Re: can an auto trans shift "too hard", causing damage?
[Re: RSNOMO]
#1579759
02/18/14 08:26 PM
02/18/14 08:26 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
That trans is WAY too radical for what you're doing...
And it's gonna find the weakest point...
Zing..
Lose the 5.0 lever and the accumulator blocker rod. Put a 3.8 lever in it , 5.0 is a HEMI part that helped apply more leverage on the wide hemi band , it may apply quicker but it releases slower ...
or does it apply slower and release faster ???
[Re: JohnRR]
#1579760
02/18/14 09:02 PM
02/18/14 09:02 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
Zing..
HUH???
[Re: mcmopars]
#1579762
02/18/14 09:18 PM
02/18/14 09:18 PM
Posts: 1,012 indiana
mcmopars
indiana
in your first statement you said it is a griener rpmvb,now you state its and automatic????
sorry my bad
[Re: JohnRR]
#1579763
02/18/14 09:41 PM
02/18/14 09:41 PM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
Zing..
why lose the blocker rod? what about the 4.2 lever?
[Re: cal_gecko]
#1579764
02/18/14 11:34 PM
02/18/14 11:34 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
HUH???
Blocking the accumulator firms-up the shift...
'5.0' lever takes the kick-down shift point upstairs...
[Re: cal_gecko]
#1579765
02/19/14 12:35 AM
02/19/14 12:35 AM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Zing..
HUH???
Sorr cal_geco, that's my fault...I responded to your original post and JohnRR responded to one of my posts which started a sub-conversation...
[Re: barracuda7199]
#1579766
02/20/14 11:26 AM
02/20/14 11:26 AM
JohnRR
Zing..
3.8 or 4.2 ...
[Re: JohnRR]
#1579767
02/20/14 11:52 AM
02/20/14 11:52 AM
Posts: 5,166 CT
GTX MATT
CT
The 5.0 lever on a regular non-hemi band usually causes excessive shift overlap and can actually cause the output shaft to lock up in between shifts. If you want to verify put the car on a lift, have someone start in low and bring it up to speed. Watch the tires as they select second. If you see the wheels stop in between shifts you have too much overlap.
Alot of times you need to install a restrictor plug on one of the ports (not sure which) to delay the apply to eliminate this with the 5.0 lever. I will say though I've been in a car that had this issue fixed by Fairbanks back in the 80s, and even with the restrictor, with the 5.0 lever that car will launch you forward on a 1-2 shift like you wouldn't believe with a stock 383.
[Re: GTX MATT]
#1579768
02/20/14 04:51 PM
02/20/14 04:51 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Overlap on the 1-2 upshift isn't caused by the lever ratio, it's caused by a rear servo that's slow to release.
As I've stated many times, shift phenomenon observed on jackstands isn't the same as when the car is under power.
[Re: John_Kunkel]
#1579769
02/20/14 05:11 PM
02/20/14 05:11 PM
Posts: 5,166 CT
GTX MATT
CT
Yes but you can only get the rear servo to release so fast, no? You can only fit so much spring in there. What changes on jackstands vs out on the road? I'm just going off of what Fairbanks was doing in the 80s.
[Re: GTX MATT]
#1579770
02/20/14 09:35 PM
02/20/14 09:35 PM
John_Kunkel
Rio Linda, CA
When under power the car's momentum will "drive through" some overlap so it's barely noticeable, when it's on jackstands there is minimal load on the trans so overlap becomes more visible.
[Re: GTX MATT]
#1579774
02/21/14 11:45 AM
02/21/14 11:45 AM
JohnRR
Thats kind of what I figured, but I thought that was the idea behind putting it on the lift also, on the road you wouldn't notice it or you would assume it was barking the tires because of a hard apply rather than a bind between gears. Would it be okay for the car to do this when there's no load on it?
The 727 by design has overlap of the 2-3 , Chrysler engineers put a lot of thought and effort into making it has minimal as possible ...
Add a shift kit and you screw that all up ...
As John K said , running it on a lift is not going to tell you what you think it is .
[Re: cal_gecko]
#1579775
02/21/14 04:18 PM
02/21/14 04:18 PM
Posts: 85 Rio Linda, CA
nytemuvr
Rio Linda, CA
Get a torque strap as even driving around town under light throttle is hard on the rubber engine mounts. I put a Transpak and reconfigured the valve body, removed the accumulator piston when my Challenger was 6 months old. I had to change driver side motor mounts a lot. But once I started a powerstand and let off the brakes it would sit in one place and shift though the gears burning the tires off. That transmission still snapped 2nd gear rubber in drive on a WOT until I rebuilt it at 186K miles in '95. I returned it to mostly stock configuration then, but it still picks up 2nd gear rubber as it did from the factory in '71 with Polyglas tires. It jumps sideways about a foot on a WOT 1-2 shift in drive now. [Email]340ci@400+[/Email] hp, 400 hp was as high as the old analog dynos registered. Stock Mopar 2850 rpm torque converter, 3.55 SG. 5.0 lever is really hard on everything.
1972 Challenger 340(original owner)
1968 D100
1997 HD Road King
