Re: Question for the 9 second small-block NA guys
[Re: Guitar Jones]
#1580289
02/21/14 06:30 PM
02/21/14 06:30 PM
Posts: 2,864 IN
Irun5snd8th
IN
I think you will be fine. I went 9.72 136 mph at 3000 lbs with 16X32's and a 4.88 at 7200. Keep in mind that your converter affects the finish line rpm as well. percentage of slip etc. I have since picked up a few mph in the 1/8th so Im expecting it to go 140ish and be around 7400
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Otherlane]
#1580292
02/23/14 12:02 AM
02/23/14 12:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I run a 428Sb with a 28x10 and 4.56 gears running high 9s.Shifting at 7500 and going though the traps at 8000. The car seems like its running out of steam. I was told by my engine builder to set the car up to run 7400 out the back door. That's where is made peak hp. I think i'm going to try a set of 4.10s
Set up your gear to run thru the traps at 10% above max HP rpm
[Re: MR_P_BODY]
#1580293
02/23/14 11:29 AM
02/23/14 11:29 AM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
So he should be going thru at 8100? Seems a little higher than necessary isn't it?
[Re: moparguy7074]
#1580298
02/23/14 01:07 PM
02/23/14 01:07 PM
MR_P_BODY
There are plenty of pros that say 10% higher.. if you dont want to.. dont... but rpm is HP.. if your set up for it
[Re: pittsburghracer]
#1580299
02/23/14 02:14 PM
02/23/14 02:14 PM
Posts: 2,007 Apollo, PA.
B1MAXX
Apollo, PA.
I don't know why guys think this is necessary. I'm not going to say there aren't engines out there that NEED high rpm but come-on now. Test your combo at the track shifting at a lower rpm and you may really be pleased with the results. I know I was and I only changed from 6800 to 6400. I was young once and I too put a few rods out thru the side of some engine blocks.
Maybe it's cause you run .550 lift street cams
#1580300
02/23/14 07:14 PM
02/23/14 07:14 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
I had mine geared for street use,but it worked great at the track to.8.75 w 3.91 and 5500 stall on 28x10.5. Hit 1/4 traps at 7000 rpm and 140mph also had 727 tf at the time.
[Re: 10 o to go]
#1580304
02/24/14 02:48 PM
02/24/14 02:48 PM
Quicktree
140 mph wow
pretty sure he is boosted, mine runs 140+ at 7000 NA, but it's a whole lot lighter
