Re: Have '00 Dodge Ram 2500 V10 auto, needs trans... [Re: ChrgrCuda] #1589382
03/21/14 07:56 PM
03/21/14 07:56 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Perhaps true, however why not replace it while you have it apart? Seems to me if you don't want a half ass overhaul why not do it right the first time? I guess I'm not big into removing and reinstalling transmissions.
If that's what u want to do that's fine but 99.9% of the time replacing the rear band is a waste of money unless you where having problems with rev slipping.
It is not a shifting band it is applied while you are sitting still.
I spent 27 years in the business and have done more of these units than most people have ever seen.
And most of the time the rear bands look like new.
There is a big difference in a true rebuilder that knows what is good and what is bad by looking at the parts and someone that is just a parts changer.
Absolutely true. I was a trans tech at a Dodge dealer for over 20 years. I've literally rebuilt thousands of these things and can count on the fingers of one hand the times a rear band needed to be replaced.
Perfect example why Chrysler has such a bad reputation regarding service departments. There is a reason why these technicians have rebuilt "thousands" of these transmissions......just replace what is absolutely necessary that will get the customer out of their hair.
Well my friend you have no idea who I am or what I do I spent 27 years in the business in the independent side so I never worked for a dealer
I can tell you I am a pro at what I do, I had customers that dealt with me for years and I have units out the that my customers drove for 100's of 1000's miles after I rebuilt there transmission.
I take pride in the work I do and would never charge for or recommend something that I would not do to my own vehicle.
So you can go ahead and change whatever parts you would like, as it is clear you have never done this on a daily basis as I have and are clearly not in the same league as a true tech.
Lol. No offense, but your "League" sounds to be in the Minors(maybe peewee) as I have never heard of you. But you keep on patting yourself on the back as you seem to be insecure.
To the OP. If a $40.00 rear band is going to break the bank for you then go right ahead
and use your original as one of these ass clowns have recommended. Times must
really be tough if these guys can't afford one. I most definitely wouldn't want
to travel a long distance in one of their "overhauled" transmissions without a cell phone....
Yeah well you don't live in central fl so why would you of heard of me and as far as patting myself on the back I don't need to there are a number of people on this forum that I have helped out so I don't give a sh$t what you think.
The fact that you think that all rev bands must be replaced shows how little you really know.
With that I am through talking to someone that has no clue
Have a nice day.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Have '00 Dodge Ram 2500 V10 auto, needs trans... [Re: dusturbd340W5] #1589383
03/22/14 12:01 AM
03/22/14 12:01 AM
CT
mrrandyj Offline
mrrandyj  Offline
CT
I agree with the others here who suggested that the rear band most likely doesn’t need to be replaced. It is very rare to see one that is worn or damaged. Chances are that the old, original band will give a infinite service life. Can you say that about a new replacement band that is most likely made out of the country?
As for the advice given in this thread that included name calling, that person’s attitude speaks for itself. People like that are usually the last ones that you want to take advice from. Just my
Re: Have '00 Dodge Ram 2500 V10 auto, needs trans... [Re: mrrandyj] #1589384
03/22/14 01:35 AM
03/22/14 01:35 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
OK, So I looked at Chrgrcuda's profile, his thoughts about replacing everything make sense, once you see he is an airplane mechanic. Big differences between working on a car, and working on a plane. I suspect there is little opportunity for "warranty" service on an airplane engine.
The automotive industry is held to a standard of being weary of replacing parts unnecessarily. A $40 part might not break the bank, but it might be very wasteful if that $40 part will not cause a problem over the life expectancy of the overhaul service. In the automotive industry, the standard set by law, is to replace only defective parts, and reuse parts that are still serviceable. Law suits have been filed and large settlements paid out by auto repair shops that have replaced parts that were not proven to be faulty.
To that point, there is also a huge difference in the quality of replacement parts between the two industries. Air craft quality standards are much higher then automotive standards. To assume a new replacement automotive part is going to be as good or a better quality part then what may have been in service, is expecting a lot these days. That makes the concept of replacing something "just because you're in there" somewhat questionable in the automotive industry.
