any info on a 1973 413 out of a motorhome #159345
11/30/08 06:50 PM
11/30/08 06:50 PM
fresno ca
wildfish72 Offline OP
mopar addict
mopar addict
fresno ca
ok guys i have looked around for more detailed info on this motor , im looking at what kind of compression it came with or how to calculate the compression , any good info will help alot. ive pulled the motor almost completely apart and found nothing good resalts on everything but the compression also someone told me it wont bolt up to my 727 in my cuda , i wanna say bs , let meknow please
Re: any info on a 1973 413 out of a motorhome [Re: wildfish72] #159346
11/30/08 06:53 PM
11/30/08 06:53 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Dont know about compression but think it'd be typical 8-8.5 to 1. I know if it came out of one of the big ones, it has different timing cover/water pump housing. Ran to big holes in the head. Shortblock will bolt to a regular 727. Used a few of them.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: any info on a 1973 413 out of a motorhome [Re: wildfish72] #159347
11/30/08 06:53 PM
11/30/08 06:53 PM
Kirkland, Washington
Pacnorthcuda Offline
Posted compression ratios for these vary between about 7.8 and 8.0. (very low) I had a 73 motorhome 440--you probably have "213" heads on it?
Should bolt right up to your 727--provided thats a BB 727 belhousing.
Re: any info on a 1973 413 out of a motorhome [Re: Pacnorthcuda] #159348
11/30/08 07:11 PM
11/30/08 07:11 PM
fresno ca
mopar addict
mopar addict
fresno ca
well the piston is 4.182 and at top dead center the piston hight is . 412 center and .215 out side its a dish piston
Re: any info on a 1973 413 out of a motorhome [Re: wildfish72] #159349
11/30/08 07:23 PM
11/30/08 07:23 PM
fresno ca
mopar addict
mopar addict
fresno ca
well if its a really low compression motor looks like it mite be a good turbo motor or nos motor , the bottom end is already forged steel , yeah it has those ugly [Edited by Moparts - Keep it clean] water pumper heads on it , when i picked the motor up the guy told me it was a 440 , i got for $200 and payed $90 in gas to git there and back , so when i found out it was a 413 i was much happier finding out it has all forged steel internals , i feel like i stole the motor from the guy
Re: any info on a 1973 413 out of a motorhome [Re: wildfish72] #159350
11/30/08 10:33 PM
11/30/08 10:33 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
The "real-world" compression ratio can be as low as 6.8 to one !! .... the heads are closed chambers BUT they are huge ... around 90 cc's.
It was a DAMN good motor for what it was designed for but it is as far from a HP motor as it can be.
Those UGLY heads ? ... are way WAY ahead of the competition "back-then". And those heads still are better than most truck/industrial/motorhome heads even made these days.
Re: any info on a 1973 413 out of a motorhome [Re: dOOc] #159351
11/30/08 11:04 PM
11/30/08 11:04 PM
fresno ca
mopar addict
mopar addict
fresno ca
im sure they are ,but now it has 906 heads on it with a edelbrock rpm performer cam , 440 1.6 ratio rockers , fluid dampner , and a tm7 intake with a 850 holley dp ,,,, i wanna git it fired , just wanna know the compression is on it .
Re: any info on a 1973 413 out of a motorhome [Re: wildfish72] #159352
11/30/08 11:14 PM
11/30/08 11:14 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
What head gaskets? .. bone stock 906's ?
Re: any info on a 1973 413 out of a motorhome [Re: dOOc] #159353
11/30/08 11:37 PM
11/30/08 11:37 PM
fresno ca
mopar addict
mopar addict
fresno ca
felpro , yes stock 906 heads
Re: any info on a 1973 413 out of a motorhome [Re: wildfish72] #159354
11/30/08 11:53 PM
11/30/08 11:53 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
The FP comp gaskets?
Re: any info on a 1973 413 out of a motorhome [Re: dOOc] #159355
11/30/08 11:59 PM
11/30/08 11:59 PM
fresno ca
mopar addict
mopar addict
fresno ca
Blue permatorque head gaskets
Re: any info on a 1973 413 out of a motorhome [Re: wildfish72] #159356
12/01/08 03:01 PM
12/01/08 03:01 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
What is the thickness ?
Re: any info on a 1973 413 out of a motorhome [Re: dOOc] #159357
12/01/08 09:19 PM
12/01/08 09:19 PM
fresno ca
mopar addict
mopar addict
fresno ca
.039
Re: any info on a 1973 413 out of a motorhome [Re: wildfish72] #159358
12/03/08 01:52 AM
12/03/08 01:52 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
Depending on the deck height of the block and pistons and the cc's of the heads(which could be as large as almost 90 cc's) ..... you could have LESS than 7 to one ...
Re: any info on a 1973 413 out of a motorhome [Re: dOOc] #159359
12/03/08 02:44 AM
12/03/08 02:44 AM
fresno ca
mopar addict
mopar addict
fresno ca
well 906 heads are 88 cc not 90 cc and also i mite put a set of 915 heads on it , i dont know yet , ,,,,,,, less then 7 , sounds alittle wrong to me , well i had my nitrous guy come over and do some hands on ,, and came out to be 8.266 compresson with 906 heads
Danger , Will Robinson!!!! [Re: wildfish72] #159360
12/03/08 10:52 AM
12/03/08 10:52 AM
dogdays Offline
dogdays  Offline
A real bad assumption has just been floated. 906 heads are NOT 88cc, some are, but they can be found anywhere from 88 (or lower) to 92 or so. Not that 2cc makes much if any difference on a 400 size cylinder.
If you were to get all the longtime engine builders on this board to recall every 906 head they ever cc'd I bet you would hear at least one "94".
A 915 should measure about 84cc.
Your mileage may vary!
R.
Re: any info on a 1973 413 out of a motorhome [Re: wildfish72] #159361
12/03/08 01:24 PM
12/03/08 01:24 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
88 or 90 cc's !! ... whatever !!! ... what you have here is a very possible fat-deck-height, a very thick head gasket and a HUGE dish in the piston.
8.27 compression ratio ? ...in-your-dreams !! ... Your nitrous-guy has sniffing waaaay tooo many fumes !!
Re: any info on a 1973 413 out of a motorhome [Re: dOOc] #159362
12/03/08 09:44 PM
12/03/08 09:44 PM
fresno ca
mopar addict
mopar addict
fresno ca
well he measured the cc with a plexi glass and water with a cc measureing setup , he also flowes heads , out , when i measured everything i was way off , becasue i use a strate edge and i measured from the top and not the bottom so i was waaaayyyyy off ,also the motor doesnt have stock pistons in it , it was rebuilt
