Re: How much HP? 440-1 500ci [Re: Ari440] #1577748
02/12/14 09:57 PM
02/12/14 09:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
3400 pound duster 511ci rb 440-1s cnc 345s 800/277 roller tunnellram and two 750s going 9.85
it would be nice to have a 3000 pound car , be close to low 9,s
how high are you guys revving these combos im shifting at 6800 and 7200 at the traps
I was building my 514 to shift at 9000... that was
with B-1 M/C heads max ported and a lite rotating assm
Re: How much HP? 440-1 500ci [Re: MR_P_BODY] #1577749
02/12/14 10:27 PM
02/12/14 10:27 PM
gregsdart Offline
gregsdart  Offline
7100, trap 7300. 2100 cfm terminator, 3X intake
Re: How much HP? 440-1 500ci [Re: Ari440] #1577750
02/12/14 11:32 PM
02/12/14 11:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Like Jim say's you need 330 with a heavy car. I've listed no ET till now due that exact fact. Though it's got MPH the ET is slow. Loses it all in the begining 1.345/3.843/5.926@117.75/9.257@147.71 as you can see. I believe this to be a result of 4.10 and a converter thats a little tight. For what it's worth the track wasn't the best this day. It's been 1.318/3.814/5.903@117.75 It doesn't run large tires either 10.5Wx31 Shift at 6800,traps about 6900. Replacing the gear with a 4.30, loosening the converter, and lightening up the trans. Lookin to go 9.0?
Doug
Re: How much HP? 440-1 500ci [Re: dvw] #1577751
02/13/14 02:06 AM
02/13/14 02:06 AM
Hampton,Va
Q
QuickDart 502 Offline
Q
Hampton,Va
1397 hp pump gas 26pounds of boost. That was with 2" tube headers.
Re: How much HP? 440-1 500ci [Re: AndyF] #1577752
02/13/14 02:36 AM
02/13/14 02:36 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a question for some of the dyno stuff on here. While dynos are cool and the numbers are fun they mean nothing to me unless you put it in a car and show me some results. I would like to see what Andy's mill could do in a car at the strip. Dynos are a great tool but not the all end all. As I tell people all the time a good dyno number is great, but 1320' of racetrack can be a very humbling place. Just sayin...
I don't see a -1 headed 500" stock block deal running 8's at that weight without some RPM. It is certainly doable but it is going to take some serious thought and a well working car. Just saying in my experience I do not see a 7200rpm 500" stock block(small bore)engine getting a car that heavy into the 8's. Well at least not without some help. It is not as easy to run an 8 in anything let alone something pulling that kind of weight with a small bore and limit head. Not without some serious RPM anyway.
FWIW I have been 9.0's at 3470 with a stock block B1 deal. Nothing exotic for sure but there is a good deal more head flow on the B1's than the -1's. Never was dynoed but was a basic 512" deal. Shifted at 7800 through the lites t 8000. Not a completely optimized deal but ran well for what it was. One last tidbit a 9.30 is a LONG way from 8.99. Especially with the "limitations" listed. Not impossible by any means if you are willing to do what it takes.
Re: How much HP? 440-1 500ci [Re: dvw] #1577753
02/13/14 03:06 AM
02/13/14 03:06 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Like Jim say's you need 330 with a heavy car. I've listed no ET till now due that exact fact. Though it's got MPH the ET is slow. Loses it all in the begining 1.345/3.843/5.926@117.75/9.257@147.71 as you can see. I believe this to be a result of 4.10 and a converter thats alittle tight. For what it's worth thae track wasn't the best this day. It's been 1.318/3.814/5.903@117.75 It doesn't run large tires either 10.5Wx31 Shift at 6800,traps about 6900.Replacing the gear with a 4.30,lossening the converter, and lightening up the trans. Lookin to go 9.0?
Doug
You just might get it..............
Re: How much HP? 440-1 500ci [Re: Thumperdart] #1577754
02/13/14 10:03 AM
02/13/14 10:03 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Thanks for all the replies so far
Rpm, yes I need more.
Mine is all done by 6700, might be my cam
I'm already at a honest 16 to 1
Re: How much HP? 440-1 500ci [Re: Al_Alguire] #1577755
02/13/14 10:28 AM
02/13/14 10:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree 9.30 to 8.99 will not be an easy trek. Nibble away a little at a time.
Doug
Re: How much HP? 440-1 500ci [Re: dvw] #1577756
02/13/14 05:22 PM
02/13/14 05:22 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Gregsdart, I sent a PM
I can't seem to look at my replied messages, just want to make shure you got it.
