Page 5 of 5 1 2 3 4 5
Re: Front Steer Rack Conversion - Part Deux [Re: 1967dartgt] #1579506
03/05/14 03:54 PM
03/05/14 03:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Its when doing things like these lower arms that it'd be really handy to have access to a 3D printer !!
Re: Front Steer Rack Conversion - Part Deux [Re: Stanton] #1579507
03/06/14 07:50 AM
03/06/14 07:50 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I doubt they would let me print a couple of titanium steering arms on the SLM at work.
Alan Jones
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579508
03/06/14 11:00 AM
03/06/14 11:00 AM
gregsdart Offline
gregsdart  Offline
The steering arm web is IMO way over kill
Good god, what are we talking, a couple ounces ?!?!? Hell, skip the fries at lunch !!!
As for the ackerman, zero is fine for straight line racing but the OP's application (as far as I know) and mine would be a street car and you do want some ackerman or you end up with significant scrub.
As far as the ackerman discussion, from everything I read, if you get the outer tie rod intersect outside the balljoint, you will have ackerman. Maybe not the exact optimimum position, because of space limitations ie: the wheel, but you do the best you can. On a side note, My rack is out 8 1/2" in front of the wheel. The outer tie rod connection is 7" in front. My mind escapes me how far out the tie rod connect point is outside of the ball joint. I'll have to look at my notes. Also, using my test arms, I played around with the outer connect location, in and out, up and down and settled on a position that got bumpsteer to within .030" over 6" travel.
Steff, You covered both ends of the project IMO, excelllent engineering and great looking finished product. I would be proud to put this deal on a show car.
Re: Front Steer Rack Conversion - Part Deux [Re: gregsdart] #1579509
03/09/14 03:32 PM
03/09/14 03:32 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Thanx for the kind word, all!! I got the Steering Arms finished. Here's a few pics.
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579510
03/09/14 06:15 PM
03/09/14 06:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Wow, those things hang out way in front of the rotor. What size are those rotors ??
Very nice. When I saw your cad drawings I thought they were going to be milled out of a chunk. But seeing how you've made them its something just about anyone could tackle without great expense. Very nice! And I think the extra gussets make sense.
Would you care to share the actual specs on those ??
Re: Front Steer Rack Conversion - Part Deux [Re: Stanton] #1579511
03/10/14 08:44 AM
03/10/14 08:44 AM
STEFF Offline OP
STEFF  Offline OP
Thanx!! Here's the info: From the center of the ball joint to the tie rod connection is 7", which is only a 1/2" further out from stock. The tie rod connection is also .625" outside of the ball joint. I had the gussets and base plates water jet cut from A-36 Hot Rolled Steel. Cost was $150 including material. Base Plate is 3/8" thick. Gusset is 3/4" thick. The Ball Joint Sleeves came from Speedway Motors. They were $7 each. I was able to have a friend at work machine the hole for the ball joint sleeve and tie rod tube in the main plate. The hole for the Ball Joint Sleeve was machined on a 7 1/2 degree angle to mimic the factory ball joint angle. The holes were machined to provide a slip fit for the BJ sleeve and tie rod tube. All parts were tig welded.
Re: Front Steer Rack Conversion - Part Deux - UPDATE!! [Re: STEFF] #1579512
03/30/14 03:32 PM
03/30/14 03:32 PM
STEFF Offline OP
STEFF  Offline OP
Finally finished my front end and just came back from a road test. The car drives GREAT!!! Goes straight, backs up with no issues etc.... Did a garage alignment, following instructions from Rick Jones article. Can't wait to get this thing down the track in two weeks at Mopars at the Rock!!
Re: Front Steer Rack Conversion - Part Deux - UPDATE!! [Re: STEFF] #1579513
03/30/14 03:40 PM
03/30/14 03:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cool ... Steff.. whats the length of the steering
arm from the C/L of the ball joint to the C/L of the
tie rod end... whats the turning radius... I'm moving
mine in about 1" and moving the rack back about 1 1/2"
to get a better turning radius
EDIT
I see you put the length in... thanks... hows the
turning radius
Re: Front Steer Rack Conversion - Part Deux - UPDATE!! [Re: MR_P_BODY] #1579514
03/30/14 04:05 PM
03/30/14 04:05 PM
STEFF Offline OP
STEFF  Offline OP
EDIT
turning radius
Turning radius isn't as tight as before but it isn't all that bad either. I have the Pinto rack, which has 4 turns lock to lock. Just need to be a little more aware when pulling in to tight areas. No hair pin turns.....LOL!
Re: Front Steer Rack Conversion - Part Deux - UPDATE!! [Re: STEFF] #1579515
03/30/14 04:30 PM
03/30/14 04:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the Pinto rack also and I think its just over
3 3/4 turns lock to lock but I didnt like my turning
radius for a street rod so thats why I'm moving things..
I'm gonna start on that next week... I'm finishing up
moving the body up 1" in the rear.. gotta do the same
thing in the front.. the springs I have are wrong
on both ends... I'm putting on 5# heavier rears and
moved the lower brackets... the fronts will take a bit
more work... I have the upper strut mounts on top of
the rail and I need them on the bottom with lighter
springs in front.. right now the struts are topped out
Re: Front Steer Rack Conversion - Part Deux - UPDATE!! [Re: MR_P_BODY] #1579516
03/30/14 06:14 PM
03/30/14 06:14 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Looks great Steff glad to hear she drives nice
