Re: Turbo Question
[Re: topfueldart]
#1571537
02/02/14 05:59 PM
02/02/14 05:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I agree with a lot that's been said already. Compressor A/R is a useless measurement for our purposes, but turbine A/R is very important. Trim is also a term rarely used, just look at the compressor wheel measurement.
On 418 inches, the twin 1.05 turbines might be a bit laggy, but they will work. Don't be afraid to look at build threads of Chevy and Ford combos online, similarly sized engines will offer good info about the spool characteristics of a pair of those turbos.
Looks like I'm gonna try a 60 and a .96
A as in 1? or still twins? I think twin 60/61/67's, would work very well with .96 turbines.
Twins.... as in 2... so you believe I'm headed in the right direction
Re: Turbo Question
[Re: topfueldart]
#1571538
02/03/14 03:12 PM
02/03/14 03:12 PM
MR_P_BODY
Next Question... is there really any difference between the inlets of the turbine... one rectangular hole or 2 smaller ones... does it help or hurt either way Thanks
Re: Turbo Question
[Re: MR_P_BODY]
#1571539
02/03/14 03:34 PM
02/03/14 03:34 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Divided housings are designed for split manifold diesel aplications. They flow less than an open version of the same a/r, and are usaully cast of a lower nickel content iron. I would pass on these, but I personally have used them. They did end up cracking around the flange inlets, But I was "heat stacking" them, so other's results may vary...
Re: Turbo Question
[Re: TRENDZ]
#1571540
02/03/14 04:03 PM
02/03/14 04:03 PM
MR_P_BODY
Thanks... good to know... so I'll be looking for the larger single opening style
Re: Turbo Question
[Re: MR_P_BODY]
#1571543
02/07/14 02:38 PM
02/07/14 02:38 PM
Posts: 6,567 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I think what he was saying is that with E85 or methanol, an intercooler isn't as much of a gotta have at the boost levels that most mere mortals can afford. With a blow-thru setup the alcohol vaporizing cools down the charge. I'm sure you have seen NA alcohol cars at the track with frost on the intake even on the hottest days. Highschool physics was a lifetime ago but I think the principal was called "latent heat of evaporisation" or some such. If you are running gas as your main go to fuel the intercoolers are pretty much gotta have if you are planning on more than single digit boost levels. Kevin
Re: Turbo Question
[Re: Twostick]
#1571544
02/07/14 02:46 PM
02/07/14 02:46 PM
MR_P_BODY
Kevin
Being this will be my Drag Week car I cant plan on E-85(no such animal in parts of the country) so my plan is regular pump fuel... would like to run 87 but race on 93 octane... that will require some testing to see what pressure I can get away with on the 93 so the inter cooler are a must(in my opinion).. which I have a couple... its not like I have to spend money on them
Re: Turbo Question
[Re: Quicksilver440]
#1571546
02/07/14 03:33 PM
02/07/14 03:33 PM
MR_P_BODY
Not that I really know anything about this stuff...but you could even consider running the intercooler AND an Alcohol Injection setup while racing....
I may end up using a meth/water injection set up but if I can get away with out it I would prefer not using it... I still like the KISS ways of doing it... once I get this build up and running I'll test to see what I can get away with
Re: Turbo Question
[Re: TRENDZ]
#1571548
02/07/14 04:02 PM
02/07/14 04:02 PM
MR_P_BODY
You can get away with alot more if you run a cam with longer duration than most "turbo cams". You get a proportional egr effect with rising boost/ backpressure levels. Trust me , this works. you will be able to run any pump swill along the way.
I assume due to closing the valve a bit later
