Re: How fast with a stock 8 3/4 [Re: Quicktree] #1593893
03/17/14 02:00 PM
03/17/14 02:00 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
8 3/4's are super strong and I wouldn't worry about it. I would recomend axles, gears and spool, back brace wouldn't hurt either.
67' charger 499 RB 10.57 at 127
Re: How fast with a stock 8 3/4 [Re: racerx] #1593894
03/17/14 02:20 PM
03/17/14 02:20 PM
NC
O
onefastindy Offline
onefastindy  Offline
O
NC
440 with 440-1's and 150 shot.
Re: How fast with a stock 8 3/4 [Re: onefastindy] #1593895
03/17/14 02:28 PM
03/17/14 02:28 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
How many passes on it and at what weight. Also do you use a trans brake?
Re: How fast with a stock 8 3/4 [Re: roadhazard] #1593896
03/17/14 03:22 PM
03/17/14 03:22 PM
NC
O
onefastindy Offline
onefastindy  Offline
O
NC
Car weighs 3260. It's a foot brake car. Stock stuff lasted about 25 passes with that 440. In that pic it had a 1.29 60 ft.
Re: How fast with a stock 8 3/4 [Re: onefastindy] #1593897
03/17/14 06:30 PM
03/17/14 06:30 PM
P
Paul_Fancsali Offline
P
The worst I broke on a 8.75 is a carrier bearing that turned into a metal paste. I now use BCA when I can Broke with a 340 4spd and 9inch slicks car ran like crazy until it locked up
Re: How fast with a stock 8 3/4 [Re: Thumperdart] #1593898
03/17/14 09:14 PM
03/17/14 09:14 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I've been 5.80's in the 1/8 with 1.29 60ft with stock axles and sure grip before it twisted the housing. Now it's got a new one that's back braced with moser axles and spool with billet caps.
Tell us more.................
Thumper are u trying to stir the pot?lol
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: How fast with a stock 8 3/4 [Re: bdaz smblk] #1593899
03/17/14 09:39 PM
03/17/14 09:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No sir, I just trip on the fact that some 11-12 second cars kill em and these guy`s and myself run 9`s and faster and they live.........But as Quick pointed out, guess I`m not totally hookin.............
Re: How fast with a stock 8 3/4 [Re: onefastindy] #1593900
03/17/14 11:19 PM
03/17/14 11:19 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Footbreaken a 3200 lb.car witha 1.29 60's is hookin
Re: How fast with a stock 8 3/4 [Re: Thumperdart] #1593901
03/17/14 11:27 PM
03/17/14 11:27 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
No sir, I just trip on the fact that some 11-12 second cars kill em and these guy`s and myself run 9`s and faster and they live.........But as Quick pointed out, guess I`m not totally hooking.............
Thump. doesn't your car has the MW cap on it?I think the op.was referring to a stock rear.With that said,i think that the reason so many 8.75's or in the 9's,8's along with other modification that they do to these rearends
Re: How fast with a stock 8 3/4 [Re: racerx] #1593902
03/17/14 11:30 PM
03/17/14 11:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I dream of those #`s.............
Re: How fast with a stock 8 3/4 [Re: Thumperdart] #1593903
03/18/14 01:15 AM
03/18/14 01:15 AM
NC
O
onefastindy Offline
onefastindy  Offline
O
NC
Thanks.. I've spent a lot of time and money to make it work right. I've only ran it in 1/4 mile a few times. It went low 9's and still footbraking. Now it's time to pass it on to somebody else.
Re: How fast with a stock 8 3/4 [Re: onefastindy] #1593904
03/18/14 02:43 AM
03/18/14 02:43 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ll take it..................Thankxxx...........
Re: How fast with a stock 8 3/4 [Re: Thumperdart] #1593905
03/18/14 12:09 PM
03/18/14 12:09 PM
NC
O
onefastindy Offline
onefastindy  Offline
O
NC
It's on here for sale. I'm sure it would look good on the west coast...
Re: How fast with a stock 8 3/4 [Re: onefastindy] #1593906
03/18/14 10:27 PM
03/18/14 10:27 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Hi 6's in the 1/8. Anything past 6.80 is gambling on stock everything.
I went 6.00 with my 8&3/4. But the trans break is the week link finder.
Re: How fast with a stock 8 3/4 [Re: FastmOp] #1593907
03/18/14 10:54 PM
03/18/14 10:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been using a trans brake from day one.. like I
said I got over 600 passes on a stock center.. even
with the cone style posi.. all with the trans brake
but my car is lite... each pass was from 5200 rpm
or up launches...weight tends to kill them
Re: How fast with a stock 8 3/4 [Re: MR_P_BODY] #1593908
03/18/14 11:13 PM
03/18/14 11:13 PM
dogdays Offline
dogdays  Offline
To the OP:
The best place for you to find a Dana 60 in Sweden might be a scrapyard that specializes in US Military vehicles. I'm thinking Germany.
The Dana 60 is a 3/4 ton truck rear end, it was never meant to go under a car. But it was in the parts chain when Mopar engineers decided they needed something stronger than an 8 3/4.
In a 3/4 ton or even a 1-ton vehicle the rear will have full floating 8 lug hubs. The idea is to cut the axle ends off and weld on new ends like 8 3/4 ends so you can use your existing brakes. Then you buy custom axles.
Doctor Diff would be the guy I'd talk to, he would be the most helpful, in my opinion. He could walk you through the steps and help you get the right length axles.
Most all Dana 60s in military vehicles will have 4.10 or numerically higher gears and limited slip differentials.
Good Luck!
R.
Re: How fast with a stock 8 3/4 [Re: MR_P_BODY] #1593909
03/18/14 11:32 PM
03/18/14 11:32 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We ran 9.80s all day long with a stock 8 3/4 ! And I do mean stock ! My best 60ft was 1.29 with it, we were close to 3500lbs race ready ! I did that for a year, then put a spool back brace axles in it, then ran it for another year and switched to the strange 60 from doc diff ! Car went just as quick until I broke the block
Re: How fast with a stock 8 3/4 [Re: 70dusterjohn] #1593910
03/19/14 10:25 AM
03/19/14 10:25 AM
an8sec70cuda Offline
I broke something in the stock sure-grip running 11.40s at 3700#. Found twisted axle splines when I took it apart.
Changed to a spool w/ 35 spline axles and all was good until I started running mid 10s at the same 3700#. It took the teeth off the ring and pinion. Car never 60 footed all that well (1.49-1.51) w/ a best of 10.40 at 129 mph.
Once that happened I put a Dana in it. That was in 2003...haven't touched it since.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How fast with a stock 8 3/4 [Re: an8sec70cuda] #1593911
03/19/14 10:51 AM
03/19/14 10:51 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Wish i knew at what weight kills them as i broke one bout 20 years ago on the street.Tore it apart and it was the spider gears,Went to a spool 33 spline with the street/stripe axles broke an axle,upgraded to a 35 spline/race axles all was good ran with that setup for about 10 years never broke a gear or anything(wish we had a wood knocking icon )but went to a different gear(4.56 to 4.10)which kind of raising my worried factor cause the 4.10 ring gear seems a little thin we shall see.
