Page 2 of 3 1 2 3
Re: Motor oil in trans [Re: tscuda] #158521
11/29/08 10:20 AM
11/29/08 10:20 AM
Also,put your motor oil in anything but a 904/727 and see how long it lasts.Even Type F is not recommended.
Re: Motor oil in trans #158522
11/29/08 10:25 AM
11/29/08 10:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The first Fluid Drives that Chrysler made not only used motor oil but it used the same oil as the engine it was attached to, they shared the oil.
While the Fluid Drive wasn't an automatic, per se, it did have a torque converter and other features present in what we call an automatic.
As for switching from gear oil to ATF in a stick, that was done to ease shifting, NOT for durability.
Don't be the exception.
Re: Motor oil in trans [Re: Supercuda] #158523
11/29/08 10:29 AM
11/29/08 10:29 AM
And constant temperatures below 30*.
Manufacturers spend millions on R&D to make things work.Ever wonder why? Another example is power steering fluid.How many use ATF fluid in a power steering pump? It will work but if you want to see the difference,take two clean pumps,run one with each for a year and take them apart.You won't run ATF when you see the difference.
Re: Motor oil in trans [Re: Supercuda] #158524
11/29/08 12:17 PM
11/29/08 12:17 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I agree that's part of it, but the thinner oil get's into more places, so it protects better too.
With 80's honda manual transmissions, it was very common to see 5th gear burned out. The Common cause was adding gear oil instead of using the recomended 10w30 motor oil. The gear oil was too thick to make it out to 5th gear. The teeth would disintigrate.
Back to the oil in the auto debate , I remember at auto school (all those years ago) them telling us the base ingredient in dexron was 10w30 motor oil. The rest of it was all detergent, pressure, and heat additives.
It can be debated as to whether engine oil has better lube properites, but how often does an auto trans fail from lack of lube anyway?
Virtually never.
It is always heat, and lack of pressure that kills autos.
Although I don't think using motor oil is a good idea, I doubt it did any damage. It's just a good reason to go through it now that you know.
Re: Motor oil in trans [Re: dave571] #158525
11/29/08 12:58 PM
11/29/08 12:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
on the flip side Chrysler changed the spec from ATF to motor oil in some of the FWD 5 speeds, durability reasons were given.
ATF is thin, lack of "shock" ability is part of it's problem. As for autos failing for lack of lube, I have rebuilt more than on Torqueflight that had wear issues with bushings. That wasn't teh failure mode, but it was an issue.
Re: Motor oil in trans #158526
11/30/08 05:38 PM
11/30/08 05:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
And the aftermarket spends millions undoing their work.
And then there's the TSB...........
Re: Motor oil in trans [Re: John_Kunkel] #158527
11/30/08 07:26 PM
11/30/08 07:26 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
I tore apart a 727 that someone put two bottles of "trans fix" in it.The fluid looked like black jello.
Re: Motor oil in trans [Re: tscuda] #158528
11/30/08 08:23 PM
11/30/08 08:23 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Tranny fluid is a poor lubricant
I would think that too. But why would the factory switch from 90 weight to atf in the manaual trans.
Less drag for fuel economy - same reason they went to lower viscosity motor oils.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Motor oil in trans [Re: bigslant6fan] #158529
11/30/08 08:57 PM
11/30/08 08:57 PM
I wonder if thats what happened here with tscuda. that it was acting up & the owner figured that 2 or 3 bottles of this miracle stuff would for sure take care of it(cheaply ) because I dont think many people put motor oil in their tranny.
Re: Motor oil in trans [Re: RapidRobert] #158530
11/30/08 10:44 PM
11/30/08 10:44 PM
dulcich Offline
dulcich  Offline
I use tranny fluid in my engines, motor oil in my tranny's and brake fluid in my power steering, in the appropriate quantities, of course.
