Re: 3310 Jet Reccomendations
[Re: Kern Dog]
#1571848
02/02/14 01:51 PM
02/02/14 01:51 PM
Posts: 12,138 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
2,000 and up probably means you are already on the main circuit. That would seem to indicate that the issue is with the idle and low speed transition. I'm thinking the slot needs more fuel.
That is, IF, the issue is carb related.
Master, again and still
[Re: DaveRS23]
#1571850
02/02/14 05:21 PM
02/02/14 05:21 PM
Posts: 15,401 Omaha Ne
TJP
Omaha Ne
[Re: PossessedDuster]
#1571855
02/06/14 12:37 PM
02/06/14 12:37 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The Street Demon will be the next carb on my Barracuda. And it will replace the 3310 that is on there now.
[Re: Junky]
#1571857
02/06/14 04:13 PM
02/06/14 04:13 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I'm running the 383 big block with some modifications. However, my 3310 needed to be really richened up to take a stumble out of it. Try this: Go to the biggest shooter and the green or blue accelerator pump cam and see if it goes away. It may run too rich, but what the hay. Then at least you'll know if it's the carb being lean. Work backward from there if the "pop" is gone. Summery: Biggest shooter, fastest shooting accelerator cam and 18 degrees timing. Don't forget to look for vacuum leaks. If that doesn't help, wont that at least tell you it isn't the carb? Just saying.
And along with that, I would recommend a 9.5 or so power valve. Every 3310 I have ever messed with worked best with the quickest opening power valve, sometimes even a 10.5.
#1571861
02/18/14 12:51 PM
02/18/14 12:51 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Have you actually had the chance to drive the car so that the engine could be put under load since the popping has come up? If a cylinder was partly fouled, freewheeling the engine may not clear it.
Maybe try a new set of plugs when you can drive the car. I have had a fouled cylinder back fire when revved, but would idle okay.
#1571862
02/18/14 01:04 PM
02/18/14 01:04 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I would put a faster (bigger) accelerator pump cam on it and 37 squirters. also put at least a 7.5 power valve in your cam is small and 4.5 is for huge low vacuum cams. make sure accelerator pump is adjusted correctly so it provides a shot of fuel as soon as possible! New ethonal fuels need lots of stable when car is sitting they draw water like crazy. Jetting stock is usually good if 72's you can try 74 but no larger. Your problem is the transition from the idle circuit to the high speed. causing a monentary lean condition before the jets take over. The power valve is one of the things designed to help that. as you quickly open the throttle vacuum drops and the power valve opens allowing extra fuel in to help in that transition as do the accelerator squirters. the lower the number of the power valve the later it opens. pop. your vacuum sneaking up on the throttle with that mild cam my be way up to 14 or more! So you need a little more fuel quicker the power valves and accelerator pump is the way to get it. you could slow down advance curve a smidge (slightly heavier springs) as long as you get 35 to 38 total (vacuum advance unhooked) by 3200 or so maybe even run less initial depending on the amount of advance in the distributor.
