Re: No spark from plug wires,possible problems?? #158811
12/04/08 03:41 PM
12/04/08 03:41 PM
Anonymous OP
Anonymous OP
it is erratic firing from the coil wire.It sparks when just beginning to crank and when you let go of the key and the sparks are very erratic in between,no distinct pattern.It may spark 3 times a 1 second apart then not spark again for another 4 seconds.
I had the ign. coil tested today at two different places and both checked it OK.It is a 73 Charger with electronic ign.
I had the ign. control module checked out it also was OK
The rotor button is turning.
How often is the coil SUPPOSED to fire??Thanks for the replys so far.
Re: No spark from plug wires,possible problems?? #158812
12/04/08 03:53 PM
12/04/08 03:53 PM
It would fire 8 times in (1) revolution of the rotor. Do you have another ECU handy that you could sub in & is your reluctor gap .008"
Re: No spark from plug wires,possible problems?? #158813
12/04/08 04:09 PM
12/04/08 04:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Should of mentioned this in the first post.
Your problem is an erractic spark, might be the coil wire. OR a bad electrical connection.
Don't be the exception.
Re: No spark from plug wires,possible problems?? [Re: Supercuda] #158814
12/04/08 04:35 PM
12/04/08 04:35 PM
Anonymous OP
Anonymous OP
or an incorrect reluctor to pickup gap or a bad pick up or a bad coil. whats the voltage at the coil in run
Re: No spark from plug wires,possible problems?? #158815
12/04/08 06:19 PM
12/04/08 06:19 PM
Anonymous OP
Anonymous OP
4.75v at the + side of the coil with the wires hooked up and key switched to ON
I disconnected the wire from the + side and it is 9.9V .Does this seem right??
Re: No spark from plug wires,possible problems?? #158816
12/04/08 06:33 PM
12/04/08 06:33 PM
Anonymous OP
Anonymous OP
no, its low. it should be around battery voltage when the wire is disconnected. youve got a low battery of a voltage drop somewhere
Re: No spark from plug wires,possible problems?? #158817
12/04/08 06:49 PM
12/04/08 06:49 PM
You're battery is good right? you might (1) run 12V fron the batt positive over to the coil positive and( for several seconds only) see if it'll start. (2) w key on you might hold the coil wire(the dist end) 1/4" from ground & jump the coil negative primary terminal to ground & see if you get a spark from the coil wire as you take the jumper off of its ground(repeatedly).
Re: No spark from plug wires,possible problems?? [Re: RapidRobert] #158818
12/04/08 07:47 PM
12/04/08 07:47 PM
Anonymous OP
Anonymous OP
12.5V at the battery:As you suggested,I ran a jumper from the battery positive to the coil positive , {12.5V}.With the same results.Sporatic sparks from the coil wire and NO sparking from plug wires.Needless to say,It didnt try to crank.
RapidRobert,On the second test,do I need to take the original wire off the negative primary terminal before I put on the jumper wire?
Re: No spark from plug wires,possible problems?? #158819
12/04/08 07:55 PM
12/04/08 07:55 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Silly question, but when you are checking for spark at the plugs, are yuo grounding them out to something?
Re: No spark from plug wires,possible problems?? #158820
12/04/08 08:00 PM
12/04/08 08:00 PM
the transistor is supposed to stop in the "open" position but to keep it simple. yes
Re: No spark from plug wires,possible problems?? [Re: RapidRobert] #158821
12/04/08 08:32 PM
12/04/08 08:32 PM
Anonymous OP
Anonymous OP
OK,I took off the original wire off the - side of the coil and hooked a jumper wire to it
I took the coil wire off the dist. cap and laid it 1/4 from metal bracket.
Turned key to RUN-Tapped other end of jumper wire to ground -creating sparks there at the end of the jumper..
NO sparking at the coil wire
So,what does this tell me?
Thanks for your help guys..and your patience!!!
Yeah,I was grounding the plugs.
Re: No spark from plug wires,possible problems?? #158822
12/04/08 08:50 PM
12/04/08 08:50 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Check the ballast resistor
NS1AAR
Re: No spark from plug wires,possible problems?? #158823
12/04/08 08:52 PM
12/04/08 08:52 PM
You hooked the jumper wire to the neg side of the coil not to the wire you took off the coil right? (sorry just checking). Allen I have more time than money(by far) & an abundunce of patience which explains why I am on here all the time . If you have a good/charged battery in there then I say bad coil! but one last double check jump 12V to the positive side of the coil & repeat your test of grounding the neg coil terminal & again have a FRESH battery
Re: No spark from plug wires,possible problems?? [Re: RapidRobert] #158824
12/04/08 10:45 PM
12/04/08 10:45 PM
Anonymous OP
Anonymous OP
yeah,I had the jumper on the neg. terminal
I tried it again with both pos. and neg. sides jumped.Still no regular spark from the coil secondary wire
Re: No spark from plug wires,possible problems?? #158825
12/04/08 11:15 PM
12/04/08 11:15 PM
your jumping 12V to the coil positive primary & grounding the coil negative primary terminal & pulling it away from ground intermittently & the coil secondary wire held 1/4" from another ground has no spark as you make/break the neg to ground. No spark = a deceased coil
Re: No spark from plug wires,possible problems?? #158826
12/05/08 06:24 PM
12/05/08 06:24 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Please tell me it isn't an orange control box you have.
If it will TRY to start when you STOP cranking it over, it sounds weird, but try another ECU that you KNOW works.
No spark while cranking, let the key go and it TRIES to fire sometimes? Is that it?
CrAzYMoPaRGuY
Re: No spark from plug wires,possible problems?? [Re: CrAzYMoPaRGuY] #158827
12/06/08 12:38 PM
12/06/08 12:38 PM
Anonymous OP
Anonymous OP
Yep,It was the coil.Finally got a chance to get one this morning.Its running now.Odd that a few days ago,I took mine off and took it to Oreillys and AutoZone and had it tested and they both said it was OK
Thanks RapidRobert and all you guys for the help
Allen
Re: No spark from plug wires,possible problems?? #158828
12/06/08 12:43 PM
12/06/08 12:43 PM
your welcome & for my contribution it was my pleasure. I can see why it threw you with it testing good & you were getting sparks there for awhile. Holler back when the next problem comes along
