Race Brake Weight Difference Rear Drum Swap #1593771
03/16/14 12:36 PM
03/16/14 12:36 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Going from 10x2.5 to race disc anybody have #s?
Re: Race Brake Weight Difference Rear Drum Swap [Re: Scamp408] #1593772
03/16/14 12:51 PM
03/16/14 12:51 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have a set of 11x3 out in the garage I just took off the race car & replaced with Willwoods...If I had a scale I could tell you.
Re: Race Brake Weight Difference Rear Drum Swap [Re: Scamp408] #1593773
03/16/14 01:03 PM
03/16/14 01:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you a foot braker... drums have a better holding
ability over disc... but the disc have better stopping
ability
Re: Race Brake Weight Difference Rear Drum Swap [Re: MR_P_BODY] #1593774
03/16/14 03:18 PM
03/16/14 03:18 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Yes foot brk . Just wondering worth the 550.00 or not for me as far as weight an ET.
Re: Race Brake Weight Difference Rear Drum Swap [Re: Scamp408] #1593775
03/16/14 03:26 PM
03/16/14 03:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depending on how high you rev at the line the disc
MIGHT not hold.... on my Rampage I put drums on the
rear just because I will foot brake it(no trans brakes
allowed in the class I want to run)
Re: Race Brake Weight Difference Rear Drum Swap [Re: MR_P_BODY] #1593776
03/16/14 03:37 PM
03/16/14 03:37 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Didn't even think of that Im at like 1800-2000
Re: Race Brake Weight Difference Rear Drum Swap [Re: MR_P_BODY] #1593777
03/16/14 03:37 PM
03/16/14 03:37 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I had 11 inch drums on my 8 3/4, I switched to Wilwood discs , I weighed everything and came up with a 50 lb savings in weight. I have Wilwoods on the front also , I leave at 2,500 and have left as high as 3,000 and it holds fine on the line.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Race Brake Weight Difference Rear Drum Swap [Re: 11secdart] #1593778
03/16/14 05:35 PM
03/16/14 05:35 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Wow That's a huge difference.
Re: Race Brake Weight Difference Rear Drum Swap [Re: 11secdart] #1593779
03/16/14 06:29 PM
03/16/14 06:29 PM
Az
Crizila Offline
Crizila  Offline
Az
Aint callen ya a lier, but that number aint happening.
Fastest 300
Re: Race Brake Weight Difference Rear Drum Swap *DELETED* [Re: Crizila] #1593780
03/16/14 09:02 PM
03/16/14 09:02 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Post deleted by 11secdart
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Race Brake Weight Difference Rear Drum Swap [Re: 11secdart] #1593781
03/16/14 11:21 PM
03/16/14 11:21 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Race Brake Weight Difference Rear Drum Swap [Re: Crizila] #1593782
03/16/14 11:54 PM
03/16/14 11:54 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What's not happening? Leave rpm or weight savings?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Race Brake Weight Difference Rear Drum Swap [Re: 1967dartgt] #1593783
03/17/14 12:56 AM
03/17/14 12:56 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
THat weight savings should be close. My drums alone weight 40# add in the backing plates, pads, slave cyl, and springs, I could easily see 72# like 11sec dart states.
Could Wilwoods rotors/calipers/pads and brackets come in at 22#? Could be, aluminum calipers dont weight that much.
Re: Race Brake Weight Difference Rear Drum Swap [Re: 1967dartgt] #1593784
03/17/14 01:17 AM
03/17/14 01:17 AM
Az
Crizila Offline
Crizila  Offline
Az
The weight savings. Just seems like a lot.
Fastest 300
Re: Race Brake Weight Difference Rear Drum Swap [Re: Crizila] #1593785
03/17/14 01:25 AM
03/17/14 01:25 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I think maybe the key is the 11" drums, versus the 10.5" The 11" drums on my car, are the finned truck drums, which dwarf the original ones. Original poster: You might want to pay close attention, to how much the caliper mounting brkt, and hat thickness move the wheel around in the opening.
Re: Race Brake Weight Difference Rear Drum Swap [Re: Leigh] #1593786
03/17/14 06:54 PM
03/17/14 06:54 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
They were the big 11 inch ones, no further comment
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Race Brake Weight Difference Rear Drum Swap [Re: 11secdart] #1593787
03/17/14 07:03 PM
03/17/14 07:03 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I have the 10in anybody know the diff in weight.
Re: Race Brake Weight Difference Rear Drum Swap [Re: Scamp408] #1593788
03/17/14 07:55 PM
03/17/14 07:55 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Im thinking about 12# each if I remember right. So Your not going to see that 50# loss.
So you might see 30#, You will need to decide if thats worth $550 bucs to you. Your car is already a light weight, you wont see much ET gain at a 30# loss.
But lets say you need pads,drums and maybe some slave cyl,s and stuff. Financially that would make alot of sense to swap at this time.
For A ET gain alone, not worth it IMO
But you do have a SB. So "You guys" need all the help you can.
Re: Race Brake Weight Difference Rear Drum Swap [Re: Sport440] #1593789
03/17/14 08:50 PM
03/17/14 08:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Leave RPM depends on converter, gear ratio, master cylinder piston diameter, and pedal ratio. I can leave over 3200 with a pretty stout 572 with my Willwoods.
Doug
Re: Race Brake Weight Difference Rear Drum Swap [Re: Sport440] #1593790
03/18/14 07:46 AM
03/18/14 07:46 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Everything is 3 yr new in the so I am starting to thing its not worth it for the money.
