/28/14 06:18 PM
Posts: 68 Detroit, MI
RawnDart
Detroit, MI
MT sportsman fronts
Same here. 26x6
[Re: RawnDart]
#1599363
03/28/14 06:32 PM
03/28/14 06:32 PM
Posts: 2,703 Mohnton, Pa
DodgeCharger
Mohnton, Pa
I run the MT Sportsman S/T Radials. They look like BFG radial T/A's. They are a good tire but I don't know if they come in a size as small as you are looking for.
I like to get a front tire as close to as tall as the rear as possible. I think it help weight transfer and it does help with ground clearance.
[Re: RawnDart]
#1599364
03/28/14 06:35 PM
03/28/14 06:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
MT sportsman fronts
Same here. 26x6
I'm looking at the sportsman for the spare set of tires for racing.. I like my road racing type tire for the street.. they handle very well but are a BIT wide for the track
