Valve cover #1567436
01/23/14 11:42 AM
01/23/14 11:42 AM
mass
0
03dodgeram Offline OP
mass
I have a set of vintage cal custom alluminum valve covers. They need cleaning. How do I sand and buff them out. Never did it before. Thanks
Re: Valve cover [Re: 03dodgeram] #1567437
01/23/14 07:37 PM
01/23/14 07:37 PM
"easy off" oven cleaner might be appropriate or glass beading if you have one. not sure what finish either of those two would leave you so wait for more opinions & consider this just a BTT
Re: Valve cover [Re: RapidRobert] #1567438
01/23/14 09:05 PM
01/23/14 09:05 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
What kind of finish do you want them to have?
Polished would mean a good de-greasing followed by sandpaper at 600 and then a 1000 grit. Follow that up with a good aluminum polish on a buffer and they will be shiny. It is also the most labor intensive method but you get good results. Here is a pic of a friend of mines 289 FURD that we cleaned up in the spring. These were in pretty bad shape and came out nice. Just tape them up and paint the centers after everything is polished. You can polish everything but man its a LOT of work to do three sides and the bottoms of all the fins.
...FAFO...
Re: Valve cover [Re: skicker] #1567439
01/24/14 09:42 PM
01/24/14 09:42 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'd think that media blasting would be the best way to get them completely clean.