This concept leads to a few quick questions for Mr Chrgrcuda. If you inspect the brakes on your car, do you always replace them "while you're in there" even if they are still good? Do you replace your tires every time to rotate them? My point is, sometimes replacing every part is not required if the part shows no sign of wear or age.
If you feel the need to replace everything you touch, go for it, but do not judge everyone else by the industry standard in which you work. I promise most of the world functions on a lot lower standard of nearly everything required of the airline industry. Frankly, I'm OK with that. I don't fly very often, but I like the idea that the last guy that worked on the plane I'm going to ride in, replace everything when he repaired something.
That said, the last time I checked, my car doesn't do well leaving the ground, even momentarily, without support (hoist or jack), without receiving severe trauma. I do not need to hold it to aircraft standards, I don't need to replace every part, nut, or bolt, every time I do a major overhaul. I live in the real automotive world, if the parts are not defective, I'm going to reuse them. Gene
Re: Have '00 Dodge Ram 2500 V10 auto, needs trans... [Re: poorboy] #1589385
03/22/14 03:54 AM
03/22/14 03:54 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Mr. Poorboy:
Good question and your points are valid regarding the two industries. However, pulling the wheel and inspecting brake shoes (especially rotors) is much less labor intensive when compared to pulling a transmission (especially in a 3/4 ton truck, 4x4, etc). I would not think one would simply pull a transmission out and disassemble for a routine inspection (unless a racecar), hence changing a $40.00 component "while you're in there."
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Have '00 Dodge Ram 2500 V10 auto, needs trans... [Re: ChrgrCuda] #1589386
03/22/14 04:10 AM
03/22/14 04:10 AM
San Francisco
dilvoy Offline
dilvoy  Offline
San Francisco
For the guys that don't want to change the low reverse band. I have Installed some B&M kits in some old 727's and always went and bought low reverse bands for the job, because the friction lining seemed to be made of some sort of paper and I was worried about damaging it when cleaning it. How do you clean it well without damaging it?
Re: Have '00 Dodge Ram 2500 V10 auto, needs trans... [Re: dilvoy] #1589387
03/22/14 09:24 AM
03/22/14 09:24 AM
Guitar Jones Online laugh2
The only thing that will damage it is water. Mineral spirits, gasoline, diesel fuel, lacquer thinner nothing harms it but water.
Re: Have '00 Dodge Ram 2500 V10 auto, needs trans... [Re: ChrgrCuda] #1589388
03/22/14 09:28 AM
03/22/14 09:28 AM
Nice try. I'll give you an "E" for effort. Sugar coat this turd however you like, however the customer is still inconvenienced by having to bring the vehicle back in AGAIN regardless if they have to pay or not. However I thank you for proving my point as to why Chrysler has pretty much the worst reputation in the industry when it comes to service. You just keep on replacing what is ABSOLUTELY is necessary. Another great reason as to why Chrysler has such a [Edited by Moparts - Family Friendly Site - Keep it clean] resale value as customers have experienced just what you described.
EVERY MANUFACTURER OPERATES THE SAME WAY not just Chrysler. Your outrage is misplaced.
Re: Have '00 Dodge Ram 2500 V10 auto, needs trans... [Re: Guitar Jones] #1589389
03/23/14 07:18 PM
03/23/14 07:18 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I used the original rear band in the 47RE I built for my 01 80K+ miles ago...(reason was that the hp/torque of my Cummins had been raised well beyond what the stock trans was designed to handle). Believe that core had 60k on it when I got it. I also reused the bearings, and all the planetary gears. Used the same pump, and did replace the input shaft and hub as the splines had some play in them, and of course, a new triple lock torque converter. Like a few others here.... I've been around the block a few times on these transmissions. You get to know what to look for, what gets changed, and what can be used again. Biggest reason for failure rate of those old trannys imho is the gawd awful amount of overlap they were programmed with from the factory..... and it was always funny how many of the clutch pack clearances were wrong. BTW a prolonged 1-2 shift I'd be looking pretty hard at the front band adjustment, and servo. Fwiw... I service my trans every 30k, my truck is a tool to pull my race trailer and boat.... and it does it well.
