Cowl Hood
#1565781
01/19/14 09:48 PM
01/19/14 09:48 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
post pictures of your cowl hood A-Bodies. which one would be faster and more effective a Cowl hood or Aero hood scoop? Any track back to back testing.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
Re: Cowl Hood
[Re: Dragula]
#1565788
01/20/14 01:40 AM
01/20/14 01:40 AM
Triple Threat
Renton Washington
I've done a bit of research on this lately. Big aero scoops seem to be worth a little bit of ET over cowl's or other small forward facing scoops like you have now. The con is they're a pain to see around, if you've ever driven a car with one, you know what I mean.
Re: Cowl Hood
[Re: Jeepmon]
#1565795
01/20/14 02:25 PM
01/20/14 02:25 PM
Posts: 4,662 Motor City
6PKRTSE
Motor City
Nice Nova's guys. LOL. Just kidding alot of nice A bodies though.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Cowl Hood
[Re: 6PKRTSE]
#1565796
01/20/14 03:51 PM
01/20/14 03:51 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
My car hates the cowl hood I run a 5inch glasstek similar to Johns.I have tried 3 to 4 air pans,blocking this and that and different carb spacers and it dirty's the plugs after one run. I also run a max effort carb that's 2.20 bore that's made for the most air you can throw at it.
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
Re: Cowl Hood
[Re: 440W8 Duster]
#1565798
01/20/14 05:11 PM
01/20/14 05:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Chris how does Butch Kemp run so quick with a cowl hood on the Mustang and its sealed to the hood
You need to look at the distance from the windshield.. close(about 1" to max 2")... this is mine but its no A-body... I set this up up so I could hinge it but I am thinking about making a slider on the back opening to get it close for racing
Re: Cowl Hood
[Re: FASTFISH420]
#1565800
01/20/14 05:26 PM
01/20/14 05:26 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
Mine loves the cowl hood(6" glasstech)...no air pan or even close to the windshield...145mph in the 1/8 and should be in the 150mph range with the new combo !!
Re: Cowl Hood
[Re: 440W8 Duster]
#1565801
01/20/14 05:28 PM
01/20/14 05:28 PM
MR_P_BODY
Another thing to think about... when you are traveling down the road in a rain... which way do the rain drops go... if up then its not gonna put air into the back of the cowl... the cowl itself is blocking the upward flow if its close enough to give the low pressure area needed at the back of it... so between the low pressure created from the intake/pistons and the cowl close enough it should get good flow.... I was gonna do a test on my car(P-Body) and a guy that was running a cowl.. we both had similar speeds but he blew up the engine and I never got the chance
Re: Cowl Hood
[Re: headhunter]
#1565806
01/20/14 09:37 PM
01/20/14 09:37 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
what about both
Now that this car is a streeter,want to sell the hood or trade lmk.
Thats the set up i want
Re: Cowl Hood
[Re: mistress]
#1565809
01/21/14 01:10 AM
01/21/14 01:10 AM
MR_P_BODY
My 8 inch glasstek
Is your scoop sealed... where is the seal at in relation to the hood itself... also where are the carbs in the scoop... how far from the top of the carbs to the scoop
Re: Cowl Hood
[Re: MR_P_BODY]
#1565810
01/21/14 10:13 AM
01/21/14 10:13 AM
Posts: 176 South Bend, Indiana
mistress
South Bend, Indiana
My 8 inch glasstek
Carbs are pretty much center of scoop and the front carb is about 3 inches from scoop, rear carb a little more clearance. There is about an inch and half clearance to windshield and carbs are not sealed to hood.
Re: Cowl Hood
[Re: 440W8 Duster]
#1565812
01/21/14 11:12 AM
01/21/14 11:12 AM
440W8 Duster
San Antonio,TX
On another note. SS/AH do they seal their carbs or not to the scoop?
Re: Cowl Hood
[Re: 440W8 Duster]
#1565813
01/21/14 11:24 AM
01/21/14 11:24 AM
mistress
South Bend, Indiana
My 8 inch glasstek
So does it run quicker sealed to the hood or not sealed?
