9" vs 8.75 #1587833
03/03/14 10:54 PM
03/03/14 10:54 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Anyone got an ideal on the weight (center section)?......Thax
Re: 9" vs 8.75 [Re: racerx] #1587834
03/03/14 11:00 PM
03/03/14 11:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
8.75 = 60lb with strange spool
Re: 9" vs 8.75 [Re: J_BODY] #1587835
03/04/14 12:20 AM
03/04/14 12:20 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You sure, feels a lot heavier then that.
Re: 9" vs 8.75 [Re: J_BODY] #1587836
03/04/14 12:32 AM
03/04/14 12:32 AM
Kirkland, Washington
Pacnorthcuda Offline
Ok...because it's sitting on my bench, I just went down and weighed it...
489, with cone sure grip, 75lbs.
Re: 9" vs 8.75 [Re: Pacnorthcuda] #1587837
03/04/14 12:44 AM
03/04/14 12:44 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs gents: I'v should have been clear with the ?trying to find the weight diff.between an spooled 9"and a spooled 8.75....
Re: 9" vs 8.75 [Re: racerx] #1587838
03/04/14 12:56 AM
03/04/14 12:56 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
489 lightweight spool
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 9" vs 8.75 [Re: 1967dartgt] #1587839
03/04/14 01:04 AM
03/04/14 01:04 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
57lbs? That means a lightweight spool weighs 18lbs less then a cone style suregrip?
Re: 9" vs 8.75 [Re: jcc] #1587840
03/04/14 01:13 AM
03/04/14 01:13 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes, stock caps and 1350 chromoly yoke on it. I don't know what effect gears has on it I a sure some and that chuck has 4.56s in it.
Re: 9" vs 8.75 [Re: 1967dartgt] #1587841
03/04/14 01:27 AM
03/04/14 01:27 AM
ky
68roadrunner Offline
ky
742 case with 3.91 and 35 spline spool= 60.5lbs
9" stock case and pinion support,with 31 spline spool with 5.30 gears= 60.0 lbs
8-3/4 housing 49.5" long with a backbrace, and ladder bar brackets, and shock mounts= 52 lbs
9" housing 47" long, no brace, ladder bar brackets and shock mounts= 52 lbs
Re: 9" vs 8.75 [Re: 68roadrunner] #1587842
03/04/14 01:42 AM
03/04/14 01:42 AM
ky
ky
do realize a stock case 9" will not live with any kind of hp or traction
i dont have the weights on an aftermarket 9" case
my other one is aluminum
Re: 9" vs 8.75 [Re: 68roadrunner] #1587843
03/04/14 09:07 AM
03/04/14 09:07 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax 4 the repl. is the aluminum one in the car?if not can u weigh it?THax.....
Re: 9" vs 8.75 [Re: racerx] #1587844
03/04/14 05:33 PM
03/04/14 05:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
489 with cone-type Sure-Grip; 72 lbs. 3 oz. on digital scales.
Re: 9" vs 8.75 [Re: racerx] #1587845
03/04/14 11:00 PM
03/04/14 11:00 PM
ky
ky
moser aluminum bolt through case
aluminum pinion support
35 spline steel spool
small pinion 4.10
59.5 lbs
