Re: 600/625 on a 440 [Re: RoadRunnerLuva] #1580606
02/19/14 01:54 AM
02/19/14 01:54 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I used to have a mild (stock) rebuilt '69 440
in a C body Chrysler. The cam was the Mopar
.455 lift hydralic,stock 906 heads with just a 3 angle valve job, 1-7/8 headers,CH4B intake,
and a Carter 625 4 bbl. The car would fall flat
in the upper (5,000) rpm range and run out of steam.
I went back in it a year later, changed to the
.509 cam, put a Holley 3310 750 4bbl on it, and it was a completely different car! Took it to
a local track and did a best of 14.10 @101mph
After that I always stuck with the Holley.
Hmm, change carb and cam, but it must of been the carb that did it. My thoughts say the cam probably had more influence on it than the carb.
Seriously, how much time does a street type car spend at 5000+ rpm?
Don't be the exception.
Re: 600/625 on a 440 [Re: Supercuda] #1580607
02/19/14 11:35 AM
02/19/14 11:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The carter 625 would be your best bet. If you want to do better w/ the MPGs you'll have to swap the gears out, or maybe try a taller tire.
Re: 600/625 on a 440 [Re: Mr.Yuck] #1580608
02/19/14 03:42 PM
02/19/14 03:42 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
A Carterbrock is really simple to rebuild. No need to pay for it to be done.
I want my fair share
Re: 600/625 on a 440 [Re: SomeCarGuy] #1580609
02/19/14 09:07 PM
02/19/14 09:07 PM
Iowa
76dodgeboy Offline OP
Iowa
Not paying to get the carb rebuilt. Hp383 is a friend. I suck at rebuilding them. Haven't had to really mess with what I've had. tried to rebuild obey for my 5th ave and was getting 7-9mph. I suck at carb work.
Probably going to run a 33" tire.
