Re: Found the performance limits
[Re: quickd100]
#1574233
02/06/14 04:58 PM
02/06/14 04:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Dave.. what are the specs on that GT45.. when does the boost start coming on.. your running a single turbo right... on a stock 318
[Re: MR_P_BODY]
#1574235
02/07/14 12:20 AM
02/07/14 12:20 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Mike,I'll look in the morning. Just got home, pulled all the pistons and rods out for inspection. Number 5 piston was toast, ringlands broke, 2nd ring broke, skirts broke. Everything else looked great. Boost comes on about 3000rpm when the secondaries are open. Single turbo.Dave
[Re: quickd100]
#1574243
02/14/14 05:25 PM
02/14/14 05:25 PM
Posts: 1,739 Grand Forks, ND
Hemi_Ram
Grand Forks, ND
" The 536hp/586ftlbs. were recorded at 4800rpm@24lbs. of boost" Dave that little 318 is approaching numbers close to my 512 Are you still planning on putting it in a D150? Should be an eye opener at the lights.
[Re: Hemi_Ram]
#1574244
02/14/14 08:45 PM
02/14/14 08:45 PM
quickd100
nielsville, minn.
" The 536hp/586ftlbs. were recorded at [Email]4800rpm@24lbs.[/Email] of boost"
Larry the motor is already in the 'Creampuff'. I hurt the motor doing some 'testing' out on the highway . Exhaust pipe dropped off and it saw 20lbs of boost on 87 octane for a short time. Ebay came to the rescue, new set of pistons and rings for $147 to my door. Dave
