Re: Data Aquisition.......Q
[Re: hemi-itis]
#1576366
02/11/14 10:09 AM
02/11/14 10:09 AM
Posts: 12,409 Taxes & Virus's R-US, NY
Dragula
There are racers with Racepaks and people who wished they did. Never regret buying the best.
Been trying to figure out what the sportsman one is with a dash...Their website stinks.
Sportsman $825 Dash, not sure which one, $? What else do I need?....if I can't figure out what the heck I need, I can't even compare them. What options does the system have? Which dash works with the sportsman, do I even need the Sportman if the dash has a logger? Very confusing...
I'm no expert,but if you get the sportsman,you can use the display dash if you want,but you don't have to.Just download the data to a laptop.If you get the logger dash,you don't use the sportsman because the logger is in the dash
How do you down load it from the dash?
[Re: Dragula]
#1576369
02/11/14 01:39 PM
02/11/14 01:39 PM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
Using the Serial Communications Port to Upload Data to your PC To upload data from your data logger to your PC using the serial port, connect your PC to your data logger system using the serial communications cable provided with your system and turn on the power to your data logger. Next select the New file icon in the program taskbar or the New menu item selection located in the File main menu. The following dialog box will be displayed and you will be asked to select which configuration file to use. The list on the left-hand side of the Select Configuration box will display all of the file folders in your RacePakData subdirectory that contain valid configuration files. Select the folder on the left that is named VDash and the serial number of your dash. For instance, an Ultra Dash with the serial number 1001 would be named VDash_1001. The list on the right will now contain the list of configuration files contained in this folder. Select OK to begin the data transfer.
[Re: hemi-itis]
#1576370
02/11/14 02:17 PM
02/11/14 02:17 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
I prefer the SD card versions of the Racepaks. Much easier to pull the SD card and take it in the trailer to the laptop. Rather than taking the laptop and serial cord to the car. I have a dash as well but did not use it in the S/ST car. I prefer gauges to see what is happening real time. Dash can be hard to read but I imagine once you get used to it it is fine. We did have the dash in the heads up car.
[Re: Al_Alguire]
#1576372
02/11/14 02:47 PM
02/11/14 02:47 PM
Dragula
Yeah its SD card or wifi...Not going down the serial cable rout anymore. Time to embrace the tech...
[Re: pittsburghracer]
#1576374
02/11/14 03:56 PM
02/11/14 03:56 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
When i was shopping for a racepak ended up talking to this guy. He was real helpful on walking me through everything and getting me everything i needed, and customer support. Ended up giving him the business. he answered all my questions. I saw a previous post that mention Holts as a dealer as well. if you go with a dealer they will help walk you through the process and work with you. http://www.motorsportsinnovations.com/
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
