Re: G56 clutch problems. [Re: RedRam] #1575556
02/11/14 11:39 PM
02/11/14 11:39 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Those fittings are great! Knock out the roll pins at master and slave, remove line, add these, then use braided steel AN hose.
That's how I adapted the ram SRT-10 Hyd to bearing to my factory master to install the T56 in my Dakota.
Fits together like the factory designed it that way!
**Photobucket sucks**
Re: G56 clutch problems. [Re: RedRam] #1575557
02/12/14 09:08 PM
02/12/14 09:08 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Not sure if I am understanding things right here, but if you are saying the slave isn't stroking, maybe the master is bypassing, internal leak?
What does the inside of the firewall look like?
I had a '93 Jeep Wrangler, same symptoms (I think) clutch master was leaking at the firewall, and not releasing the clutch.
there was no evidence of leakage, pulled the slave and yes it stroked, once. Lost pedal, then I messed the hose up while shoving the rod back into the slave cyl causing it to leak at the angled fitting on the hose end of the slave.
Hi RedRam! Long time no yadda yadda. What was the temperature when all this began?
Re: G56 clutch problems. [Re: redraptor] #1575558
02/12/14 10:24 PM
02/12/14 10:24 PM
Appalachia
RedRam Offline OP
RedRam  Offline OP
Appalachia
Hey Red, Congrats on the sale.
Been a while since it was above freezing, I'd say from the teens to low 30s.
My clutch problem is either the throw out brg or pressure plate. Tried a different m/c-slave setup today, no joy.
Trans has to be pulled. I will be ordering a new solid flywheel & clutch kit tomorrow.
Re: G56 clutch problems. [Re: RedRam] #1575559
02/13/14 09:58 PM
02/13/14 09:58 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Thanks! Just wondering since the extreme cold seemed to play havoc with everything at work including hydraulics that may have moisture trapped in the lines.
Re: G56 clutch problems. [Re: redraptor] #1575560
02/26/14 11:02 PM
02/26/14 11:02 PM
Appalachia
RedRam Offline OP
RedRam  Offline OP
Appalachia
Finally back on the road. Pressure plate died. Throwout brg was ok, clutch plate and flywheel looked great. Bought a heavy duty single disc Southbend setup that has a lot more clamp than the stock setup did. Engagement is smooth, pedal effort is definitely higher than stock, but I will get used to it. Entire clutch kit was little over $1200 and install was $457 at my local dealer.
Getting away from the stock dual mass setup, I was concerned about trans/gear noise that some after market clutch users report. Only thing I noticed during my 25 mile ride home was when/if you lugged the motor below 1000rpm, you can definitely hear the gear rattle in the trans. Hope to get more than 69k miles out of this one.
No complaints with my dealer's service dept, was expecting more than a $457 bill, and they seemed to have no problem installing non-chrysler parts that I brought to them.
Re: G56 clutch problems. [Re: RedRam] #1575561
02/26/14 11:22 PM
02/26/14 11:22 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Good luck, let us know when the gear rattle goes away and it is time for a new trans...
JB Rhinehart, Realist
A-Body's RULE!
Re: G56 clutch problems. [Re: Rhinodart] #1575562
02/27/14 09:16 AM
02/27/14 09:16 AM
Appalachia
RedRam Offline OP
RedRam  Offline OP
Appalachia
Will do
BTW, exactly which Southbend model did you have so much trouble with? And, who's clutch disc solved all of your trans problems?
Re: G56 clutch problems. [Re: RedRam] #1575563
02/27/14 01:21 PM
02/27/14 01:21 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I don't have the info anymore, the truck did not belong to me. I will never have my trans problems solved, it obviously has to be me...
A-Body's RULE!
