Re: opinions on a small block for sale.
[Re: Leon441]
#1568170
01/25/14 09:44 PM
01/25/14 09:44 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Would I run a set of TRW's in a new build? NO, I can afford to come up with a lighter better piston.
Would I run stock rods with bolts? Not with this application but, I have.
Would I run this baby camshaft and deal with it? Probably would have picked something else.
Would I run a 360 cast crank? Absolutely ran one on a 580 horse W2 with 175 NOS for years. The block failed not the crank.
Someone threw out a $1,500 price tag. A cam lifters and block are worth that. Problem is I would personally want more camshaft at that is $300.
Here it is.... If you can scoop it up for $1,000 or less it is a deal. You can't get the block work done for that. Buy a light set of pistons, regrind the cam or buy one, and pick a top end. A worked set of cast irons would do fine but aluminum edelbrocs are lighter and easier to fix.
It all depends on your budget. Less than $4,000 you could have a decent piece. Or buy better stuff and spend well over $6000.
Leon
The only machine work we know is done is a bore job, I would sell 360 blocks LA or Magnum all day long with a fresh bore for $500 if I could find buyers. I could throw in a square deck, crank .010 under and line hone and still under $1000 block/crank in a bag.
I have a set of those 12.5 pistons in a short block and they are not close to clearing a closed chamber eddy.
The only way to make it a good running budjet motor... file the dome down some (will have some affect on balance that may or may not be close as is), run the fel-pro .054 thick head gaskets and open the chambers, de-shroud the valves on a set of un-milled J heads and you could get a pump gas livable combo. I would say $750 tops and only after looking at the bearings and bores
