Re: Hemi Block Stampings Archive?
[Re: hemi-itis]
#1589989
03/09/14 12:56 AM
03/09/14 12:56 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I will be keeping a data base myself so emailing them to me (at bugframes@msn.com) would be fine, posting here is welcome as well. Here's an example of what I'd like to see (as much info as possible). MN4262904513(3or8?)76: Friday, August 15, 1969 (8-7-69 2 stamped above MN#) VIN: 0A107875 1970 Lynch Road Casting date: 11-18-68 Top Pad: WT 426 B
[Re: ScottSmith_Harms]
#1589998
03/10/14 01:45 AM
03/10/14 01:45 AM
Posts: 10,526 Chicago, Illinois
Devil
Chicago, Illinois
Here's another one (same casting date as yours Ryan!)
That's pretty cool. I know of a few other Hemi blocks lying around. I'll try to remember to document them better.
[Re: Triggerfish]
#1590004
03/11/14 12:18 AM
03/11/14 12:18 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
It had a 68 stamping on the back flange & Arruzza said it probably came from a 68 Hemi car.
If it did, it was definitely from a 68. That's the only year they did that.
#1590005
03/12/14 01:46 PM
03/12/14 01:46 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Scott, I found the folder & on the pad it's stamped MN4263360011 & over that looks to be stamped 12-16-67. Casting date is 10-3-66 and VIN looks to be 201381A8, but is hard to see. I have a print out of the photo & will have to scan it tonite when I get home.
