Re: Cheap Single Stage paint?
[Re: ChallengerGary]
#1586295
04/23/14 11:33 AM
04/23/14 11:33 AM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Lots and lots of guys around here use the Nason stuff, especially the clear. It sprays out good and looks good. But it will not live as long as the front line Du Pont.
With the clear, you can really tell the difference if you wait a few days too long to rub out the DuPont Clear. It is much harder to cut and buff than the Nason.
By the way, DuPont has been bought out and the paint is in the process of being renamed by the new owner. Our local paint supplier is struggling now with some of the mixing changes going on.
A red last week was so far off on the first mix that he had to throw it out and start over. And a white yesterday had to be tinted quite a bit to get to a point that I could use it.
I hope it gets better.
Master, again and still
[Re: GTX MATT]
#1586297
04/24/14 12:41 AM
04/24/14 12:41 AM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
Our cars don't rust here so leaving it in primer is an option. I have let bare metal sit in my garage for years without getting even a slight haze.
Where do you live?
feign X, Arid Zone ah
noun either of the zones of latitude 15--30° N and S characterized by very low rainfall and desert or semidesert terrain
