Re: 1969 Coronet R/T referance phots needed
[Re: RoadRunnerJD]
#1568328
01/27/14 11:06 PM
01/27/14 11:06 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
I asked on the A12 site. It serms that you could order the A01 light package with the N96 option...just not the L31 fender mounted turn signals by themselves. If you have a map light, trunk light and ignition delay, you would have fender turn signals too.
M Code Bees do not code N96 so that's kind of a non starter.
L31 IS a valid option on A12 Bees.
L31 is not part of A01. It's a separate option.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: RoadRunnerJD]
#1568329
01/27/14 11:22 PM
01/27/14 11:22 PM
Posts: 21,554 N.E. OHIO, USA
A12
N.E. OHIO, USA
John, I think a glove box light came with the A01 package and a console compartment light if you had a console(?)
[Re: A12]
#1568330
01/27/14 11:29 PM
01/27/14 11:29 PM
69CoronetRT
Harlan, Iowa
Seeking:
[Re: 69CoronetRT]
#1568331
01/28/14 12:57 AM
01/28/14 12:57 AM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
Yep, my car has N96 and A01.
[Re: Ludington1]
#1568332
01/28/14 02:25 AM
01/28/14 02:25 AM
69CoronetRT
Harlan, Iowa
Pretty sure console light came with the console regardless if you had A01 or not.
Seeking:
[Re: A12]
#1568335
01/28/14 02:55 AM
01/28/14 02:55 AM
AZ A12 Bee, thanks a lot for the detailed photos. I am going to try and print them in detail and hand them right to my bodyman.
[Re: A12]
#1568336
01/28/14 02:57 AM
01/28/14 02:57 AM
Ludington1
Farmland, IN
Can't see any other reason than the right N96 hood scoop on the Dodge blocking the fener light
Just this, I didn't believe it so I put a socket on the fender and sat in the driver's seat and couldn't see it over the scoop from the driving position.
[Re: Ludington1]
#1568338
01/28/14 02:48 PM
01/28/14 02:48 PM
A12
N.E. OHIO, USA
If you had the Ramcharger hood scoops they should have just made the option available at half price ($5.40) then there wouldn't have been any justified complaints of not being able to see it, "Sorry sir we understand that you can't see it and that's the reason we didn't charge you for it"
