Going racing again.. slicks vs drag radials
#1599109
03/27/14 11:35 AM
03/27/14 11:35 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I plan on racing again but still have a few details to tidy up and need an opinion.
Normally when I raced my GTX I would slap on the Welds with M/T 10.5" slicks and go at it. But the car no longer has long studs and my slicks are several years old (but only had 6-8 passes on them) so I'm left with some choices.
1) I have access to a set of 15" x 8 Ramcharger rims, slap some new drag radials on and no worries about the wheel studs.
2) Pickup a set of spare axles, slap some long studs on and swap them out as needed. Was even considering a new set of Yukon axles with green bearings, Cass has them for $300 a pair I think.
Odds are the slicks will have to be replaced too even though they were bagged and in climate controlled storage but won't cost me nothing to make a few passes with them and assess.
Car has a 440 auto with 8.75, when the car had a stick in it on slicks it ran 11.2 at 124 mph with a 1.75 ST boiling the slicks. Stock "hemi" bars up front with XHD leafs out back and a snubber.
I'm thinking with the auto, some 4:10's out back instead of 4:56's and a good hook it will finally been in the 10's even though both car and owner has put on a few pounds since last outing.
I have read some of the pro's and cons between slicks vs the radials. The car "walking around the track" during a pass doesn't bother me a lick and is something I'm use too so that isn't a strike for me against the slicks.
The radials seem to be less forgiving about track prep though.
Thoughts? Maybe even another option I have not considered?
Almost time to make some smoke, been too long.
"I think its got a hemi"
Re: Going racing again.. slicks vs drag radials
[Re: gdonovan]
#1599110
03/27/14 11:47 AM
03/27/14 11:47 AM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
I don't have my rule book in front of me, but I believe the after market axles are required as well as the long wheels studs...
And many on here will praise the drag radials, I for one do not like them. They have tread on them, the tire pressure is very touchy on them, and when they do spin, its not a little, they just go up in smoke...
Slicks are more consistant, less touchy on pressure, and for their width, they have more surface contact. Also, they flex the sidewall at the hit, often helping the suspension find the grip needed...Can't go flexing the sidewall on a radial...
[Re: Dragula]
#1599111
03/27/14 11:58 AM
03/27/14 11:58 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
The radials will be faster, but not as forgiving on a marginally prepped track. If your track isn't typically prepped good, or if your car isn't set up to transfer weight well, then I'd go w/ a slick. Quote:
Why not?
[Re: gdonovan]
#1599113
03/27/14 01:46 PM
03/27/14 01:46 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I mostly run test & tunes but I still have stock axles. I plan to upgrade when I can but cash is tight with me living on disability and thats why I dont race much. But none of the tracks have ever said anything to me about my stock axles. I use the Hoosier 30 x 9 radial slick as no one makes a 30 x 9 drag radial which is the size I like for my stock wheelwells. But they seem to hook fine for me most of the time at most tracks. I honestly did not notice any difference on how consistent the car hooks when I went to radial slicks and they do handle very nice since I use a radial street tire up front. I was using Hoosier QTP tires which are a bias tire. Ron
[Re: racerhog]
#1599115
03/27/14 02:09 PM
03/27/14 02:09 PM
Posts: 5,169 CT
GTX MATT
CT
Gary I would go with the real slicks if you really want that 10 second slip. Are you opposed to putting long wheel studs back in? You could do it the bootleg way with a lug nut, I just did it last weekend. Any reason you can't leave them in all the time?
Also, I know you have a T ram, but wtf is the rest of your build to trap 124?
You going to LVD or NED?
[Re: GTX MATT]
#1599116
03/27/14 02:26 PM
03/27/14 02:26 PM
gdonovan
Oakdale CT
Yes since the car is primarily going to see street use and changing tires with long studs is a pain in the ass. I'd rather swap axles out (5 nuts on each side and done) then run on the street with long studs sticking out my 15 x 8 Rallyes.
I don't plan to take the car to the track that often so swapping axles time to time is no hardship.
I had a trick set of lug nuts (wink, wink) but stopped running them when I found out I cracked two. One expanded so bad had to drive it out the rim with a punch. Not worth the risk, to me or the guy in the other lane.
30 over 11:1 440 with .590 cam, McCandless ported 452 heads with oversize valves, titanium retainers, battleship steel springs, maxi rocker gear and 2" Hooker supercomp headers at the time. The hookers have been replaced with a smaller tube header and there is an auto in it now. With 3:23's the car is fun as hell to drive, with the 4:10's I suspect my street tires are going to be severely abused.
I'll have to do some fine tuning once I'm at the track but I'm sure with some tweaking of the timing and jets it will be at 100% again.
The Valley, I find that they much nicer to people who have gone to the trouble of driving all the way from CT.
