Mild Comp SB roller... #1566293
01/21/14 04:05 AM
01/21/14 04:05 AM
Red Deer, Alberta
bill_greenwood Offline OP
Red Deer, Alberta
I think I've landed on a cam pick to replace my wounded MP528 solid. Given that I already have lots of gear and convertor, the Comp 20-702-9 R308 grind looks quite compatible with the rest of my package. 575 lift, I & E, 262 dur at .050, 110 deg lobe centers. I don't think my heads will support much more than that lift wise, and it seems as though I need a bump in duration as much as anything. Has anyone here ran that stick in a 340 or 360?
I'm leaving at a good 4500 convertor flash, shifting at 6800, and hitting the lights at 7100, so I might as well get a cam that will work better from 4500-7000 than my current.
Re: Mild Comp SB roller... [Re: bill_greenwood] #1566294
01/21/14 04:12 AM
01/21/14 04:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Without knowing what the heads flow or what they are
I would think more lift.... if you go to the max flow
on the lift, you only see that point once... BUT if
you go above the max flow lift point you see that max
flow 2 times... I know it helped mine... I'm planning
on going larger yet
Re: Mild Comp SB roller... [Re: MR_P_BODY] #1566295
01/21/14 06:35 AM
01/21/14 06:35 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I have run that cam in another engine. It's a street roller with pretty mild ramps. I think it made better low end tq than the MP 296/.557" cam but was a bit down on power, as strange as it may seem.
Plynouth VIP '67 TT IC EFI
Re: Mild Comp SB roller... [Re: jyrki] #1566296
01/21/14 12:49 PM
01/21/14 12:49 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I just had Bullet grind me this one, Not sure if it'll wind up in the current Airwolf headed 414 or in the W2 headed Tunnel rammed 440.
Similar grind to the one Mopar Dave runs in his 408" cuda, a little wider lobe spread since my car's a little lighter.
WIZE
In Car:
Re: Mild Comp SB roller... [Re: Streetwize] #1566297
01/21/14 01:17 PM
01/21/14 01:17 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
whats your compression in your 414? this cam works really well in my 408@11.4:1 comp.
Re: Mild Comp SB roller... [Re: MR_P_BODY] #1566298
01/21/14 01:54 PM
01/21/14 01:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
on going larger yet
THIS..........been saying this and using this theory for years about getting a cam with more lift than the heads peak at and more duration and my junk has always been quicker than most at similar weight and engine size.
Re: Mild Comp SB roller... [Re: mopar dave] #1566299
01/21/14 01:54 PM
01/21/14 01:54 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
11.7:1 static, The cam I got now is a similar .050 duration but it was designed for the Dodge IROC motors so it's really (and I mean REALLY) broad torque but the lobes are obviously more endurance oriented (only .585/.570 lift @ 1.5) to save the springs....It is very rev happy, but just not suited to the airwolfs higher lift/higher flow capacity.
Whichever motor the bullet winds up in the other one is getting this cam since it'll be a perfect street/strip roller.
If this one stays in the 414 I think I'll go to 1.6's since I know the motor will like the extra lift.
Don't mean to jack the thread buddy!
As for the "over the nose" theory it still applies but but it's a lot less critical when dealing with a Roller, Definately applies to a flat tap since there's no effective Dwell over the nose, you need more on a FT to try to emulate the roller's ability to 'park' the valve for several degrees.
Getting a roller "perfect" has as much to do with the Flanks (ramp area under the curve for the flow window)...maybe more, (especially with wedge heads) as it does with the "square" part of the lobe.
WIZE
In Car:
Re: Mild Comp SB roller... [Re: bill_greenwood] #1566300
01/21/14 02:15 PM
01/21/14 02:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i run that cam in my 360 and love it for what it is. easy on springs makes good power
Re: Mild Comp SB roller... [Re: Streetwize] #1566301
01/21/14 03:06 PM
01/21/14 03:06 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Pretty similar to the one I have for my 340 with 12:1, W2's, victor intake and a 4150 carb. Guess it will like some rev's....
Re: Mild Comp SB roller... [Re: Quicktree] #1566302
01/21/14 04:38 PM
01/21/14 04:38 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Just curious, what kind of times are you getting with that cam? I thought about trying it out a few years back, but never did. I still have a XR286R from Comp in my 410 stroker (and quite happy with it for what it is).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Mild Comp SB roller... [Re: MR_P_BODY] #1566303
01/21/14 07:28 PM
01/21/14 07:28 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
on going larger yet
I have always been a proponent of this theory myself!!!
Re: Mild Comp SB roller... [Re: FlyFish] #1566304
01/21/14 08:13 PM
01/21/14 08:13 PM
Q
Quicktree Offline
Quicktree  Offline
Q
we ran 10.40 @ 129 in my challenger stock crank 360 with indy heads
Re: Mild Comp SB roller... [Re: bwhackd34] #1566305
01/23/14 05:22 AM
01/23/14 05:22 AM
Red Deer, Alberta
Red Deer, Alberta
I can only make an educated guess that my heads flow 240 cfm max on the intake side. They're mildly ported and port matched. I like the Comp grind partly on the basis that the ramps are a bit less radical so it should be a little less stressful on the valvetrain. Keep in mind that I also run 1.6 rockers, so I'm probably close to maxing out on what the heads will provide at max lift anyways.
It took a lot of ruminating while driving down the road to wrap my head around the notion that the reason my car slowed down when adding gear was that I was now spending more time past the torque peak as the car moved down the track. Going from a 240 deg @ .050 cam to a 262 @ .050 should theoretically put the car back in the fatter portion of the torque/horsepower curve going down track. I could get my head wrapped around it until I went back and looked at the time slips. After picking up .05 in the 60, the car was back even at the 330, and then lost ET and mph from that point on. Not enough cam duration makes sense.
Re: Mild Comp SB roller... [Re: Quicktree] #1566306
01/23/14 02:12 PM
01/23/14 02:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya, at 2800 lbs...............details baby...............
Re: Mild Comp SB roller... [Re: Thumperdart] #1566307
01/23/14 02:37 PM
01/23/14 02:37 PM
Q
Quicktree Offline
Quicktree  Offline
Q
3050lbs there thumper dude. back half with steam roller 16x32s. basic 727 no trans brake stock 360 block stock crank eagle rods with probe 11.5/1 compression. what other details would you like there sport?
Re: Mild Comp SB roller... [Re: Quicktree] #1566308
01/23/14 02:47 PM
01/23/14 02:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You old guys really know how to get the most from your stuff fo sho..............
Re: Mild Comp SB roller... [Re: Thumperdart] #1566309
01/23/14 07:24 PM
01/23/14 07:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it's all in the heads, with out the monster tires and a little more converter it would go 10.20s easy
