Re: Question about AN fuel line and fittings
[Re: 80fbody]
#1576108
02/10/14 12:48 PM
02/10/14 12:48 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Jegs now has free shipping on everything. Bought several $5-$10 items over the last year this way. Big fan.
YUP. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Polarapete]
#1576110
02/10/14 09:39 PM
02/10/14 09:39 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
One last question and I'll end the hijack.
Original A727 cooler lines use these fittings from the line to the tranny/radiator--> -AN5 (1/2-20) Male to 1/8 NPT Male, yes?
Get out your elementary school protractor and check the angle of the male taper...if it is 45* it is SAE and if it is 37* it is AN and JIC. For consistency it is probably SAE, not AN/JIC
Here's the fitting. It's a 45.
So, it's an SAE 1/2-20 Male to a 1/8 NPT Male. Have I got it?
![](http://i62.tinypic.com/2e2jdpg.jpg)
[Re: Polarapete]
#1576113
02/20/14 03:39 PM
02/20/14 03:39 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
You take the original fitting off and screw the NPT to AN fitting into the pump body in its place.
I just want to make sure I got you right. Take a look at the picture, your saying I can remove the fitting that the arrow if pointing to in the pic?
And that will give me an opening to screw my 3/8pipe - -6AN adapter into?
I've had the hard line off and had a wrench on the fitting a couple times, and it does not want to budge. Just want to make sure that this fitting is removable before I break anything by twisting too hard on it.
It almost seems that I'm bending the body of the fuel pump, or getting ready to break the fitting off, it just doesn't want to move.
[Re: Polarapete]
#1576117
02/21/14 02:10 AM
02/21/14 02:10 AM
MileHighDart
Lyons, CO
I have to apologize...I misled you with the fitting on the pump. The last mechanical fuel pump I played with was a Hemi high performance pump that I put on my 440 in the '64 Polara. It was an expensive and totally unnecessary change from a stock 440 pump. The pump produced too much pressure and volume for the Edelbrock carb and created flooding issues. Shot myself in the foot with that. Anyway, the pump body was held together with many screws and you could rotate the bottom half to allow the feed and exit ports to better align with the hoses. That pump had tapped NPT holes for the fittings to screw in, so I was thinking of that and related it to a mild 318 stock pump. And then I walked out and looked at the pump on the 318 in my D100
Don't worry about it. I should have taken the time to try to remove that fitting from the pump before I ordered parts. Then I would have known exactly what I needed. But as it is, I ordered a premade hose "kit" for carb to pump. I came with a 90degree 3/8npt to -6AN for the pump end. So guess I'll just return that premade hose, and order the exact fittings I need and a short length of hose, now that I have a better idea what exactly I need.
