Re: Need input on wideband o2 sensor kits [Re: hooziewhatsit] #1580793
02/19/14 02:01 AM
02/19/14 02:01 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I watched flebay for a while and got my LM1 box cheap (like $10). Then got the sensor and cables new from innovate.
Then watched ebay again, and got the logging add-on thing pretty cheap.
Then to make it really useful, I built my own manifold vacuum gauge and ran that into the logging port. Now it logs AFR/RPM/Manifold vacuum, so you can actually see how the AFR changes with changes in throttle position.
Then I converted to electronic ignition and fixed all of the driveability issues I thought were fuel related
Yes. Yes you did.
Re: Need input on wideband o2 sensor kits [Re: Jeremiah] #1580794
02/19/14 03:42 AM
02/19/14 03:42 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
How are you guys logging your RPM?
Re: Need input on wideband o2 sensor kits [Re: Azzkikrcuda] #1580795
02/19/14 04:08 AM
02/19/14 04:08 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I run a Innovate LC-1 kit in my car, and my brother runs an AEM kit. Both work good.
I run LC-1's in each bank in closed loop, no problems for 5+ years.
Re: Need input on wideband o2 sensor kits [Re: ntstlgl1970] #1580796
02/20/14 02:11 AM
02/20/14 02:11 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
I love my Innovate LM2. I've heard lots of people have problems with them but I have mine for quite a while and never an issue. I log RPM an AFR, and soon will probably be logging IAT and ECT. With any one you choose be sure to free air calibrate it regularly. Any sensor is only as good as it's calibration. Reading plugs is great for a base line but if I would have relied soley on plugs my cast pistons would have been all over the road by now. I'll get flamed for saying this but some of the old heads need to learn to trust alittle more technology now and then. If you watch ebay close you can pick one up in the $250 range. I bought mine for $230 on sale
Re: Need input on wideband o2 sensor kits [Re: SLOW67] #1580797
02/20/14 03:57 AM
02/20/14 03:57 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
The NGK Powerdex AFX with the NTK O2 sensor is supposed to be very accurate. The big digital readout is easy to read also.
http://www.ngksparkplugs.com/products/performance/afx.asp?mode=nml
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Need input on wideband o2 sensor kits [Re: BradD] #1580798
02/21/14 12:40 AM
02/21/14 12:40 AM
ontario canada kingston
aspenrt360 Offline OP
thanks for all the info guy's not looking to get too crazy right off the bat I will pick one up and tinker with it a bit and see how I like it. it seems like a really good tool for tuning and after all these years I want to see how my tuning holds up to some real stats!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Need input on wideband o2 sensor kits [Re: aspenrt360] #1580799
02/21/14 02:50 AM
02/21/14 02:50 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I am running the AEM Unit (4200??) In my Megasquirt setup. so far so good!
Re: Need input on wideband o2 sensor kits [Re: redmist] #1580800
02/21/14 03:57 AM
02/21/14 03:57 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
+1 for the LC-1. Works great with my Megasquirt. Only have done one free-air calibration in 5+ years, just to double check that it was accurate. So far it's dead on.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Need input on wideband o2 sensor kits [Re: herkamer] #1580801
02/21/14 08:46 PM
02/21/14 08:46 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I just scored a lightly used LM-2 for $150.
There is also a local (MI) guy that has a new NTK/NGK kit listed for $125.
The NGK sensor is better, but the Bosch sensor is way cheaper when it fails and needs replacing.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Need input on wideband o2 sensor kits [Re: herkamer] #1580802
02/22/14 04:38 AM
02/22/14 04:38 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I havn`t calibrated mine in a couple years but maybe it`s time although I figured w/a 3 1/2 side exit that was "airy" enuff............ Mine`s older and even has a countdown warm up deal.
Re: Need input on wideband o2 sensor kits [Re: Thumperdart] #1580803
02/24/14 03:48 PM
02/24/14 03:48 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Realy great topic Im going for a full sweep LC-1
Re: Need input on wideband o2 sensor kits [Re: Mopar Guy] #1580804
02/24/14 04:29 PM
02/24/14 04:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The tech. is there so why not use it plus until I knew which direction to go tune up wise, my car was slower and was hard keeping #8 NGK`s happy.
Re: Need input on wideband o2 sensor kits [Re: GTX MATT] #1580805
02/24/14 07:17 PM
02/24/14 07:17 PM
hooziewhatsit Offline
Yes. Yes you did.
I found an LMA-2 RPM converter cheap on ebay. I also have my manifold vacuum sensor feeding into the LMA-2, which is/was very cool to watch in the logs.
Re: Need input on wideband o2 sensor kits [Re: hooziewhatsit] #1580806
02/24/14 09:39 PM
02/24/14 09:39 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I have an AEM. Works fine, but the background lighting goes wonky occasionally and then randomly changes to red, white, blue, green, whatever. Strange.
Whichever you purchase, I would suggest getting an analog gauge as opposed to a digital readout. They are much easier to glance at and see how the AFR may be trending.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Need input on wideband o2 sensor kits [Re: BBR] #1580807
02/24/14 09:53 PM
02/24/14 09:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The gauge I have inside the car is a digital read out
along with yellow green and red lights for a quick
glance(I sure dont read the numbers while driving)
Re: Need input on wideband o2 sensor kits [Re: MR_P_BODY] #1580808
02/25/14 01:31 AM
02/25/14 01:31 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I run the Zeitronix. Cool thing is you can add on to it and data log a bunch of stuff.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Need input on wideband o2 sensor kits [Re: HOTMOPR] #1580809
02/25/14 12:26 PM
02/25/14 12:26 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
My GoPro mounted on the roll bar behind my right shoulder records the AF, shift light and when I shift.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Need input on wideband o2 sensor kits [Re: Adobedude] #1580810
02/25/14 12:39 PM
02/25/14 12:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I put a camera in my car just to see a few things
inside the car during a run... like where do I look
when the front end is up... I thought I sorta watched
the wall and basically that is what I do