[Re: gdonovan]
#1599117
03/27/14 02:52 PM
03/27/14 02:52 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
The slick will be much more repeatable. I have 275/60 radials on my car, rancho's, 3.23 gear, and cal tracks. On the same day I had it go 1.50 60ft one weekend, and wouldn't hook again for 7 more passes the next weekend when I finally had the power turned down so much it only went 1.68 60ft. As mentioned... when they hook... they hook. But if they spin... it's all over. https://www.youtube.com/watch?v=pGjej81qIDoThat being said... I just spent $1,500 on shocks trying to make the radials work... ![](/ubbthreads/images/graemlins/smilie_help.gif)
[Re: Sport440]
#1599121
03/27/14 07:22 PM
03/27/14 07:22 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
The track I normally run on is prepped to the max. I run faster on the drag radial every pass. I went from Hoosier Q.T.P. 28 x 14.40 x 15 to 275-60-15 Drag radial and ran my best 60' ever. I now went to 325-50-15 and they hook great at the track not so great on the street. The drag radials seem to drive alot better on the street and you dont get any of that back end sway going down the track.
67' charger 499 RB
10.57 at 127
[Re: an8sec70cuda]
#1599122
03/27/14 10:00 PM
03/27/14 10:00 PM
Dragula
Why not?
Well Obviously you can, but when the side wall goes, they are junk regaurdless of tread depth...
[Re: 1967dartgt]
#1599129
03/28/14 12:56 AM
03/28/14 12:56 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
If you've already got a set of slicks, I'd use them and see how they do. B-Body's transfer weight pretty effectively when properly set up, and generally hook pretty good on a radial. My guess is you'd be faster on a radial, and ultimately that would be your best setup, as long as you have a decently prepped track.
[Re: StealthWedge67]
#1599130
03/28/14 05:26 AM
03/28/14 05:26 AM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
slightly off track with the original post question, but I saw a few questions which I thought I would help clarify. Aftermarket axles are required by NHRA if you are running a spool or run faster than 10.99. Quote:
2:11 REAR END Welded spider gear rear ends prohibited in all classes. Four-wheel drive permitted per class requirements. Aftermarket axles and axle-retention device mandatory on Top Fuel, Funny Car, Pro Stock, Top Alcohol Dragster, Top Alcohol Funny Car, Comp, Super Comp, Super Gas, Super Street, and 10.99 or quicker E.T. cars; also mandatory on any car (regardless of class or E.T.) with a spool.
Long wheel studs are not a requirement for any class, but the wheel stud MUST extend past the face of the wheel (and washer if used) by at least the diameter of the stud. (1/2" stud by 1/2", 5/8" stud by 5/8", and in the case of some GM 7/16" studs by 7/16").
5:2 WHEELS Hubcaps must be removed for inspectors, who will check for loose lugs, cracked wheels, worn or oversize lug holes, and condition of spindles, axle nuts, cotter pins, etc. Snap-on hubcaps are prohibited on any class car. The use of “spinner” style wheels or any wheel design that incorporates movable pieces while vehicle is in motion or stationary are prohibited. Each car in competition must be equipped with automotive-type wheels with a minimum 12 inches of diameter unless Class Requirements stipulate otherwise. Motorcycle wheels or lightweight automotive wire wheels must be equipped with .100-inch minimum diameter steel spokes, properly cross-laced to provide maximum strength. All spoke holes in rim and hub must be laced. Omissions to lighten wheels prohibited. The thread engagement on all wheel studs to the lug nut, or lug bolts to wheel hubs, must be equivalent to or greater than the diameter of the stud/bolt. Length of the stud/bolt does not determine permissibility. (Example: A 7/16-inch stud must be thoroughly engaged through the threads in the hex portion of the lug a minimum of 7/16-inch.) Wheel spacer permitted. Spacer to be either hub-centric or lugcentric and must fit with minimal clearance to retain concentricity. The wheel spacer must not reduce the minimum permitted thread engagement below the limits established by fastener diameter. (See example as stated above.) No stacking of wheel spacers allowed.Maximum rim width on any car: 16 inches. No rear wheel discs or covers permitted in any category. Top Fuel and Funny Car rear wheels must meet SFI Spec 15.4. Pro Stock, Top Alcohol Dragster, Top Alcohol Funny Car, and Pro Modified (Comp) must meet a minimum of SFI Spec 15.1
[Re: gdonovan]
#1599133
03/28/14 09:16 AM
03/28/14 09:16 AM
an8sec70cuda
Yes, I'm aware that on a radial I'd have a fast mph but would rather have the ET.
I raced the Duster at LV 2 years ago and it would spin the slicks out the hole, track prep is a concern. They were running a bunch of street cars too so I can't blame the track too much.
The radial WILL ET and most likely MPH better. Radials don't grow nearly as much as a slick, so the MPH may or may not be better, but it'll definitely ET better on the radial when it hooks. Like I said before, if the track isn't typically prepped very well when you go, I'd suggest a slick.
Dragula...any decently fast car on radials is wrinkling the sidewall just like a slick...and wears them out accordingly, just like 67dartGT said. No different than a slick. The day that pic I posted earlier was taken, I made 7 passes to win my first bracket race...went 1.32-1.34 sixty foot every pass running 9.60s.
[Re: an8sec70cuda]
#1599134
03/28/14 11:51 AM
03/28/14 11:51 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I would run a slick in your case. It takes a lot to get radials to work right and you don't race near enough to do that. A slick would work better for you, but a radial would be a faster tire both et and mph.
Brett Miller W9 cnc'd heads STR Chassis fabraction
