Re: Is this possible? [Re: GTX MATT] #1576396
02/12/14 08:10 PM
02/12/14 08:10 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quote Depending on how much bowl work was done they may flow 250-260 cfm or so.
Are the heads 346s or 452s by chance? A basic bowl blend by somebody knowledgable will get a stock valve 346 in the 260 range.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Is this possible? [Re: GTX MATT] #1576397
02/12/14 09:09 PM
02/12/14 09:09 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
, and he has headwork that the pure stock guys don't have.
Re: Is this possible? [Re: dvw] #1576398
02/12/14 09:18 PM
02/12/14 09:18 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Car has to weigh at least 3800 lbs. Do the math, 426 HP is not going to go [Email]114@3800.[/Email] At best 110-111. And I'll bet it's closer to 3900-4000lbs. Am I correct?
Doug
Agreed. I just don't know with certainty any specifics about the car.
It could weigh 3500 lbs and the track day could have been -2000 DA. Unlikely of course.
Re: Is this possible? [Re: BSB67] #1576399
02/12/14 09:20 PM
02/12/14 09:20 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
, and he has headwork that the pure stock guys should not have.
There you go fix it for you.
Getting old just means you were smarter than some and luckier than others.
Re: Is this possible? [Re: dannysbee] #1576400
02/12/14 09:49 PM
02/12/14 09:49 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
You do have a point Russ
