Re: opinions on a small block for sale.
[Re: boydsdodge]
#1568151
01/24/14 11:37 PM
01/24/14 11:37 PM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
If it were me I would look elsewhere. Why have to run race fuel because of dome pistons that are part of a pretty much tame bottom end with stock crank and heavy rods. If I was gonna run that much compression I would utilize better and lighter parts and certainly a bigger roller cam. In other words make serious steam. Kinda like a go cart at those rental tracks that they turn the governor screw in on.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#1568152
01/24/14 11:47 PM
01/24/14 11:47 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
With edelbroc heads you are looking 475HP.
I can not really say sense we do not know the price. A larger cam and lighter piston would help but, then you need better rods. It goes on and on. How fast you wanna go how much money you got to get there.
Leon
[Re: Leon441]
#1568154
01/24/14 11:58 PM
01/24/14 11:58 PM
Posts: 20,206 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would keep on looking. Its a roller cam but a real small one. I prefer aftermarket H beem rods with 7/16 rod bolts and you may have issues with a domed piston and edelbrock heads. Flat-top pistons and pump gas works out pretty nice.
[Re: boydsdodge]
#1568155
01/25/14 12:02 AM
01/25/14 12:02 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
" 6.123 new connecting rods (6 pac) " Huh ? Little tells like this usually steer me away from a deal. I'd be leery of six pack road on a big block build because they weigh so much. On a small block deal , they would be too rare to risk running........I've never heard of a small block six pack rod.
[Re: Quicktree]
#1568157
01/25/14 10:52 AM
01/25/14 10:52 AM
Posts: 8,945 Holly/MI
Dean_Kuzluzski
Holly/MI
Assume that it's a pile of parts to be disassembled, inspected, selectively reused and then price accordingly. Or walk away.
It's a "Sum of the (used) parts" kinda deal.
[Re: Dean_Kuzluzski]
#1568158
01/25/14 11:25 AM
01/25/14 11:25 AM
Posts: 2,141 junction city oregon
viperblue72
I would say, if it's cheap and you are buying it for that reason go for it. It would probably run good, but would require race fuel. And I would get it for a price that you wouldn't cry if it blows up. This engine may have already taken a good beating, as it probably loved 7k rpm.
[Re: viperblue72]
#1568159
01/25/14 12:35 PM
01/25/14 12:35 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
It would have to be cheap. It would be pretty easy to duplicate and improve on for not much money.
68 Barracuda Formula S 340
[Re: Bad340fish]
#1568160
01/25/14 01:26 PM
01/25/14 01:26 PM
Leon441
Lynchburg, VA
I'm baffled by all the guys saying to pass. They most know the OP and what he is wanting to do. And evidently his budget.
There are so many guys that are just looking for something better but never get there. Why because someone talks them out of it. There is a lot of fun to be had with something like this if the price is right.
I actually know someone who would love to have this exact short block if the price is right. We just don't know what the price is or where it is advertised.
Not everyone can shell out $10,000 in parts for better stuff and then penny up to put it together with all the cost of small parts.
I have a similar piece for sale. Little different. Larger cam, no tube, really nice light pistons, and a race only prepared block 3/4 full of filler and a max ported set of J heads. I have not advertised it for reasons that come to mind reading this thread. I have almost given this thing away several times to have the buyer talked out of it by larger budget minded people. The buyers eventually gave up and figured this stuff out of their financial reach and quit on their project.
Leon
[Re: boydsdodge]
#1568162
01/25/14 03:10 PM
01/25/14 03:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Being that you want a STREET engine I wouldnt buy it with 12.5 compression... its defiantly not a race engine either with those parts.... unless he is damn near giving it away and you could buy a set of pistons
[Re: MR_P_BODY]
#1568164
01/25/14 04:46 PM
01/25/14 04:46 PM
B3422W5
Portage,michigan
W
Exactly.... Why suffer dealing with 12.5 compression unless your intent is to make serious steam. The cam is real small for a serious performance build, and the bottom end utilizes stock/ heavy parts. Just not a very well thought out piece, in my opinion. And opinions seem to be what the OP was seeking. Why not build a shortblock that is pump gas friendly if just looking for a fun street mill. And on the other hand, if going high compression, use a light spinning assy, and something other than that dinky roller which even still will require pretty decent valve train gear. Just looks like poorly matched parts to me.
[Re: Leon441]
#1568165
01/25/14 08:04 PM
01/25/14 08:04 PM
Posts: 928 NC
SLOW67
NC
Leon
If the price is within his budget and he can hear the motor run and check simple things out on it why not pick it up. Run it as is now and then later if he decides to get more serious swap out the rods/pistons and change the heads. 12.5-1 may be alittle high for the street but sometimes you have to compromise things for something that will fit into your budget, I know I do.
I bought a 75 Nova drag car one time to bracket race, first thing all my friends wanted to do was tear the motor and trans down and go through it and add new parts and better heads and better etc. etc. They had me almost convinced that there was no way it would work as is. Motor ran fine, trans shifted perfect and it was an ok ride for my money. not everyone has deep pockets
[Re: SLOW67]
#1568166
01/25/14 08:28 PM
01/25/14 08:28 PM
Leon441
Lynchburg, VA
Would I run a set of TRW's in a new build? NO, I can afford to come up with a lighter better piston.
Would I run stock rods with bolts? Not with this application but, I have.
Would I run this baby camshaft and deal with it? Probably would have picked something else.
Would I run a 360 cast crank? Absolutely ran one on a 580 horse W2 with 175 NOS for years. The block failed not the crank.
Someone threw out a $1,500 price tag. A cam lifters and block are worth that. Problem is I would personally want more camshaft at that is $300.
Here it is.... If you can scoop it up for $1,000 or less it is a deal. You can't get the block work done for that. Buy a light set of pistons, regrind the cam or buy one, and pick a top end. A worked set of cast irons would do fine but aluminum edelbrocs are lighter and easier to fix.
It all depends on your budget. Less than $4,000 you could have a decent piece. Or buy better stuff and spend well over $6000.
Leon
[Re: SLOW67]
#1568168
01/25/14 08:34 PM
01/25/14 08:34 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
[quote If the price is within his budget and he can hear the motor run and check simple things out on it why not pick it up. Run it as is now and then later if he decides to get more serious swap out the rods/pistons and change the heads. 12.5-1 may be alittle high for the street but sometimes you have to compromise things for something that will fit into your budget, I know I do.
Its a Short block, he cant hear it run, and the TRW domes may not work with his Eddy heads. Plus he wants a street motor. 12 .5 comp is not pump gas friendly, this really wouldnt make for a nice street motor, even if his heads would work out.
I say pass too. It just doesnt fit, unless he gets it for a steal. Then he could redo it to fit his needs. Id just look elsewhere for now.
[Re: Sport440]
#1568169
01/25/14 09:41 PM
01/25/14 09:41 PM
Quicktree
not a lot of usable parts for his build, would have to be dirt cheap
