Re: No spark from plug wires,possible problems??
#158811
12/04/08 03:41 PM
12/04/08 03:41 PM
it is erratic firing from the coil wire.It sparks when just beginning to crank and when you let go of the key and the sparks are very erratic in between,no distinct pattern.It may spark 3 times a 1 second apart then not spark again for another 4 seconds. I had the ign. coil tested today at two different places and both checked it OK.It is a 73 Charger with electronic ign. I had the ign. control module checked out it also was OK
The rotor button is turning. How often is the coil SUPPOSED to fire??Thanks for the replys so far.
[Re: Supercuda]
#158814
12/04/08 04:35 PM
12/04/08 04:35 PM
or an incorrect reluctor to pickup gap or a bad pick up or a bad coil. whats the voltage at the coil in run
#158815
12/04/08 06:19 PM
12/04/08 06:19 PM
4.75v at the + side of the coil with the wires hooked up and key switched to ON I disconnected the wire from the + side and it is 9.9V .Does this seem right??
#158816
12/04/08 06:33 PM
12/04/08 06:33 PM
no, its low. it should be around battery voltage when the wire is disconnected. youve got a low battery of a voltage drop somewhere
#158817
12/04/08 06:49 PM
12/04/08 06:49 PM
RapidRobert
You're battery is good right? you might (1) run 12V fron the batt positive over to the coil positive and( for several seconds only) see if it'll start. (2) w key on you might hold the coil wire(the dist end) 1/4" from ground & jump the coil negative primary terminal to ground & see if you get a spark from the coil wire as you take the jumper off of its ground(repeatedly).
[Re: RapidRobert]
#158818
12/04/08 07:47 PM
12/04/08 07:47 PM
12.5V at the battery:As you suggested,I ran a jumper from the battery positive to the coil positive , {12.5V}.With the same results.Sporatic sparks from the coil wire and NO sparking from plug wires.Needless to say,It didnt try to crank. RapidRobert,On the second test,do I need to take the original wire off the negative primary terminal before I put on the jumper wire?
#158819
12/04/08 07:55 PM
12/04/08 07:55 PM
Posts: 5,170 CT
GTX MATT
CT
Silly question, but when you are checking for spark at the plugs, are yuo grounding them out to something?
[Re: RapidRobert]
#158821
12/04/08 08:32 PM
12/04/08 08:32 PM
OK,I took off the original wire off the - side of the coil and hooked a jumper wire to it I took the coil wire off the dist. cap and laid it 1/4 from metal bracket. Turned key to RUN-Tapped other end of jumper wire to ground -creating sparks there at the end of the jumper.. NO sparking at the coil wire So,what does this tell me? Thanks for your help guys..and your patience!!! Yeah,I was grounding the plugs.
#158822
12/04/08 08:50 PM
12/04/08 08:50 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Check the ballast resistor
NS1AAR
[Re: RapidRobert]
#158824
12/04/08 10:45 PM
12/04/08 10:45 PM
yeah,I had the jumper on the neg. terminal I tried it again with both pos. and neg. sides jumped.Still no regular spark from the coil secondary wire ![](/ubbthreads/images/graemlins/hammer.gif)
#158825
12/04/08 11:15 PM
12/04/08 11:15 PM
RapidRobert
your jumping 12V to the coil positive primary & grounding the coil negative primary terminal & pulling it away from ground intermittently & the coil secondary wire held 1/4" from another ground has no spark as you make/break the neg to ground. No spark = a deceased coil
#158826
12/05/08 06:24 PM
12/05/08 06:24 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
Please tell me it isn't an orange control box you have.
If it will TRY to start when you STOP cranking it over, it sounds weird, but try another ECU that you KNOW works.
No spark while cranking, let the key go and it TRIES to fire sometimes? Is that it?
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#158827
12/06/08 12:38 PM
12/06/08 12:38 PM
Yep,It was the coil.Finally got a chance to get one this morning.Its running now.Odd that a few days ago,I took mine off and took it to Oreillys and AutoZone and had it tested and they both said it was OK ![](/ubbthreads/images/graemlins/shruggy.gif) Thanks RapidRobert and all you guys for the help Allen
