Re: Hotchkis 76 Dart Build
[Re: Consulier]
#1592890
03/19/14 06:12 PM
03/19/14 06:12 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
I like this solution better than the electric assist as part of a rack since you can retrofit to more cars. Interested to see how you mount this up under the dash, assuming you need to add some extra support to counter the forces from the assist unit (tie into the pedal box/dash/firewall)? Also cool since it removes some weight from the front of the car and one less belt driven accessory. How much current does one of these pull? - wait I found it. 80A. So other than packaging, the only upgrade would be a high amp alternator it looks like.
[Re: PHJ426]
#1592894
03/20/14 03:41 PM
03/20/14 03:41 PM
Posts: 256 USA
Consulier
USA
Is electric power assist steering better or just different?
It's definitely high tech either way.
I know my Ford Flex will parallel park itself with no driver input. I don't live in the city so I never use that feature of the electric power assist steering controls.
To me it's both. Different because you dump all the hydraulics and engine driven stuff. Better because it's adjustable (dial in the assistance), it fits and less weight.
There is still going to be a draw on the engine with the alternator, so not sure what the difference in HP would be between the two.
[Re: 72Swinger]
#1592897
03/20/14 04:44 PM
03/20/14 04:44 PM
Posts: 256 USA
Consulier
USA
6.4 cover must be different than 6.1, my alt clears good with lip removed off frame.
VVT cam moves it out 1/2 inch of something like that, so you can't use the 6.1 or earlier 5.7 alternators.
[Re: Consulier]
#1592898
03/20/14 08:51 PM
03/20/14 08:51 PM
Posts: 3,456 Fly Over States
PHJ426
Fly Over States
If you go by the physics of it....energy cannot be created or destroyed. ...only change forms. I see it as different and cool from my geek electrical / electronics / instrumentation background. Depending on how much you can tune it for the response you like and for the feedback you get is what I will be keeping a look out for. Are there other vendors selling controllers for this as well or is this option currently a one vendor deal?
Re: Hotchkis 76 Dart Build *Updated 20 March 2014
[Re: Pale_Roader]
#1592901
03/22/14 11:54 AM
03/22/14 11:54 AM
Posts: 256 USA
Consulier
USA
Neat build, but you guys sure aren't worried about weight are you...??? Starting with the heaviest A-body ever made and adding a LOT ov weight.
If FullMetalJacket wandered in here from the race-only section he'd have a stroke looking at those pictures...
Whats it going to weigh? Any idea?
Under 3000. It started as a Dart Lite, so far from the heaviest a body.
[Re: mopardamo]
#1592906
03/22/14 09:29 PM
03/22/14 09:29 PM
Posts: 256 USA
Consulier
USA
Hello,
Love the build. What were the factors that made you go with the GT-700 trans? Did you consider the T56 and if so why did you choose not to use it?
It started as a car that was all bolt together with no extra fab required. That has changed a bit. So, I already had the trans based on that.
Ultimately it didn't fit courtesy of the final engine position required for the headers and that required some tunnel mods. Since it was getting cut out anyway, might as well make it removable. Plus I needed good seat mounts and just tying something into the stock tunnel isn't very stong.
[Re: 72Swinger]
#1592907
03/22/14 09:36 PM
03/22/14 09:36 PM
Posts: 256 USA
Consulier
USA
Is this thing going to have glass panels Kevin?
Not to start. We'll see where the weight shakes out and if I need to put it on more of a diet.
Since it's a Dart Lite, the hood and decklid will only save about 40lbs.
[Re: Dan@Hotchkis]
#1592908
03/28/14 02:48 PM
03/28/14 02:48 PM
Posts: 2 Albuquerque, NM
perlhaqr
Albuquerque, NM
I think the cat is pretty much out of the bag as to Hotchkis building a 76 Dart for Kevin on this site. The guys working on the car are the same folks who assemble all of our components we sell as well. So I think it is time for some pictures!
A good roll cage will tie into the unibody structure in as many places as possible. Not only does this make the vehicle safer, but it dramatically increases the rigidity of the unibody, reducing chassis flex during hard cornering. Here you can see the installation of the A-pillar gussets that are critical for driver safety in the event of a roll over.
![](http://farm4.staticflickr.com/3729/11938646425_831fd10eb5_z.jpg)
The next step to reinforcing the front end was to tie these new bars into the upper shock mounts. Like the star-shaped mounts on the firewall, these mounts are fabricated out of 16-gauge sheet metal and are designed to disperse the tremendous forces the upper shock mounts will see during racing events.
![](http://farm4.staticflickr.com/3789/12209074593_21db6a7b64_z.jpg)
![](http://farm8.staticflickr.com/7424/12208881235_8ce8462153_z.jpg)
Now it was time to work on the bay bars that will tie the two shock towers together. Here is the finished product with the ends trimmed down for access to the bolts for easy removal:
![](http://farm3.staticflickr.com/2046/13092743754_ac05a7f6b3_c.jpg)
Well, dang. That's sure some amazingly pretty fabrication.
Please keep updating as you go along! ![](/ubbthreads/images/graemlins/laugh.gif)
