what primer on bare metal ? body men !!
#1569766
01/27/14 10:13 PM
01/27/14 10:13 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
just started working on project car again . car was in primer when i bought it , surface rust was starting to show through the 1/4 panels so i D a sanded it with 80 grit and it all came rite off down to bare metal . The metal has lots of scratches looks like they striped it with 50 grit . I was able to sand most out with the 80 grit.. What primer self etching or epoxy or just a 2K urethane. I was gona hit the bare metal with 180 and the paint store guy said no just use the urethane , don't sound rite . I did body work in the late 70s to early 90s so all this is new !! to me . Im old school putting filler on top of primer makes me wonder ? I did the fendrs and doors , bodywork over bare metal then urethane hs 2k on top of the filler . so which is better to start with self etching or epoxy ? I got 2 quarts of sem self etching that epoxy is expensive !!! then a good sand able filler primer for all those scratches whats a good affordable one ? thanks
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: what primer on bare metal ? body men !!
[Re: sparcy]
#1569767
01/27/14 10:21 PM
01/27/14 10:21 PM
Posts: 1,545 USA
hudsonhornet7x
USA
Epoxy all the way. Follow the manufacturers reccomendations about prep.
Etch primer is used in collision shops where speed is a priority. It does okay.
Epoxy primer is used by restoration shops as they are not in a hurry. Epoxy is best.
2k primer filler is used on bare metal by monte carlo driving mullet heads who don't know any better! J/K!
[Re: ek3]
#1569771
01/28/14 02:07 AM
01/28/14 02:07 AM
Posts: 5,669 South Dakota
hotairballoonpilot
South Dakota
All very good replies. I agree epoxy is way to go BUTT. Watch how smooth you get it and keep your paper changed out. If you try to save $ by using paper a long time you actually will get to a point that you are not cutting the metal just more or less polishing it. Epoxy is a strange animal. It's more a chemical bonding product but still needs that mechanical bond you get with a sand scratch profile. Really watch your top coat times. Epoxys are a very slow drying product which is the reason why they (in PPG Products) have 3,5 and 7 day top coat windows depending on not only product but catylist too. I would agree on the Omni/Shopline Epoxy being close to the original DP. Naturally it is lead free too. I have been told the shopline epoxys are a 3 day top coat where as the DPLF 401 is a 5 day but the 402 is an 8 hour window. I have been using the DPLV series recently. Not totally a true surfacer product that's direct to metal but not a true epoxy either. Will actually powder up like a surfacer and not gum up like an epoxy if you have to sand it. Say priming something and getting back on it after the 7 day top coat window. It isn't designed to replace a surfacer but can and does do some filling. It may be worth looking into if you are spreading a project out over months or years. It's not a cheap product but if you figure you put epoxy down then month later sand it all or partially off to continue where you left off its cheaper cause you can hand sand it to prep it for surfacer.
Contact Me about AMD Prices
[Re: sparcy]
#1569774
01/28/14 09:08 PM
01/28/14 09:08 PM
Posts: 654 MN
astrobuf
MN
You will want to use Epoxy primer. I use MetalPrep before I spray the epoxy when I can't sandblast the surface as there are always pits. If this is old metal, sanding will not clean the pits out. Follow instructions carefully as you must clean the surface and neutralize before the epoxy. Do note that you must paint the epoxy within a week with primer etc, else you will need to scuff the surface when you shoot next. Astrobuf ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: hotairballoonpilot]
#1569775
01/29/14 02:34 AM
01/29/14 02:34 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The roof on my '69 Coronet 500 had surface rust, and after sanding, and acid cleaning, prep wiping... I used a thin coat of the PPG etching primer? Not even sure it was a primer, maybe an adheasion promoter, it was really thin and almost clear/yellow color (this was 20-years ago.) I then used the Epoxy primer over that.
If you used an acid metal prep then used an etch primer(sounds like the 1791 if memory is good) you got lucky if it's still on. The preach big time don't acid metal clean(dx579) then etch prime as its to much acid on metal and can cause adheasion issues. It's not as bad as if you sandblasted something then metal prepped cause there a person will not get the acid out of the sandblasting profile.
Your right about the acid cleaner. It worked great on the rust, but left a surface residue. I think I was able to clean the residue off with some surface prep or acetone? I know that I did clean the residue off before priming the roof.
