Re: Hemi ID Question
[Re: 6bblgt]
#1568210
01/26/14 01:30 AM
01/26/14 01:30 AM
Posts: 5,124 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Looks like the "A" stands for a 20 over size piston. If Chrysler stamped the "A" on the block of my Cuda then it is a 429 Hemi just like a Ford Hemi. I believe when the motor was built the last time the builder stamped the block with the "A" knowing exactly what it was for for future rebuilding information.
1971 HEMI E BODY REGISTRY
[Re: srt]
#1568212
01/26/14 02:23 PM
01/26/14 02:23 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
The machine marks suspicious.
They look factory to me
Concerning the Race Hemi Orange paint (which looks original) all 64-68 Hemis and SOME 69 Hemis were painted Race Hemi Orange. So, it's likely that it was built before the paint color change. As stated, it's most likely a typical service replacement engine of the era that was put into inventory and used when needed as a warranty replacement or simply sold over the counter, etc. The other stampings were added after the fact by whomever, without a paper trail the rest is pure speculation.
[Re: 6bblgt]
#1568219
01/26/14 03:39 PM
01/26/14 03:39 PM
hemicar1971
Chicago Blackhawks
What is needed to be found out to start a search is just what was changed on this motor. Was there a replacement of a block only, short block or long block or complete motor. What version or year is the intake now on the motor. What year are the carbs and is there anything that is a different year to the body on the motor. How does anyone know if there was a complete total change of the motor without more information and maybe taking a look at some date codes on each part of the motor.
Back in the day you would rebuild your race motor every off season. Bearings, rings and updates every winter. Anytime I do any kind of build or rebuild of a motor every thing is taken down to bare metal. Blocks and heads go into the Hot Tank and cleaned. This would mean all paint would be eliminated from the cast iron parts such as the block. So if paint was left on the block then did someone just do a CIL rebuild on the motor by just painting everything. So did the complete motor get the paint of did just some pieces such as the block.
[Re: ScottSmith_Harms]
#1568220
01/26/14 04:39 PM
01/26/14 04:39 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
But as far as the date on the pan rail extension, you might be right Dan, but I've seen some earlier blocks (originals installed in cars) with similar dates, so I can't comment with certainty on that one.
This tag was on a block installed into a 66 Hemi car, it was said to have been purchased as a replacement from Kieth Black back then. I can't say for sure but it appears that it was painted at the factory, either that or someone took the time to mask off the tag before painting and installing the engine.
There's orange paint on the tag, so that leads me to think it wasn't painted at the factory...
[Re: Triggerfish]
#1568221
01/26/14 04:59 PM
01/26/14 04:59 PM
hemicar1971
Chicago Blackhawks
The oil pan is black, not sure why and not sure if it is factory or aftermarket or altered factory pan. The Oil Pan bolts, is that bluish on them and the type of bolts? The only way to know more is to have someone go with the OP and look at all the numbers and colors and what ever that can give more information. Kind of a nice post for learning about different stuff on a Motor and how things were put together.
#1568222
01/26/14 05:27 PM
01/26/14 05:27 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
When i had these Hemi engines, along with a NOS hemi short block, in the crate, none of them were stamped on the ID pad. They did have the WT stamp, along with one or two, letters "B" on the pad. And by the way, the NOS shortblock was unpainted.
RF-4C Phantom 69-370 Zweibrucken, Germany
