Re: All new brakes, low and hard pedal
[Re: ChallengerGary]
#1568437
02/04/14 11:29 AM
02/04/14 11:29 AM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
do you have an adjustable valve on the rear line to adjust the rear brakes from overpowering the fronts?
Not yet. Guess that is the next step...
When I had a drum brake rear I plumbed in a adjustable valve for the rears. I also used the truck wheel cylinders. I never had to use the valve it was always wide open and never had a problem locking up the rears first?
[Re: brads70]
#1568438
02/05/14 05:11 AM
02/05/14 05:11 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
did you have a front drum setup as well? I have read that the problem lies more on when you have a disk front/drum rear proportioning valve when switching to disk brakes on all 4 corners
[Re: dangina]
#1568439
02/05/14 05:42 AM
02/05/14 05:42 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Are all the caliper bores and wheel cylinder bores the correct size for that bore of master cylinder? (and what are they) Bendix or Raybestos catalogs used to provide this information. Is the brake light switch adjusted too tight (meaning the pedal cannot fully return) which would have the same affect as the master cylinder pushrod being too long and covering the rear compensating port in the master cylinder which would give a low pedal. As far as the assist goes, I'm wondering if the booster size is too small in diameter. Most of the OE mopar stuff was 10 or 11" if I remember right. Some of the street rod stuff use a small diameter dual diaphragm booster, but it doesn't sound like that is what you have. I can't think of any power brake old mopar with functioning assist that had a hard pedal with the engine running stock. "Squishy" is the term that comes to mind. as far as the rear brakes locking up (if the wheel cylinder bores are matched to the master), are the backing plates grooved? Are the primary shoes (shorter length friction) torwards the front of the car? Are the primary and secondary return springs in the right spots? Are the parking brake cables adjusted too tight?
Did the customer provide any info on how the brakes were before changing all this stuff? (was this a problem prior to changing the booster/master?)
Maybe start by isolating the master - replace one or both lines with a plug(s) and see if the pedal function is correct. we don't have any idea what the original application was for the booster/master on there now other than it came from ebay.
[Re: V8val]
#1568446
02/06/14 12:11 PM
02/06/14 12:11 PM
Posts: 2,143 Port Saint Lucie, FL
ChallengerGary
Sorry to do my first post here, but it sounds to me like maybe the hole in your brake pedal arm is maybe in the wrong spot? Where the pushrods connects to the arm? An inch up or down can make a huge difference......
I will take a look at that - thanks
#1568447
02/06/14 08:08 PM
02/06/14 08:08 PM
moparpollack
Lil Herman
Lil Herman
85086
Those small Chinese brake boosters are complete junk. We have had better luck with small import booster that were used.
[Re: V8val]
#1568449
02/07/14 02:02 PM
02/07/14 02:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Oh I see, I've only seen a body stuff. Thanks for filling me in. I'm in Australia, all our Chrysler stuff is just a brake pedal with different positioned holes in the arm for different brake set ups.....
Well, maybe Chrysler Australia does it different, but in US A bodies there is a, for lack of a better way to describe it, step down linkage between the firewall and booster to drop the pedal ratio in a power brake setup. In a manual setup the master cylinder just bolts to the firewall with a stiffening plate and different pushrod, same pedal assembly, no extra holes.
[Re: Supercuda]
#1568450
02/07/14 06:44 PM
02/07/14 06:44 PM
Posts: 29 Queensland Australia
V8val
Well there ya go Thanks for the explanation
[Re: V8val]
#1568451
02/07/14 07:38 PM
02/07/14 07:38 PM
Supercuda
About to go away
About to go away
up yours
Well, since y'all got the steering wheel on the wrong side they had to do something. Wouldn't surprise me if they used Holden (GM) sourced parts and I know GM, at least here in the states, does use different holes in the pedal setup.
