Re: High RPM Misfire -- SOLVED!
[Re: 340RICK]
#15727
07/07/05 12:08 PM
07/07/05 12:08 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Good work Jim. Electrical gremlins can be a real PITA.
2 kids and a dog
[Re: NewMemberAgain]
#15728
07/07/05 12:47 PM
07/07/05 12:47 PM
Posts: 16,932 NC
440Jim
NC
I thought that it was a no no to run solid core spark plug wires with an MSD ignition?
NewMemberAgain (BP), Those are MSD Heli-core suppression wires. The label on the wires uses the word "solid suppression" but that is misleading. The wire is wound around a core to give noise suppression. They are approved for the MSD ignitions. From the instructions, "A good quality, helically wound wire and proper routing are required to get the best performance from your ignition, such as the MSD Heli-Core or ..."
![](https://board.moparts.org/ubbthreads/upload2/1828430-MSD_Helicore_wire.jpg)
jamesc, I asked the MSD rep about the MSD noise capacitor for the power leads on the box. He said that was to stop the MSD from interfering with other equipment. Not my problem. But I agree with you it might be good insurance and can't hurt.
moper, A shielded cable has an electrically conductive material covering the insulated wires inside. This material is grounded at one end of the cable. This shields the inner wires from electromagnetic fields outside the cable.
'Solid Core Wires'
[Re: 440Jim]
#15733
07/07/05 10:29 PM
07/07/05 10:29 PM
Posts: 238 St. Catharines, ON
NewMemberAgain
super street
super street
St. Catharines, ON
Wow! That is great news Jim. That means for me, that i do not have to buy another set of sp wires. Those wires as mentioned are the sames one that I have, but never used because. I am glad that i asked, maybe it might help my msd box... Thanks again Jim for clarifying that. ![](/ubbthreads/images/graemlins/smile.gif) BP
Re: 'Solid Core Wires'
#15734
07/07/05 10:54 PM
07/07/05 10:54 PM
Posts: 16,932 NC
440Jim
NC
Just to show I am not made of steel... Revving the engine in the garage, in neutral to 6000 or 7000 rpm is a little un-nerving. But I did warm the engine before I did it, and that included both the water and the oil. Then I don't like "zinging" the RPM, but rather did a controlled steady increase in RPM. It started to sound a little like listening to NASCAR on TV as the engine passed 5000, 5500, 6000, 6500... After the first few times, it actually sounded nice. But a day later, thinking back, it was a little stressful! It was much worse when it would misfire at 5000 rpm, rather than the beautiful sound of the steady climb past 6000...
[Re: B1Ken]
#15736
07/09/05 10:14 PM
07/09/05 10:14 PM
Posts: 842 Baltimore,MD
Bill_LBSR
Baltimore,MD
B1Ken, are you running a Digital MSD (Digital 6,7)or are you running an Analog box (7AL2,3)?
LBSR
[Re: B1Ken]
#15737
07/10/05 10:49 AM
07/10/05 10:49 AM
Posts: 16,932 NC
440Jim
NC
I read your "fix" (sheilded leads) but was wondering if perhaps a weak magnet in the pick up might make the system more sensitive to noise. I also have a one wire GM alternator mounted close to the distributor, but ran this way for years without trouble.
Ken, Do you have the shielded cable to the distributor? I tried two different magnetic pickups in my distributor during the trouble shooting, and they acted the same. I guess if one is deteriorating and the signal is not as strong, the signal to noise ratio would get worse and might reach the MSD interference limit.
I was running for years also. It started with the addition of 15 amps more alternator load and I am thinking that more alternator output made more noise and reached the threshold. Also I noticed the Delco alternator would be better when cold, and after heat soaking and round robin, it got worse (interference).
After trying all those things and each time the car misfired, then doing this cable mod and having it work perfect, I felt so relieved. I am going to mod my spare distributor the same way. Maybe I should log off this computer and go to the shop and do it, now!
[Re: Bill_LBSR]
#15740
07/11/05 04:27 PM
07/11/05 04:27 PM
Posts: 1,919 Long Island, NY
B1Ken
Long Island, NY
Bill: I'm using a 7AL2 (analog) Jim: I was talking to my son last night about the problem and I remembered that I had the alternator repaired midway through the season last year. The repair definitely increased the output of the alternator. The signal cable from the distributor runs within 3" of the alternator and is not shielded. I think I'll try your recommendation. Actually, though, I'd like to hook up the crank trigger again. My Chevy buddy, who used to break starters like me, said that the new style MSD spark retard, works great for him. I just ordered one. One way or another, I have to get this fixed. I have a points race at Delmar this week and the Sports Nationals at Columbus at the end of the month. It ain't easy dialing this thing with it running like crap on the top end.
[Re: wildcargo]
#15743
07/12/05 10:29 AM
07/12/05 10:29 AM
B1Ken
Long Island, NY
Jim after reading this I went out and put a ground strap on the altinator. I wasen't having a problum but I guess it cant hurt.
I can't see what this would accomplish, since the alternator is bolted directly to the engine. If the alternator wasn't grounded already, it wouldn't put out any current.
