Anyone use Stato-Seals when sealing a bulk head?
#1569402
01/27/14 01:14 PM
01/27/14 01:14 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Anyone use one of these types sealing washers when plumbing their oil pick up lines to the pan?
Earl's makes them up to size -10 so I haven't found any for -12 yet but I'm sure someone makes one, I think the OD for a -12 is 1 1/16".
They are basically like a crush washer with a built in O-ring, I'm thinking this will work better than just and o-ring.
I also looked as using the teflon washers but if I can find one of these Stato-seals for -12 I think they will be the ultimate sealing solution.
Does anyone know where I can buy them on line for -12.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Anyone use Stato-Seals when sealing a bulk head?
[Re: WadeMetzinger]
#1569403
01/27/14 02:03 PM
01/27/14 02:03 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
i used Dowty Seals on mine earls 178117ERL, they are similar to the Stato-seals
Joe
Without Data, you’re just another guy with an opinion.
[Re: Dduster]
#1569406
01/27/14 05:02 PM
01/27/14 05:02 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
I think everyone may be referring to the seals Michael Doty makes at Doty Manufacturing. You can find them here. Michael is a great guy and a mopar guy to boot. http://dotymi.com/Automotive_Home.html
[Re: Al_Alguire]
#1569408
01/27/14 06:13 PM
01/27/14 06:13 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
That's what I used years ago, I only needed one and I gave the 2nd one away.
[Re: WadeMetzinger]
#1569414
12/08/14 08:57 PM
12/08/14 08:57 PM
WadeMetzinger
Tulsa, Ok
