Re: Brake pedal "meh" thinking about braided lines.
[Re: gdonovan]
#1594507
03/18/14 09:48 AM
03/18/14 09:48 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
get a reman master for a 70 C body with disc/drums.They are all we run.Pedal is always right there.That and make sure the rears are adjusted up.Rocky
Chrysler Firepower
[Re: gdonovan]
#1594521
03/18/14 06:51 PM
03/18/14 06:51 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Pulled the pads off and it looks like they had uneven contact with the rotor, will head out to take a pic.
"I think its got a hemi"
[Re: gdonovan]
#1594522
03/18/14 07:03 PM
03/18/14 07:03 PM
gdonovan
Oakdale CT
You can clearly see three spots on the pads where they were not making full contact. Either the pads were not flat out of the box or the caliper and or slides are not totally square to the rotor face.
[Re: Twostick]
#1594524
03/18/14 08:07 PM
03/18/14 08:07 PM
gdonovan
Oakdale CT
So I'm digging around further and here is what I found- When there is two chunks of steel in the calipers I can clearly see the pistons move out 1/8" and then back in about the same amount when the pedal is released.
This jarred a memory- Is there not suppose to be a residual check valve built into the master cylinder that leaves a pound or three of pressure in the lines for disc brakes? Or do I have it backwards, for drum brakes?
[Re: gdonovan]
#1594525
03/18/14 09:00 PM
03/18/14 09:00 PM
gdonovan
Oakdale CT
In for the night, I can't get a good seal on the banjo fittings. Try again tomorrow..
[Re: gdonovan]
#1594526
03/18/14 10:20 PM
03/18/14 10:20 PM
Posts: 1,274 Ontario.Canada
can.al
Ontario.Canada
no check or residual valves for discs...
