Re: Anyone ever use a catalytic converter for a muffler
[Re: 360view]
#156988
11/26/08 12:04 PM
11/26/08 12:04 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I ran my '96 ram with the cat only, then split to dual 2.25" straight pipe out the back. it wasn't too obnoxiously loud. those cats are kinda restrictive though. a higher flow cat would've probably been too loud.
[Re: patrick]
#156989
11/26/08 02:07 PM
11/26/08 02:07 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
I have a 2002 non-Mopar truck with a V8 and just run cats. It sounds pretty good and is surprisingly quiet at idle. My exhaust is cut off at the rear of the extended cab. Everything about the engine and exhaust is stock other than it being cut.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Anyone ever use a catalytic converter for a muffler?
[Re: dogdays]
#156992
12/02/08 10:06 PM
12/02/08 10:06 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
My 81 Charger 2.2 had a converter and a resonator, factory. My 74 slant "FartDart" is running a straight pipe out to the bumper. It sounds neat, except for that damned cracked manifold ![](/ubbthreads/images/graemlins/image_294343.gif)
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: dmerc]
#156995
12/03/08 02:01 PM
12/03/08 02:01 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Unless you have a closed loop system or an air pump I think you will just melt the cat.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: dmerc]
#156997
12/03/08 04:13 PM
12/03/08 04:13 PM
Posts: 7,759 So Cal
HealthServices
So Cal
A proper working cat needs the exhaust mixture to cycle from lean to rich, back and forth. Rich enough to get a little fuel in there, then lean enough to get a little oxygen in to burn it off.
On a late model car this can happen several times a second
Allen
[Re: 360view]
#156999
12/04/08 11:16 AM
12/04/08 11:16 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
A hollow cat sounds good and not restrictive and with a properly tuned engine you can still pass an emmisions test.
