Page 2 of 5 1 2 3 4 5
Re: Front Steer Rack Conversion - Part Deux [Re: ] #1579446
02/16/14 03:23 PM
02/16/14 03:23 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
IMO, yes and no, In the area a gusset is suggested I don't see a stress concentration, relative to the rest of his design, and therefore adding a gusset would only make another area more prone to flexing and stress concentration issues, it looks to me well balanced in this concern, sure he could add stuff all over it, with the added weight. Bottom line much better execution. I would like to know however how beefy his mounting holes are 3" sides on the 2x3's.
Re: Front Steer Rack Conversion - Part Deux [Re: jcc] #1579447
02/16/14 03:49 PM
02/16/14 03:49 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Anyone saying that its not strong enough better start with Lego or something other than cars!
Re: Front Steer Rack Conversion - Part Deux [Re: sshemi] #1579448
02/16/14 07:20 PM
02/16/14 07:20 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
If he used a washer on his bolts they'd be as beefy as any stock k-member! Hell, those things are only two layers of sheetmetal !!
Re: Front Steer Rack Conversion - Part Deux [Re: Stanton] #1579449
02/16/14 07:25 PM
02/16/14 07:25 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
How does this thing compare height-wise to a stock k-member. Judging by the position of the strut mounts relative to the bottom it looks like it would hang a couple inched lower than a stock k-member.
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579450
02/16/14 07:39 PM
02/16/14 07:39 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What does it weight? What control arms are you going to use?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Front Steer Rack Conversion - Part Deux [Re: sshemi] #1579451
02/16/14 07:46 PM
02/16/14 07:46 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Thanx all for the positive feedback! It's much appreciated! Here's the answers to a bunch of the questions.
I designed the k-frame in Solidworks 3D software. It was designed to use the stock lower control arms and strut rod arrangement with a strut rod using a heim end at the front. I plan to get rid of the t-bars and go to coilovers, once I get the shock area reinforced. All of the round tubing is 4130 moly: 1 1/2 dia x .120 wall for the 3 main tubes and 1" x .083 wall for all of the other pieces. Rect. tubing is 2 x 3 x 1/8 wall mild steel and Sq. tubing is 2" x 1/8 wall mild steel. Mounting holes are reinforced with Grade 8, 1/2 flat washers, that are 1 3/4 dia. by about an 1/8" thick.
I built it on a jig. This is one of the only build pic I have.
Weight is 28 lbs bare. I wanted to make sure this thing could handle a pot hole as it is going on a street/strip car. So a few extra pounds wasn't a big deal. It's still alot lighter than the stock frame. I think the stock k-frame was around 40 lbs.
And for reference, the Pinto Rack weighs 12 lbs. A stock manual gear box with the steering arm, drag link, tie rod ends, and idler arm weighs 28 lbs. So, 40 lbs for the new K-frame and rack vs. 68 lbs for the stock stuff.
I got it into the car and it's fits like a glove. I'm really pleased. Here are a few pics of it installed.
Re: Front Steer Rack Conversion - Part Deux [Re: Stanton] #1579452
02/16/14 07:54 PM
02/16/14 07:54 PM
STEFF Offline OP
STEFF  Offline OP
Stock K-frame from mtg. face to bottom is 7". My new K-frame from mtg. face to bottom is 7 3/16", so, 3/16 difference. The lower control arm location and strut rod intersect point at front (centerline of bolt for heim) is in the stock location.
Re: Front Steer Rack Conversion - Part Deux [Re: Stanton] #1579453
02/16/14 07:56 PM
02/16/14 07:56 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I strongly disagree. They are not an open span of 2.75"of 1/8" sheetmetal like the OP's. They are closely gusseted as possible, and welded, granted not well. I think the OP at least, for all his other efforts here, should insure this bolted conection, almost the most single point that chassis forces are channeled thru, does not flex. I will later post a close up of the OEM area, but am sure most are familiar with it anyway.
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579454
02/16/14 08:01 PM
02/16/14 08:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
As others have stated, great job and looks plenty stout but I`m no engineer. I too admire guys like you and wish I had your fab skills................
Re: Front Steer Rack Conversion - Part Deux [Re: Thumperdart] #1579455
02/16/14 08:27 PM
02/16/14 08:27 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Just awesome Stef! That is sweeeet!
Re: Front Steer Rack Conversion - Part Deux [Re: mshred] #1579456
02/16/14 09:16 PM
02/16/14 09:16 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks good, why the heim joint on the steering shaft?
Re: Front Steer Rack Conversion - Part Deux [Re: 1967dartgt] #1579457
02/16/14 09:35 PM
02/16/14 09:35 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
What body style is that built for, a or b/e ?
Post more pics when its all hooked up please.
Re: Front Steer Rack Conversion - Part Deux [Re: Stanton] #1579458
02/16/14 09:51 PM
02/16/14 09:51 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I didn't need one
Re: Front Steer Rack Conversion - Part Deux [Re: 1967dartgt] #1579459
02/16/14 10:17 PM
02/16/14 10:17 PM
STEFF Offline OP
STEFF  Offline OP
The inner steering g shaft isn't supported, coming out of the column. It was either make a bushing to insert into the end of the column or add a Heim. I opted for the heim.
Re: Front Steer Rack Conversion - Part Deux [Re: Stanton] #1579460
02/16/14 11:11 PM
02/16/14 11:11 PM
STEFF Offline OP
STEFF  Offline OP
Built for my 70 Road Runner.
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579461
02/16/14 11:23 PM
02/16/14 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks real nice Steff... fits in there nice also
Re: Front Steer Rack Conversion - Part Deux [Re: MR_P_BODY] #1579462
02/17/14 01:14 AM
02/17/14 01:14 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My recollection is flawed. I have been lately working on my RMS K, and it has a 1.75 opening in K member attaching bolt tube. Below is a 2x3tube next to I believe a typical OEM K. The opening measurers 2.72" in rear and 2.39" in front. OP's front with 2" sq tube is a smaller area. However very importantly there is on all attaching bolt areas a third vertical gusset, 1" from bolt hole center on the third side, and provides most of the mounting surface reinforcement. The pictured OEM flange thickness is .285", with dirt/rust.
Re: Front Steer Rack Conversion - Part Deux [Re: jcc] #1579463
02/17/14 12:04 PM
02/17/14 12:04 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
So a factory is a little more then twice as thick in mounting flange then a 1/8 box tube.
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579464
02/17/14 12:39 PM
02/17/14 12:39 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
I like it! So here's a question...........
Do you plan on making & selling these for A-bodies using using coilovers & retaining the stock, or stock-type LCA?
Re: Front Steer Rack Conversion - Part Deux [Re: 1967dartgt] #1579465
02/17/14 12:54 PM
02/17/14 12:54 PM
STEFF Offline OP
STEFF  Offline OP
There is an extra L-shaped piece welded in the hole area. The total of the main plate thickness and extra L-shaped piece make up the approx 1/4" thickness.
