Re: Gen 3 Hemi Rocker Arms
[Re: SC304]
#1565901
01/24/14 09:24 AM
01/24/14 09:24 AM
Posts: 3,875 Smyrna, South Carolina
STEFF
The 6.1 crank has been just fine. At the time it's all that was available
The 426 is a Callie's piece cause it is a 4" stroke.
Molnar is supplying my new cranks for the next 6.1 builds.
Going back to dyno next week with some stiffer rocker shafts.
Mike
Mike, you trying out the Trend Shafts?
[Re: SC304]
#1565905
01/25/14 01:23 AM
01/25/14 01:23 AM
Posts: 833 MN
hemidup
MN
Are you using stock diameter rockershafts or a smaller diameter shaft with sleeves like HS?
Jerry Williams.
