Page 2 of 5 1 2 3 4 5
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594507
03/18/14 09:48 AM
03/18/14 09:48 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
get a reman master for a 70 C body with disc/drums.They are all we run.Pedal is always right there.That and make sure the rears are adjusted up.Rocky
Chrysler Firepower
Re: Brake pedal "meh" thinking about braided lines. [Re: therocks] #1594508
03/18/14 09:52 AM
03/18/14 09:52 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Rears are spot on.
Tonight I may bypass the calipers by blocking the lines at the bango fittings. If the pedal still has a lot of "travel" then it has to be the two flex lines, if not I'll have to look close at the calipers and pads.
"I think its got a hemi"
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594509
03/18/14 11:01 AM
03/18/14 11:01 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
i had about an inch more pedal travel than i was happy with on my last conversion to discs.no amount of bleeding or adjustment helped but i did have good braking.
continued driving over the first few weeks brought the pedal up to a satisfactory position.
i suspect that with use,the pistons worked there way closer and retracted less but don't know for sure.
a pedal ratio of 1:6 with a 1" master,2" of pedal travel would not move a couple of 2.75" caliper pistons very far
Re: Brake pedal "meh" thinking about braided lines. [Re: can.al] #1594510
03/18/14 11:31 AM
03/18/14 11:31 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I'm tempted to do just that but it will cost me nothing but a little time to narrow down the possible reasons.
I still think $60 isn't a bad investment for the braided hoses.
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594511
03/18/14 12:56 PM
03/18/14 12:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I suggest you look into what the factory combination valve does before you dismiss having one or think just putting an aftermarket adjustable proportioning valve in is the same.
The '70 GTX drum/drum unit is just a distribution block.
A disc brake car has a prop valve that regulates how much pressure the rear sees. For this application the current block is just fine, the problem is I'm not getting enough force on the FRONTS, not too much on the rears.
I am not talking about your current problems, other than that problem of thinking you do not need a factory style combination valve. I highly suggest you read up on what they do and why, you're a smart fellow and unlike some here ought to be able to understand it's function.
Don't be the exception.
Re: Brake pedal "meh" thinking about braided lines. [Re: Supercuda] #1594512
03/18/14 01:16 PM
03/18/14 01:16 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I have, there are several threads on the subject.
https://board.moparts.org/ubbthreads/show...amp;Search=true
Unless I'm locking up the rear brakes (which I'm not at the moment, they are deliberately undersize at 10") a distribution block is just fine. It isn't the cause of the current issue.
Now if I was locking up the rears all the time I would agree with you.
BTW as an aside? My Reliant doesn't even have a valve, no rear brakes! With 75 pounds on each rear tire they would just lock up instantly. The master on that car does the left and right wheel separately.
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594513
03/18/14 01:18 PM
03/18/14 01:18 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Did you confirm the master cylinder and caliper bore sizes?
If you installed '76 and newer slider calipers (2.75" bore), coupled with a '73-'75 A-body POWER (15/16" bore) master cylinder, you will experience long, light pedal travel.
Re: Brake pedal "meh" thinking about braided lines. [Re: DoctorDiff] #1594514
03/18/14 01:33 PM
03/18/14 01:33 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
The master I'm working off the part number that was ordered for my '74 Duster with disc brakes, same for the calipers.
The master is *suppose* to be 1 1/32" and worked fine with the drum brakes. It takes a stout leg to operate a power master cylinder without a booster but I'm use to a clutch pedal with big spring rates so not a big deal to me.
The pedal feels solid, not light at all just spongy. Almost like the pedal linkage is flexing but that has already been eliminated by turning the line lock on.
I'll take some measurements tonight if you like, have to check the casting for numbers though since the master is secured from the inside.
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594515
03/18/14 02:09 PM
03/18/14 02:09 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Seems like your hung up on installing braided lines. Just do it and then you can go about fixing the original problem.
Re: Brake pedal "meh" thinking about braided lines. [Re: stumpy] #1594516
03/18/14 02:17 PM
03/18/14 02:17 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Not necessarily, it does seem logical that they would flex much less than factory rubber lines and that does *feel like* what the problem is. I'll know more tonight when I block the calipers off.
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594517
03/18/14 02:24 PM
03/18/14 02:24 PM
GEORGIA
barracuda7199 Offline
GEORGIA
A new aluminum 1 1/32 master cylinder with adapter from doctor diff fixed your same problem on my car. Stops far better than it ever has and has the best pedal it ever had. His masters are going on all our cars from here on out.
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594518
03/18/14 04:15 PM
03/18/14 04:15 PM
AndyF Offline
AndyF  Offline
I'd be surprised if you feel a difference between OEM hoses and SST hoses.
The main reason to run SST hoses is either looks, or because you can't find a stock hose that fits/works for a custom brake setup.
SST hoses aren't really a performance upgrade even though they look like they are.
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594519
03/18/14 05:24 PM
03/18/14 05:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I am suspecting that you may have air in the front (disc) portion of the system or master. WHY ???? you indicate that the pedal is rock hard with little movement when the line lock is engaged which effectively blocks the front lines off.
Re: Brake pedal "meh" thinking about braided lines. [Re: TJP] #1594520
03/18/14 05:41 PM
03/18/14 05:41 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
That was my first thought which is why I vacuum bled them twice, had a helper bled them twice and even jacked up the car on one side to raise the caliper higher. And when I say vacuum pump, I mean a $250 electric pump with clear reservoir and lines I use just for bleeding brakes when help isn't about, it does a superb job.
Not my first rodeo, I have done thousands of brake jobs over the last 30 years professionally. Air was the first thing I thought of and did my best to eliminate it as a possibility.
Usually if you have air in the system you can pump the pedal and it will come up, this doesn't act that way.
The best description is new pads on a beat grooved rotor if you have ever done it. Its a spongy "not right" feeling.
Heading out to the garage now after a java infusion, pics later.
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594521
03/18/14 06:51 PM
03/18/14 06:51 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Pulled the pads off and it looks like they had uneven contact with the rotor, will head out to take a pic.
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594522
03/18/14 07:03 PM
03/18/14 07:03 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
You can clearly see three spots on the pads where they were not making full contact. Either the pads were not flat out of the box or the caliper and or slides are not totally square to the rotor face.
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594523
03/18/14 07:28 PM
03/18/14 07:28 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Can you seal off the top of the master and then put a vacuum on the reservoir? Any air hiding in the system will have no choice but to go to the top.
Also if you vac it out and close the valve you can see if it will hold a vacuum. If it won't you will have found out why your pedal is spongy. Then you get the fun of figuring out which seal can hold fluid under pressure but not air from the lack of it.
Kevin
Re: Brake pedal "meh" thinking about braided lines. [Re: Twostick] #1594524
03/18/14 08:07 PM
03/18/14 08:07 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
So I'm digging around further and here is what I found- When there is two chunks of steel in the calipers I can clearly see the pistons move out 1/8" and then back in about the same amount when the pedal is released.
This jarred a memory- Is there not suppose to be a residual check valve built into the master cylinder that leaves a pound or three of pressure in the lines for disc brakes? Or do I have it backwards, for drum brakes?
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594525
03/18/14 09:00 PM
03/18/14 09:00 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
In for the night, I can't get a good seal on the banjo fittings. Try again tomorrow..
Re: Brake pedal "meh" thinking about braided lines. [Re: gdonovan] #1594526
03/18/14 10:20 PM
03/18/14 10:20 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
no check or residual valves for discs...