I had a smaller cowl hood with a single carb and sealed it to hood and didn't make a bit of difference, now with the tunnel ram and two 4's i didn't mess with trying to seal the carbs on this hood.
Re: Cowl Hood
[Re: 440W8 Duster]
#1565815
01/21/14 12:14 PM
01/21/14 12:14 PM
Posts: 13,543 Marion, South Carolina [><]
an8sec70cuda
FWIW...I used to run a six pack hood on my cuda. It ran about a tenth quicker and 1 mph faster sealed than it did unsealed. I switched to a 5" cowl hood, unsealed, and it ran the same as the sealed six pack hood. This was on a combo that I'd run for years. I have experimented w/ sealing the cowl hood to the carb but haven't seen anything really.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: Cowl Hood
[Re: 440W8 Duster]
#1565816
01/21/14 12:50 PM
01/21/14 12:50 PM
mistress
South Bend, Indiana
My 8 inch glasstek
Do you have a SB or BB?
BB
Re: Cowl Hood
[Re: 440W8 Duster]
#1565817
01/21/14 01:00 PM
01/21/14 01:00 PM
Posts: 141 iowa
bad1970dust
"Hollywood"
"Hollywood"
iowa
my 71 with cowl
Is that in Humboldt Ia?
Yes our local skating rink lol
Re: Cowl Hood
[Re: 440W8 Duster]
#1565819
01/21/14 07:50 PM
01/21/14 07:50 PM
Posts: 999 Addison,IL
OUTLAWSSAA
Addison,IL
If you go down to the US Nationals and look at all the hemi cars, not one of them that I saw had there hoods sealed to the carbs.
Re: Cowl Hood
[Re: John Burdine]
#1565823
01/21/14 09:04 PM
01/21/14 09:04 PM
Posts: 2,601 ky
headhunter
ky
Glasstek 6"
that's a good looking demon
Re: Cowl Hood
[Re: fishy340]
#1565824
01/21/14 09:10 PM
01/21/14 09:10 PM
Posts: 2,601 ky
headhunter
ky
what about both
I don't know ive thought about getting another hood but it kinda grows on you lol
Re: Cowl Hood
[Re: headhunter]
#1565826
01/21/14 10:43 PM
01/21/14 10:43 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
So does the paint job
Re: Cowl Hood
[Re: headhunter]
#1565827
01/22/14 10:07 AM
01/22/14 10:07 AM
an8sec70cuda
if im not mistaking the carbs sit to high in the scoop to seal them
Using drop bases on the carbs will fix that. Seen it done many times. If it was worth any power on those cars, I'm sure they would be doing it.
Re: Cowl Hood
[Re: Thumperdart]
#1565829
01/22/14 03:33 PM
01/22/14 03:33 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
If you`re talking about the Hemi guys, I read somewhere that they can`t use air pans.................
Sure they can, problem is they don't help. The scoop has to be kept within factory dimensions and as discussed in other threads is not high enough to do any good. Sealing the scoop would probably cost it air vs letting it get some underhood air unsealed.
Monte
Re: Cowl Hood
[Re: Monte_Smith]
#1565830
01/25/14 01:39 PM
01/25/14 01:39 PM
Posts: 232 NYC
Dartari
NYC
Monte
Hi Monte in your opinion is there an advantage in the glasstek 5" six pack scoop over the glasstek 6" cowl hood thanks for any insight you may have
Re: Cowl Hood
[Re: Monte_Smith]
#1565831
01/25/14 02:47 PM
01/25/14 02:47 PM
MR_P_BODY
Monte
... they just arent tall enough to get up into the real air flow... they MAY be getting a good percentage of their air flow from inside the hood area.. I picked up ET and 3 MPH on my scoop when I sealed it
Re: Cowl Hood
[Re: headhunter]
#1565837
01/26/14 02:25 PM
01/26/14 02:25 PM
Monte_Smith
North Alabama
is my carb up in the scoop high enough to be any good?
I would venture a guess that this car will run the SAME, with or without a plug in the scoop
Monte
