Re: WOO HOO! My Cummins swap is officially underway! [Re: Guitar Jones] #1572782
03/07/15 03:28 AM
03/07/15 03:28 AM
Pyeongtaek, South Korea
69HemiGTX Offline OP
Yes, mine is a double-joint shaft. I posted the following in the thread you linked to.
I plan on drilling a hole into (but not through) the splined end of the factory steering column. I will then install the Borgeson shaft, thread a tap into the setscrew hole, and then tap the newly drilled hole so a longer setscrew can engage both the Borgeson and Dodge parts. I'll buy a longer setscrew if I need to. See the pic below if you're confused. This will keep the u-joint from ever sliding off. The setscrew will experience minimal torsional loads, mostly single-shear stress.
Here's my blueprint:
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572783
03/07/15 12:42 PM
03/07/15 12:42 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
That orange looks familiar.....
We built Frankenstein a few years back...
Cummins, NV4500, Dana 61-70....
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: WOO HOO! My Cummins swap is officially underway! [Re: dynotune440] #1572784
03/07/15 12:48 PM
03/07/15 12:48 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
That's nice. My buddy has a nice rustfree crewcab dually 2WD and a Cummins donor truck. I'd buy it but I just don't need a crewcab.
Sheldon
Re: WOO HOO! My Cummins swap is officially underway! [Re: RUNCHARGER] #1572785
03/08/15 05:03 AM
03/08/15 05:03 AM
Sheldon
There's never enough room when you're 6' 6" tall. I always say it's better to have it and not need it, then need it and not have it. Plus, it irritates the hippies.
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572786
03/08/15 05:22 AM
03/08/15 05:22 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
What are your plans for the 2wd front end? I have a single wheel truck I'd like to convert
Re: WOO HOO! My Cummins swap is officially underway! [Re: wyldebill] #1572787
03/08/15 11:03 AM
03/08/15 11:03 AM
The front wheel adapters? Honestly, I figured they'd go to the scrapyard and become Chinese goods. If you're interested, they'll eventually be available, but I have no idea when. At least they won't be too far away, only about 360 miles. I'll make a note that you want them and drop you a line when they come off.
Re: WOO HOO! My Cummins swap is officially underway! [Re: 69HemiGTX] #1572788
03/08/15 11:06 AM
03/08/15 11:06 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
Thank you
