Re: Pro Comp Small Block Heads [Re: cj391] #1587327
03/08/14 12:45 AM
03/08/14 12:45 AM
Union grove,wi
cj391 Offline
cj391  Offline
Union grove,wi
chamber
Re: Pro Comp Small Block Heads [Re: cj391] #1587328
03/08/14 03:02 PM
03/08/14 03:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
There's quite a bit of runner area untouched by their CNC porting.
I know what they're advertised to flow, but I wonder what they really flow.
Are those going to get a different valve job? And what valves are you intending to use?
Re: Pro Comp Small Block Heads [Re: b5fish73] #1587329
03/08/14 04:11 PM
03/08/14 04:11 PM
Az
Crizila Offline
Crizila  Offline
Az
I broke down and bought a set of bare heads and their valve train set of the new Pro Comp LA heads. The flow numbers are pretty decent and comparable, if not better than the Edelbrocks. I have a whopping $730 in these heads and couldn't be happier with the quality. The service on the other hand was really lacking. They sent the wrong spring cups and had to call 10 times to get the correct ones. I know I'm going to get some response back about them being "Made in China" but anyways here are the flow numbers OOTB with 2.05/1.60 valves. They are right in line with my ported RHS magnum heads.
@28"
Lift INT EXH
.100 69.5 63.1
.200 130.4 103.4
.300 182.6 139.4
.400 227.5 164.2
.500 245.7 175.3
.600 252.3 180.2
Any pics to share? Here are some of my Hughes ported Edelbrocks.
Fastest 300
Re: Pro Comp Small Block Heads [Re: Crizila] #1587330
03/08/14 04:12 PM
03/08/14 04:12 PM
Az
Crizila Offline
Crizila  Offline
Az
some mo.
Fastest 300
Re: Pro Comp Small Block Heads [Re: Crizila] #1587331
03/08/14 04:13 PM
03/08/14 04:13 PM
Az
Crizila Offline
Crizila  Offline
Az
and mo.
Fastest 300
Re: Pro Comp Small Block Heads [Re: BradH] #1587332
03/08/14 07:46 PM
03/08/14 07:46 PM
Union grove,wi
cj391 Offline
cj391  Offline
Union grove,wi
unsure of valvetrain components. Once i get valves and valve job done they'll get flowed. I'll report back with results.
