Page 3 of 3 1 2 3
Re: Gen 3 Hemi Rocker Arms [Re: SC304] #1565901
01/24/14 08:24 AM
01/24/14 08:24 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
The 6.1 crank has been just fine. At the time it's all that was available
The 426 is a Callie's piece cause it is a 4" stroke.
Molnar is supplying my new cranks for the next 6.1 builds.
Going back to dyno next week with some stiffer rocker shafts.
Mike
Mike, you trying out the Trend Shafts?
Re: Gen 3 Hemi Rocker Arms [Re: dizuster] #1565902
01/24/14 11:02 PM
01/24/14 11:02 PM
SC304 Offline OP
SC304  Offline OP
And it runs with the 4.10 gear back in it.
Re: Gen 3 Hemi Rocker Arms [Re: dwayne welder] #1565903
01/24/14 11:07 PM
01/24/14 11:07 PM
SC304 Offline OP
SC304  Offline OP
Roush dyno for this 426 project
Re: Gen 3 Hemi Rocker Arms [Re: STEFF] #1565904
01/24/14 11:09 PM
01/24/14 11:09 PM
SC304 Offline OP
SC304  Offline OP
No too pricy and there are none in stock.
Re: Gen 3 Hemi Rocker Arms [Re: SC304] #1565905
01/25/14 12:23 AM
01/25/14 12:23 AM
MN
hemidup Offline
hemidup  Offline
MN
Are you using stock diameter rockershafts or a smaller diameter shaft with sleeves like HS?
Jerry Williams.
Re: Gen 3 Hemi Rocker Arms [Re: SC304] #1565906
01/25/14 09:19 AM
01/25/14 09:19 AM
STEFF Offline
STEFF  Offline
Yeah, I was a little floored by the price as well......$200 per shaft is a bit spendy.
Re: Gen 3 Hemi Rocker Arms [Re: STEFF] #1565907
01/25/14 05:26 PM
01/25/14 05:26 PM
MN
hemidup Offline
hemidup  Offline
MN
At $400 a set? Yeah, so was I. I was going to revamp some SB rockershafts to fit the G3's, but the cost of the shafts and machining work wouldn't be cost effective so I went another route.
I bought bulk tubing which I cut to length, centerless ground the tubing to the proper shaft diameter, machined the mounting holes, oil feed holes and shaft ends and then had them Nitrated, Tufftride*/Melonite QPQ treated so I ended up with hardened, treated rockershafts for way less.
Sorry for all the comma's lol
Jerry Williams.
Page 3 of 3 1 2 3
