Re: Cowl Hood
[Re: 440W8 Duster]
#1565801
01/20/14 06:28 PM
01/20/14 06:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Another thing to think about... when you are traveling down the road in a rain... which way do the rain drops go... if up then its not gonna put air into the back of the cowl... the cowl itself is blocking the upward flow if its close enough to give the low pressure area needed at the back of it... so between the low pressure created from the intake/pistons and the cowl close enough it should get good flow.... I was gonna do a test on my car(P-Body) and a guy that was running a cowl.. we both had similar speeds but he blew up the engine and I never got the chance ![](/ubbthreads/images/graemlins/wave.gif)
Re: Cowl Hood
[Re: headhunter]
#1565806
01/20/14 10:37 PM
01/20/14 10:37 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
what about both
Now that this car is a streeter,want to sell the hood or trade lmk.
Thats the set up i want ![](/ubbthreads/images/graemlins/smile.gif)
Re: Cowl Hood
[Re: mistress]
#1565809
01/21/14 02:10 AM
01/21/14 02:10 AM
MR_P_BODY
My 8 inch glasstek
Is your scoop sealed... where is the seal at in relation to the hood itself... also where are the carbs in the scoop... how far from the top of the carbs to the scoop ![](/ubbthreads/images/graemlins/wave.gif)
Re: Cowl Hood
[Re: MR_P_BODY]
#1565810
01/21/14 11:13 AM
01/21/14 11:13 AM
Posts: 176 South Bend, Indiana
mistress
South Bend, Indiana
My 8 inch glasstek
Carbs are pretty much center of scoop and the front carb is about 3 inches from scoop, rear carb a little more clearance. There is about an inch and half clearance to windshield and carbs are not sealed to hood.
Re: Cowl Hood
[Re: 440W8 Duster]
#1565812
01/21/14 12:12 PM
01/21/14 12:12 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
On another note. SS/AH do they seal their carbs or not to the scoop?
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
Re: Cowl Hood
[Re: 440W8 Duster]
#1565813
01/21/14 12:24 PM
01/21/14 12:24 PM
mistress
South Bend, Indiana
My 8 inch glasstek
So does it run quicker sealed to the hood or not sealed?
I had a smaller cowl hood with a single carb and sealed it to hood and didn't make a bit of difference, now with the tunnel ram and two 4's i didn't mess with trying to seal the carbs on this hood.
Re: Cowl Hood
[Re: 440W8 Duster]
#1565815
01/21/14 01:14 PM
01/21/14 01:14 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
FWIW...I used to run a six pack hood on my cuda. It ran about a tenth quicker and 1 mph faster sealed than it did unsealed. I switched to a 5" cowl hood, unsealed, and it ran the same as the sealed six pack hood. This was on a combo that I'd run for years. I have experimented w/ sealing the cowl hood to the carb but haven't seen anything really. ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Cowl Hood
[Re: 440W8 Duster]
#1565816
01/21/14 01:50 PM
01/21/14 01:50 PM
mistress
South Bend, Indiana
My 8 inch glasstek
Do you have a SB or BB?
BB
Re: Cowl Hood
[Re: 440W8 Duster]
#1565817
01/21/14 02:00 PM
01/21/14 02:00 PM
Posts: 141 iowa
bad1970dust
"Hollywood"
"Hollywood"
iowa
my 71 with cowl
Is that in Humboldt Ia?
Yes our local skating rink lol ![](/ubbthreads/images/graemlins/grin.gif)
Re: Cowl Hood
[Re: 440W8 Duster]
#1565819
01/21/14 08:50 PM
01/21/14 08:50 PM
Posts: 995 Addison,IL
OUTLAWSSAA
Addison,IL
If you go down to the US Nationals and look at all the hemi cars, not one of them that I saw had there hoods sealed to the carbs.
