Small Block Engine Storage Cradle #159297
11/30/08 05:57 PM
11/30/08 05:57 PM
NY
old340dog Offline OP
NY
Does anyone make a reasonabley priced engine storage cradle with wheels for small block mopar? The universal one I had for my old small motor was a piece of junk.The motor did not fit right.I'd like to find one made for a small block mopar.I'm getting ready for my project and engine rebuild. Think it will easier to be able to move moor out of the way, instead of leaving it on engine hoist in the way.
old340dog
Re: Small Block Engine Storage Cradle [Re: old340dog] #159298
11/30/08 06:05 PM
11/30/08 06:05 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
use 2 2x4"s
and 2 2x10s
Make a craddle.
Re: Small Block Engine Storage Cradle [Re: old340dog] #159299
11/30/08 06:06 PM
11/30/08 06:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Try mancini racing.
I think member andyf makes them and mancini sells them????
http://www.arengineering.com/engine/motordolly/smallblock/motordolly.html
Re: Small Block Engine Storage Cradle [Re: Neil] #159300
11/30/08 06:10 PM
11/30/08 06:10 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
just wrap the mill in searan wrap, and hammer a couple nails. Do you have wood lying around? Home Depot has scraps that are cheap.
I used this for all kinds of builds.
Handles big blocks with no problems.
Less than 1/2 hr work.
here,
Re: Small Block Engine Storage Cradle [Re: mark7171] #159301
11/30/08 06:13 PM
11/30/08 06:13 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Re: Small Block Engine Storage Cradle [Re: mark7171] #159302
11/30/08 06:14 PM
11/30/08 06:14 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I built one just like that but put wheels on it.so it could be moved around
Re: Small Block Engine Storage Cradle [Re: mark7171] #159303
11/30/08 06:22 PM
11/30/08 06:22 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
They work good for Hemi-6's too (I have had a variety of engines on this same sort of base..works great for a low buck sort of thing.)
Re: Small Block Engine Storage Cradle [Re: OzHemi] #159304
11/30/08 06:32 PM
11/30/08 06:32 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I built the same type of cradle too. Works well for both BB and SB. The only difference is that I had access to 2 x 8" rectangular aluminum section, which I welded togeter and added wheels.
Re: Small Block Engine Storage Cradle [Re: OzHemi] #159305
11/30/08 07:26 PM
11/30/08 07:26 PM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
looks a heck of a lot safer than the one I bought from Summit!
B5 Challenger T/A
Re: Small Block Engine Storage Cradle [Re: KARLN] #159306
11/30/08 07:44 PM
11/30/08 07:44 PM
MO
cdp Offline
cdp  Offline
MO
buy one of these from Harbor Freight and add your rails. You can buy a 1000 lb capacity wood one for around $15-20. This one lists for $30
Re: Small Block Engine Storage Cradle [Re: old340dog] #159307
11/30/08 10:13 PM
11/30/08 10:13 PM
AndyF Offline
AndyF  Offline
Mancini Racing part number MRE10175.
Re: Small Block Engine Storage Cradle [Re: cdp] #159308
12/01/08 09:43 AM
12/01/08 09:43 AM
Winnipeg,Manitoba
cudablues Offline
cudablues  Offline
Winnipeg,Manitoba
I was thinking of using that Harber Frieght one and putting my K frame and suspension together on it,and small block,and sliding the whole thing under the Cuda when i install it.
Re: Small Block Engine Storage Cradle [Re: AndyF] #159309
12/01/08 09:53 AM
12/01/08 09:53 AM
NY usa
540challenger Offline
NY usa
I have that one at my house right now works great
Re: Small Block Engine Storage Cradle [Re: 540challenger] #159310
12/01/08 01:31 PM
12/01/08 01:31 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
The wooden ones work great, and I hope to build a couple more, but my only mistake was not gluing AND screwing.......they loosened up, over time. No biggee, I just like to do things right the first time........they are easy to make, and fairly cheap.
Re: Small Block Engine Storage Cradle [Re: old340dog] #159311
12/01/08 03:45 PM
12/01/08 03:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If your gonna use a wood dolley...( anyone ever noticed the metal frames with wheels sitting behind fast food restraunts that the buns come in on?) I have a about four of those covered with 2x12s from over the years... did I say that?
Anyway if I was gonna spend some $$ on a storage dolly, I would recomend buying a engine stand if you don't already have one. Might be real handy if you ever wanted to do some engine work. And you will someday.
I have two of them and could use another.
Re: Small Block Engine Storage Cradle [Re: Challenger 1] #159312
12/01/08 03:51 PM
12/01/08 03:51 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I bought an engine stand at a local Harbor Freight store and it was less then $50 with taxes. And its nice and strong too.
Re: Small Block Engine Storage Cradle [Re: cudablues] #159313
12/02/08 12:25 PM
12/02/08 12:25 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
I currently have my 360/727 sitting on one of those dollys. Make sure you lube the wheels first as the tend to be a bit dry and won't roll as well. I used lithium grease and have no problem moving it when it needs to be moved.
1979 Chrysler 300 1968 Barracuda project
Re: Small Block Engine Storage Cradle [Re: Challenger 1] #159314
12/02/08 12:28 PM
12/02/08 12:28 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
What did you do with four carts worth of buns ?
Re: Small Block Engine Storage Cradle [Re: OzHemi] #159315
12/02/08 12:32 PM
12/02/08 12:32 PM
Cincinnati, Ohio
Cincinnati, Ohio
I eat em and then
Re: Small Block Engine Storage Cradle [Re: Challenger 1] #159316
12/02/08 12:51 PM
12/02/08 12:51 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
