Re: Power Steering Box Upgrade Options -- Firm Feel ? [Re: cjskotni] #1566965
01/23/14 06:59 PM
01/23/14 06:59 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
I just purchased Stage Two from Firm Feel for my 1969 Plymouth Roadrunner. Give them a call Great to talk to and with advice
Re: Power Steering Box Upgrade Options -- Firm Feel ? [Re: a12rag] #1566966
01/23/14 07:07 PM
01/23/14 07:07 PM
AndyF Online content
AndyF  Online Content
They have a Stage IV that they don't advertise. So if you want the steering really stiff just ask. (But don't complain if it is too much)
Re: Power Steering Box Upgrade Options -- Firm Feel ? [Re: AndyF] #1566967
01/23/14 10:04 PM
01/23/14 10:04 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Wow never seen this board so Pro Firm Feel only.
The answer I usually hear is it depends on where your located and then send to either Firm Feel or Steer and Gear.
I have used both over the years with mostly Steer and Gear since they are closer to the East and have had ZERO problems with either company.
I have never used tighter than a Stage 2 and was ALWAYS satisfied.
The last box was the original from my 70 GTX, Stage 2 done by Steer and Gear.
If I ever pull the one out of my Demon (in decent shape as it sits) it will go the Steer and Gear for a Stage 2 experience.
Ron
Re: Power Steering Box Upgrade Options -- Firm Feel ? [Re: RJS] #1566968
01/23/14 10:14 PM
01/23/14 10:14 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Yup another Firm Feel Fan, better quality control from firm feel vs large reman company steer n gear.
And great service and tech support.
Firm Feel Stage 3 in a 70 Charger R/T.
Same as my 1996 Intrepid ES with the speed sensitive steering. Nice.
Re: Power Steering Box Upgrade Options -- Firm Feel ? [Re: cjskotni] #1566969
01/24/14 12:53 AM
01/24/14 12:53 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
How is the stage III in parking lots? I don't mind some effort but I don't want to feel like I have manual steering either. How does it compare to a modern sedan (not performance) as far as firmness?
I have the Stage 3 in the Charger, along with Fast ratio Idler and Pitman arms that make the effort even higher. Also, I'm turning 275/40/18 tires.
Parking lot maneuvers feels like manual steering. You feel it but don't need to be Arnold Schwarzenegger to drive it.
Power Steering Box Upgrade Options -- What Paint? [Re: Kern Dog] #1566970
02/07/14 11:25 PM
02/07/14 11:25 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I went ahead and ordered the Firm Feel stage III box. I am looking to paint it with Eastwood's Extreme Chassis Black. Will this hold up with the box being so close to the headers?
There is only about 3/8" or so clearance between the box and one of the primary tubes. Is this going to burn the paint right off the box? Would engine paint be a better choice?
Thanks!
Re: Power Steering Box Upgrade Options -- What Paint? [Re: cjskotni] #1566971
02/08/14 03:40 AM
02/08/14 03:40 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I had the same clearance problems with the headers being so close. I ended up denting the headers a little.
Re: Power Steering Box Upgrade Options -- What Paint? [Re: Kern Dog] #1566972
02/08/14 12:32 PM
02/08/14 12:32 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Yeah same here, headers have been 'clearanced' already. I just need to know if the close proximity is going to roast the paint off the gear. FWIW, the gear that's in there came painted and so far, no burned paint....
Re: Power Steering Box Upgrade Options -- What Paint? [Re: cjskotni] #1566973
02/08/14 01:05 PM
02/08/14 01:05 PM
Central TX
roe Offline
roe  Offline
Central TX
I would use the black high heat header paint. Good to 1200 deg or so.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