-dulcich
Re: Motor oil in trans [Re: tscuda] #158531
12/01/08 09:47 AM
12/01/08 09:47 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I am working from memory
and don't recall all the details
but I am pretty sure that
Bill Kondolay (of Diesel Trans in Canada)
http://www.dieseltrans.com/phpBB/index.php
several years ago ran some experiments
on 47R automatics
comparing
Mobil One Syn motor oil (can't remember viscosity)
against
Chrysler ATF+ (can't remember whether +2 or +3)
I have a vague memory that it initially looked promising for Mobil One Syn motor oil but did not work out well in the long run
Many years ago I had a good & imformative telephone conversation with an engineer at Universal Lubricants, the makers of the 'Red Bottle' and 'Black Bottle' trans additives about what alternatives would be superior to ATF+2, and this UL engineer seemed confident that Black Bottle additive plus Mobil One Syn ATF was at least as good as +3
Chrysler & Lubrizol laid out the
ATF+4 (Type 9602)
technical story in a 14 page SAE document (paper# 982674)
Re: Motor oil in trans #158532
12/01/08 11:46 PM
12/01/08 11:46 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Have you looked at what the auto manufacturers recommend for power steering??? Yep ATF!!!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Motor oil in trans [Re: 360view] #158533
12/02/08 08:10 AM
12/02/08 08:10 AM
USA
3
360view Offline
360view  Offline
3
USA
anyone ever run a 727 or 518
on a test stand for transmissions
and found the friction differences
between the various ATF's
like Type F versus 7176 versus Mobil One Syn ATF ?
Re: Motor oil in trans [Re: 360view] #158534
12/02/08 08:25 AM
12/02/08 08:25 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
From a Harley web site
First of all I want to state that I'm no engineer and the observations here are from personal experience and 40+ years as a auto and bike repair shop owner/mechanic. In the last 30 years I've built well over 1000 automatics for every application from stock to all out race applications in 1000+hp race cars and monster trucks.
For those of you (including myself) that use ATF in the primary here's some facts that I have verified over the years.
There are approximately 25 types of ATF but I'll cover the 5 most common as the other twenty are either obsolete or very vehicle specific.
Type F or (Ford) fluid was developed for and used in Ford automatic transmissions back when the clutch discs were made of sintered bronze or asbestos and there were no bearings used. All parts were supported by bronze bushings and thrust washers. It is essentially 20wt hydraulic oil (pure mineral oil) with a red dye and that's it. It is commonly sold as Racing ATF under brands such as B&M Trick Shift because it provides the quickest lockup of the clutch packs (Hardest shift). It has no place in 99.9 percent of modern applications unless you're just looking for neck snapping shifts (or in the case of motorcycles used for drag racing where quick and harsh clutch engagement is the primary goal and you're gonna change it very often.
Dexron II and III are the most commonly used fluids with the only difference being additives in Dexron III to make it more compatible with the electronics used in modern transmissions.
They both have an additive package that includes friction modifiers for smoother cluch engagement, oxidation control, viscosity stabilizers, corrosion inhibitors and proper lubrication of bearings and bushings of all types. Since the advent of gerotor pumps and better friction materials such as Kevlar and Aramid, Dexron II or III has even replaced the use of Type F for racing use by most transmission builders.
Dexron III is commonly used in many automotive manual tranmissions and is probably used in more transfer cases of 4WD vehicles than any other fluid.
ATF+3 uses higher quality base oils with the highest content of friction modifiers to prevent torque converter shudder. It lubricates a bit better than Dexron III but can also cause slow clutch engagment (slipping). If you ride easy and your primary goal is smooth clutch engagment then this is the fluid to use in your primary if you're gonna run ATF.
Synthetic ATF comes in many formulations but the most common is Dexron III. It has the same properties of clutch engagement as Dexron III with some advantages.
The main advantage of synthetic fluid is it's ability to resist thermal breakdown. If you ride in extreme heat or just want to extend your primary fluid change intervals then this is probably your fluid.
