Dodge truck bolt patterns... #1589824
03/08/14 02:50 AM
03/08/14 02:50 AM
Halifax, N.S. Canada
Edison62 Offline OP
Edison62  Offline OP
I'm looking at buying an aftermarket set of wheels for my 1989 D-150. What is the bolt pattern on these? Is it the same as say 1970 Stock 15" Rallye rims? I"m sure I had a set of stock rallye's on my 1986 D-150 years ago.....
Tnx,
Bryan.
Don't be stupid.... it's not smart!
1970 Super Bee. Big blk 4 speed car.
1973 Dodge Dart Sport 340 4 speed car.
1985 Dodge Ram D-100 /6 auto. Original paint
1990 Dodge Ram D-150 V-6 5 Speed. Original paint
1995 Chrysler LHS V-6 auto. Original paint
2014 Ram 1500 R/T 5.7 Hemi...!
Re: Dodge truck bolt patterns... [Re: Edison62] #1589825
03/08/14 04:11 AM
03/08/14 04:11 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
5 X 5.5
I am truckless..
Re: Dodge truck bolt patterns... [Re: Edison62] #1589826
03/08/14 12:25 PM
03/08/14 12:25 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
See above
No
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Dodge truck bolt patterns... [Re: Edison62] #1589827
03/08/14 08:39 PM
03/08/14 08:39 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Tnx,
Bryan. [/quote
You had stock Ralleyes on a 84 down 2WD 85-up are same as your 89
Re: Dodge truck bolt patterns... [Re: BulletBob] #1589828
03/09/14 12:20 AM
03/09/14 12:20 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Should be 5.5" 5 lug. Same bolt pattern is used on the Furd trucks and Jeeps.
...FAFO...
Re: Dodge truck bolt patterns... [Re: skicker] #1589829
03/09/14 07:34 AM
03/09/14 07:34 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
5x5.5" was also used on the W100 up to 1974, then again 1980-up.
1984 was the last of the 5x4.5" D100s. I just put a set of 15x7 Cop wheels on my 84 D100.
OT, has anyone seen a D150 with the 8 lug pattern on both front and rear?
Re: Dodge truck bolt patterns... [Re: B5 Bee] #1589830
03/09/14 05:25 PM
03/09/14 05:25 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
No, but there are light duty D250s that use a semi floating 9.25 rear axle.
Re: Dodge truck bolt patterns... [Re: Soopernaut] #1589831
03/14/14 07:57 PM
03/14/14 07:57 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
My grandson has a 85 Dodge 1/2 ton short bed truck that we found in southern Indiana. It has the 4.5 bolt pattern on it. Maybe it was an early
truck for that year.
Frank
Re: Dodge truck bolt patterns... [Re: duster2] #1589832
03/14/14 08:22 PM
03/14/14 08:22 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Frank
2 wheel drive...
I am truckless..
Re: Dodge truck bolt patterns... [Re: 340SHORTY] #1589833
03/16/14 11:06 AM
03/16/14 11:06 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Frank
2 wheel drive...
That's a big 10-4
Frank
Re: Dodge truck bolt patterns... [Re: Edison62] #1589834
03/16/14 07:11 PM
03/16/14 07:11 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Tnx,
Bryan.
Stock 15x7" Rallyes would not clear the front brake calipers on my '84 D100. I ended up with 15x7" Cop wheels.
Re: Dodge truck bolt patterns... [Re: B5 Bee] #1589835
03/21/14 12:47 PM
03/21/14 12:47 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
That's because the factory 15 inch ralley wheel is 12.25 on the inside and a factory 15 inch cop wheel is 13.25 on the inside.
Frank