You may want to think about this too. Although the primary doesn't generate much heat in and of itself that's not the only concern when choosing a fluid.
The primary on your motorcycle is not a seperate entity. It is attached to the engine and it acts as a giant heatsink for that engine. The temps seen on a long hard run are probably within 20-40 degress of the engine oil temp.
Mineral based ATF starts to break down at around 220 degrees and is almost useless as a lubricant at 250 degrees.
Personally I use any major brand of regular Dexron III and change it out every 5000 miles but if I did alot of the riding described above I would probably use synthetic (although I am a cheap old [Edited by Moparts - Keep it clean]).
I'm not promoting the use of ATF in the primary!
But!
ATF has proven itself in hundreds of millions of auto applications and tens of millions of manual tranmissions and transfer cases.
You almost never see a 4wd transfer case failure anymore and I've personally seen 4wd trucks with a quarter million miles on a manual transmission and transfer case using Dexron III and still going strong.
Re: Motor oil in trans [Re: dulcich] #158535
12/02/08 11:29 AM
12/02/08 11:29 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
-dulcich
I use 1/2 qt of 30wt in some of my transmissions..and i have used trans fluid in old dirty engines
butt what does brake fluid do in the power steering??
Re: Motor oil in trans [Re: Dakota_Don] #158536
12/02/08 12:23 PM
12/02/08 12:23 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Brake fluid will help keep the seal swollen and soft to prevent leaks. I've used it in a tranny that'd hardly pull before, it worked great for about a week.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Motor oil in trans [Re: dave571] #158537
12/02/08 06:36 PM
12/02/08 06:36 PM
WA 98043
thecarfarmer Offline
WA 98043
...With 80's honda manual transmissions, it was very common to see 5th gear burned out. The Common cause was adding gear oil instead of using the recomended 10w30 motor oil. The gear oil was too thick to make it out to 5th gear. The teeth would disintigrate....
A low oil level would do the same thing, too. Replaced a couple of 5th gear sets where someone had let 'em get low.
IMHO, running low on oil, hi temp on oil, or over-long intervals on oil is usually worse than using the "wrong" oil.
...I was thinking when I seen that that it might have been done to solve a problem. Like how they used to add sawdust to the atf.
I've never heard of putting sawdust in an auto; I know guys would do it to quiet a noisy stickshift, but, I'd imagine that it doesn't do a torque convertor, clutches/bands, front pump, etc. any favors.
I've also put type F into 727's to make 'em apply clutches faster. I even ran a 50/50 mix of straight 30 and type F to crutch years of life out of an AT in a Geo Metro (yeah, baby!) that was starting to slip. The different friction characteristics stopped the slipping for at least three years until I sold the car.
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Motor oil in trans [Re: thecarfarmer] #158538
12/07/08 04:33 PM
12/07/08 04:33 PM
Bellville, Mi.
tscuda Offline OP
tscuda  Offline OP
Bellville, Mi.
Before the invention of Transmedic the old trick of adding saw dust was to get you home or to sell a car before the trans went. It didn't last long but it got the guy away from your house. And no I never done that. But back to my trans. The clutchs and bands didn't look that good at tear down. But I have plans on rebuilding it anyways. I was more worried about the vb then anything else.
Re: Motor oil in trans [Re: tscuda] #158539
12/07/08 04:45 PM
12/07/08 04:45 PM
The saw dust deal was a used car dealer would have their mechanic put it in the rear axle not the trans to quiet one that was noisy.A noisy rear axle in a daily driver will last a long time but the noise would scare away a potential buyer.
Re: Motor oil in trans [Re: Prodart440] #158540
12/07/08 05:22 PM
12/07/08 05:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not all recommend ATF for power steering fluid and if you use the wrong fluid you will have issues. Seal compatibility usually.
If your system is designed to use ATF, then use it. If it is designed to use something else you'd be foolish to use ATF.
Page 2 of 3 1 2 3
